Fitzcaraldo215
- Joined
- Mar 4, 2016
- Messages
- 1,440
- Likes
- 633
I think added bit depth has two faces. It is hard indeed to make a case for it techically on playback of a CD, whose playback bit depth, especially properly dithered, is more than adequate for home listening. However, recording engineers I have spoken to, no doubt a small sample, value the added headroom that accompanies added bit depth across the various recording, mixing and mastering processing stages through a variety of equipment. Obviously, true 24 bit depth is not realistically achievable on recording or playback. But, at least some of those added bits are useable in extending low level detail above the noise.
I witnessed a very hirez, Mch classical recording session in the control room several years ago, and I was surprised to see that all the mic feeds were totally wide open, each capturing maximum S/N. Obviously, on mixing and mastering, individual channels would be comparatively adjusted proportionately to achieve a proper, "artistic" sense of sonic balance. I did not witness the final mixing/mastering process. But, in no case would low level dynamics become lost in the noise in the final mix or mastering as final production sound level, EQ or other adjustments were made due to the headroom provided by the added bit depth in the production chain.
Even before that, I believed, and still do, that one advantage to hirez was better capture and playback of low level audio detail in the signal. Much of this advantage can still be obtained by hirez 24 bit recording and production for CD then carefully fitting maximum hi and lo level dynamics of the hirez master into the slightly reduced 16 bit plus dither capacity of CD's bucket size. (I am especially not talking about dynamically compressed, loudness wars music, which is a different matter.) But, I don't think recordings captured, then mixed and mastered at 16 bit depth enjoy the same advantage in retaining low level detail through the production chain, regardless of the final distribution and playback format, CD or otherwise.
