40db below the fundamental is equivalent to 1%. So the ascend is just hitting 1% in a couple of areas (56db)Seems to be an outstanding directivity and FR, my only concern it's the distortion between 300hz-20khz is not close (lets see only the 300hz-20khz range, because the 208 is using 8'' woofers. The guy from A.A was right btw, these woofer are pushing a lot of bass at low distortion) vs Revels like F208.
Also there is a peak of distortion at 300hz~
In my ignorance, i don't know if this were the best low distortion build or not, I saw there is a lot of versions.
You're wrong in this one, they both are Klippel measurements. But yes, the ascend is just hitting a little above 1% in a couple of areas at 96dB. Thing is, at 86 is also hitting 1% above 3.5Khz+40db below the fundamental is equivalent to 1%. So the ascend is just hitting 1% in a couple of areas (56db)
Also, I'm pretty sure that distortion measurements are not comparable unless performed in the same environment with the same equipment? But I could be wrong.
Personally, I would be curious to see how the titan version measures up
Thanks for pulling all of those together in one place.You're wrong in this one, they both are Klippel measurements. But yes, the ascend is just hitting a little above 1% in a couple of areas at 96dB. Thing is, at 86 is also hitting 1% above 3.5Khz+
Another example, Kef LS50 meta, the tiny speaker. Distortion aren't bad but aren't good enough for say they are one of the best below '' 20k USD '', when much cheaper speakers have lower distortion.
*If i'm not wrong it's 3rd harmonic dominance.
86dB measurements distortion data:
Bonus, Revel M106:
This one have lower distortion than the tower even at 96dB.
DB | % |
-26 | 5 |
-28 | 4 |
-30 | 3 |
-34 | 2 |
-40 | 1 |
-46 | 0.5 |
-52 | 0.25 |
-60 | 0.1 |
-66 | 0.05 |
ThanksThanks for pulling all of those together in one place.
When comparing, keep in mind some displays use % and some use dB.
Here's a conversion chart:
DB % -26 5 -28 4 -30 3 -34 2 -40 1 -46 0.5 -52 0.25 -60 0.1 -66 0.05
So on the charts that show the fundamental at 86dB, if the THD is at 56dB it's -40dB from the fundamental or 1%. And as the readers here will know, the harder a speaker is pushed, the higher the THD will be (i.e. any graph of data at both 86 and 96dB for the same speaker). I wish the data was always presented both ways, much easier to compare the THD % across speakers.
Actually, other poster is correct and you are incorrect.
As awesome as the Klippel NFS is, it is really not much different than REW for THD measurements. In the case of THD, the NFS is measuring the speaker and the environment, especially when measured at 1 meter (Amir's procedure). As such, the room and the overall environment greatly influence the distortion results. Amir's THD measurements really shouldn't be compared with ours, I can say this with full confidence as our THD measurements of some of the same Revel speakers he measured are significantly higher. We have our NFS in my lab, which I believe is quite a bit smaller than the room Amir has his NFS in (garage?), thus more destructive room influence in our setup.
Ideally, THD measurements need to be taken using close mic techniques, to minimize the influence of the environment. Amir's THD measurements are ok for comparing one measurement he has taken with another he has taken, provided the environment and procedure has not changed.
This is one of the main reasons we do not publicly post distortion measurements, and few - if any, manufacturers do. The only way to get consistent and comparable results is to use an anechoic chamber for these measurements.
Klippel has released a few new add-on distortion modules, and combined with another add-on, are less influenced by the environment. The ISC module removes room reflections by essentially comparing the anechoic on-axis results of a full spin, to a simple on-axis measurement. This module combined with MTON module (multi-tone) does indeed produce more accurate and comparable distortion measurements. We have ISC and I use it regularly, but it does not function with the standard distortion feature of the NFS. If used with standard distortion function, it removes the room after the measurement has been made, thus has no influence on the actual distortion measurement.
In summary, one really can't compare NFS THD measurements from one system to another, at least not yet. If using MTON in combination with ISC, results from one NFS system to another will be more comparable, but not still not fully.
Hope this makes sense.
You address this later but to be clear, I did at the start use the NFS feature to remove the room reflections. Here is an example of anechoic distortion I have published:As awesome as the Klippel NFS is, it is really not much different than REW for THD measurements. In the case of THD, the NFS is measuring the speaker and the environment, especially when measured at 1 meter (Amir's procedure). As such, the room and the overall environment greatly influence the distortion results. Amir's THD measurements really shouldn't be compared with ours, I can say this with full confidence as our THD measurements of some of the same Revel speakers he measured are significantly higher. We have our NFS in my lab, which I believe is quite a bit smaller than the room Amir has his NFS in (garage?), thus more destructive room influence in our setup.
Clarifying this as well, I use 1/3 meter for my distortion measurements. But I report at 1 meter. This, and gating further helps to reduce impact of the room.Ideally, THD measurements need to be taken using close mic techniques, to minimize the influence of the environment. Amir's THD measurements are ok for comparing one measurement he has taken with another he has taken, provided the environment and procedure has not changed.
We have the ribbon towers. Does anyone have an idea what the upgrade kit will cost?
We digitize subjective impressions and handle them as data all the time. For example, mean opinion scores have been around since long before I started studying telecommunications in the 80s. Other fields such as medicine and blending drinks rely on measurement of subjective reports too. Heterophenomenology in general involves the production of objective data about the subjective experiences of others.Subjective impressions are just that: impressions. They are not data. Data are numerical facts used in the calculation of mathematical problems.
I was thinking about this. From what I understand, it's caused by cancelation between the two woofers oriented horizontally. This is why it doesn't show up in the vertical directivity. This is the typical 'lobing' issue we see in MTM speakers. It can be avoided in a 3-way design by crossing over from the horizontally oriented woofers at a low frequency, such as Revel or KEF do in their 3-way center channel speakers. I have to wonder why Dave went with a somewhat high crossover point, especially since the EX woofer used as the midrange is perfectly capable of playing bass. It makes me wonder if it's a side effect of his unique crossover design, a cost saving compromise in the crossover, or just a compromise to avoid some other issue.The Horizon's dispersion is extremely wide, but there is a little bit of narrowing in the 300 - 600Hz region.
In reality, it's probably not that audible, if audible at all outside of very specific instances like, say, if you were specifically testing for it using sweeps / tones. It happens over a fairly narrow range, and even then you'd probably need to be well off-axis to really pick up on it. You're very likely correct and a lower crossover could have smoothed it out, but perhaps doing so would introduce some other, more impactful anomaly. Or perhaps the LX woofers simply "punch" harder in that region and Dave felt that it was worth trading out a small amount of dispersion for. Obviously, it's a question for him. Centers in particular are an exercise in compromises.I was thinking about this. From what I understand, it's caused by cancelation between the two woofers oriented horizontally. This is why it doesn't show up in the vertical directivity. This is the typical 'lobing' issue we see in MTM speakers. It can be avoided in a 3-way design by crossing over from the horizontally oriented woofers at a low frequency, such as Revel or KEF do in their 3-way center channel speakers. I have to wonder why Dave went with a somewhat high crossover point, especially since the EX woofer used as the midrange is perfectly capable of playing bass. It makes me wonder if it's a side effect of his unique crossover design, a cost saving compromise in the crossover, or just a compromise to avoid some other issue.
Maybe size of inductor was more of a concern than cost, I wouldn't know. I looked at the horizontal Klippel measurements of the Revel C208 and Kef R2C again after posting. It seems like they have the same narrowing of directivity in the lower mids due to the horizontally opposed woofers. Maybe it is just a very difficult to avoid issue.I can't imagine there's any cost savings concerns on an internet direct $2500 speaker. This is already double the price of its quasi-predecessor, which itself likely already had incredibly healthy margins being their (heretofore) premium high end model. This speaker's priced where it is to pay for the Klippel, not materials. They even abandoned the "Made In USA" commitment they used to use to justify their pricing (which I personally don't care about, just pointing it out).
It's really strange to see a company taking into account things like research and developmental costs when pricing it's products. I don't understand why more companies don't just try to barely break even, or maybe even lose a little money. They could just cut salaries and have less money to invest in the future of the business. No big deal, I'm sure you'd agree to something like that at your job.I can't imagine there's any cost savings concerns on an internet direct $2500 speaker. This is already double the price of its quasi-predecessor, which itself likely already had incredibly healthy margins being their (heretofore) premium high end model. This speaker's priced where it is to pay for the Klippel, not materials....
