A cost no object ideal Analog Reconstruction Filter - is it a thing?
gvl
SoCal
The endless agonizing about oversampling digital interpolation filters and how they can badly affect the sound leaves one wondering if it is possible to create an ideal analog filter that would make a digital filter unnecessary. The common knowledge tells us that digital filters were introduced to simplify the design of the analog anti-imaging filters, i.e. reduce costs. What if one doesn't care about the cost? I'm pretty sure it is possible to create a heck of an analog filter for the amount of money some makers charge for their DACs, some of which, ironically, have no filters at all.
restorer-john
Digital filters in the case of Compact Disc were created due to the fact that Philips had already committed to silicon 14 bit D/A converters (as had Toshiba) when the working group decreed that 16 bit was the standard. Oversampling gave them almost 16bits of resolution using 14 bit D/As and precious extra time to get true 16bit D/As fabricated. (the dual channel TDA-1541)
It was a welcome byproduct of oversampling (4 times in the case of the first TDA-1540D, single channel 14 bit D/As released in their CD players in March 1983), that the analogue reconstruction filters could be less complicated and less costly.
The analogue filters used in the very first generation CD players were expensive to buy and align. 13th order Chebyschev were used in some early machines IIRC.
This is single sample, full 0dBFS impulse as produced by the very first commercially released CD player- the Sony CDP-101 (I have several in my collection). Note, due to oversampling not appearing on this unit, there is absolute zero pre-ringing. There is considerable post-ringing however.
Here's a 100Hz square wave, again on the CDP-101
Here's the same single sample pulse on a 24/196 CD player with OS (A Marantz PMD-325 professional machine) Horizontal Scales are not the same however- it is not really that clean
Zoomed in to 100uS/Div to see the pre-ringing of the oversampling DF.
The same square wave for comparison
Personally, I have absolutely no problem listening to well implemented 16/44 D/As, using analogue (brickwall) filters.
But, my favourite machines are Sonys, their flagship machines from 1989-91 which used BB PCM-58P K in 8x OS. To this day, their CD (measured) performance is truly beyond any rational criticism. It makes me smile to see standalone D/As of today, that can't approach what those machines achieved on Red Book nearly 30 years ago.
gvl
gvl
SoCal
Thanks, I suppose my question is can you do better than the filters in those early players.
restorer-john
I would say, that at 16/44 NOS, no, you couldn't do any better than the analogue filters they used.
The choice of filters was based solely on performance, and LPF filter price was not a an issue in the early generation machines as they were loss making for several years in any case. Murata made most of the filters and once economies of scale kicked in, their price dropped, but the bit race was on and OS was the rage. There were only a few years where ultra high grade analogue filters were in use. Basically, I would say from 1983/4- 1986.
gvl
gvl
SoCal
That impulse response looks not much different than that from the minimum phase filter that many seem to like these days .
Cosmik
The endless agonizing about oversampling digital interpolation filters and how they can badly affect the sound....
They may agonize over it, but it doesn't mean that oversampling filters do badly affect the sound - the opposite is more likely because oversampling filters are closer to the theoretically perfect filter, as designed by humans using mathematics, just like the rest of the digital audio system.
Audiophiles need something to agonize over, and in the case of digital audio they're struggling because it is so close to perfection in a $1 integrated circuit. That cannot be allowed to happen or else they would be left with nothing but music to spend their time listening to.
svart-hvitt
True, the accuracy problem in a $100 digital device is a fraction of the accuracy problem in, say a $100k analog turntable system.
Why is it that analog inaccuracy is benign while digital inaccuracy is malign?
Wombat
Australia
It is to do with which crowd and which neutral.
restorer-john
Ironic isn't it?
The issue however is many of the early machines using NOS also had a single multiplexed D/A resulting in a phase error (interchannel delay) that increased as the frequency went up. That said, in a normal 2 channel stereo I have never been able to hear it. It only becomes remotely significant at high frequencies.
Here's a 3.15KHz example of the CDP-101, showing the interchannel phase delay.
Theo
If this is just a delay between channel, moving your armchair a few inches should compensate that, shouldn't it?
Kal Rubinson
Industry Insider
NYC
I published an article in The Audio Amateur on doing that way back in the last century.
MY ERROR: I was referring to the reconstruction filters on the output of the DAC.
Kal Rubinson
Industry Insider
NYC
What was the verdict?
My feeling was that it was worthwhile but that was very early in the CD era and the issue of filtering was fairly simplistic.
EDIT: MY ERROR: I was referring to the reconstruction filters on the output of the DAC.
DonH56
Monument, CO
The interpolation filter at the input of DACs is usually a digital thing, not sure why you'd want to insert an analog network into that path. Interpolation is used to assist in oversampled designs to create an approximation of the signal generated by a higher sampling rate. The higher sampling rate allows use of a simpler analog output anti-imaging (some just say image) filter since the images are reflected about Nyquist (one-half the sampling rate) so higher sampling rate means images are higher and easier to filter. Digital interpolation filters can be much higher order, with desirable characteristics such as linear phase (for better time-domain response), and are stable over process, voltage, and temperature (PVT) variations.
The output filter is normally analog, and numerous types have been used, with varying impact on the signal. Some of the best for roll-off (image suppression) have more in-band ripple, and some of the best for time response have slow roll-off so very high orders (complex filters) are needed. Always trades (digital or analog). In-band artifacts are greatly reduced when the filter's transition band (corner frequency) can be moved well above the audio band. Early filters introduced significant phase shift well into the audio band and often caused HF ringing. Later filters were based on more modern filter theory and exhibited fewer problems.
FWIFM - Don
Edit: Was typing so missed Kal's response... @Kal Rubinson , is the article on-line?
Kal Rubinson
Industry Insider
NYC
The interpolation filter at the input of DACs is usually a digital thing, not sure why you'd want to insert an analog network into that path. .....................
FWIFM - Don
1. MY ERROR: I was referring to the reconstruction filters on the output of the DAC.
2. I doubt it. I have been trying to find it but all I can find is this reference: "Passive Filters for Digital Audio", Kalman Rubinson, TAA 4/94, p. 30
3. Cited here: http://info.linuxoid.in/radio/audio/cd1/AMPLIFIERS/39/JT DAC No_ 3.htm
I am sure that I have a print copy at home.
DonH56
Monument, CO
gvl
gvl
SoCal
Sounds like there are missed opportunities in the modern audiophile business. Given a decent analog anti-imaging filter they can slap the mysterious NOS stamp on a DAC (NOS sounds good, right?) and have this DAC measure reasonably well and probably sound better than filterless NOS. Who knows, may be it is the next big thing.
restorer-john
...and probably sound better than filterless NOS...
Filterless NOS is just utterly ridiculous. No serious manufacturers would allow a product out the door with that implementation. It is essentially a faulty product, not fit for purpose.
It's a bit like removing the catalytic converter and muffler from a car because they 'stifle' the performance when they do the complete opposite.
gvl
gvl
SoCal
Objectively, Dyno tests confirm removing the cat, and muffler is a way to increase engine power :)
restorer-john
And spew all sorts of toxic substances into the air as well as producing excessive and undesirable noise- that was my analogy.
