Denon AVR-X2200W Audio/Video Receiver Review
This is a review and detailed measurements of the Denon AVR-X2200W home theater AVR (processor and amplifier). It is on kind loan from a member. Looks like the unit was released back in 2015. I can't find the pricing on it but I am guessing US $700 when new. Used ones seem to go for as little as US $250. Despite its age, all the modern features seem to be there from UHD video resolution to Dolby Atmos.
The front panel is the usual affair with AVRs (you have seen one, you have seen them all):
The OSD (on-screen display) is low resolution (1080p?) but fairly responsive. Amplifier construction is of the flimsy heatsink type to keep the weight down. As a result, the unit runs warm even at idle.
Back panel shows outdated inputs which shouldn't have been on it even then:
Denon AVR-X2200W Home Theater AVR Dolby Surround Back Panel Connectors Audio review.jpg
Like the clear labels on speakers though. And the little clips that keep the Wifi antenna in place and not risk ripping them out.
AVR Audio Measurements
There is no preamp output so I can't test the DAC portion by itself. So all the tests are from speaker output. Let's start with our dashboard of 5 watts into 4 ohm using HDMI as the input:
Denon AVR-X2200W Home Theater AVR Dolby Surround HDMI Audio Measurements.png
Shame one channel (in blue) is worse than the other by good bit. Still, this is not an embarrassing showing seeing how bad many AVRs are. Among all amplifiers tested, the ranking is middle of the road:
Among AVRs, it does a bit better:
Crosstalk was rather disappointing:
Denon AVR-X2200W Home Theater AVR Dolby Surround Analog In Crosstalk Audio Measurements.png
The dashed green line is a $25 ebay-special amplifier!
Signal to noise ratio ranks similarly:
Denon AVR-X2200W Home Theater AVR Dolby Surround Analog In Dynamic Range Audio Measurements.png
Frequency response using the analog input was surprisingly flat and wide:
Denon AVR-X2200W Home Theater AVR Dolby Surround Analog In Frequency Response Audio Measurements.png
No digitization, no band limiting. I like it!
Power into 4 ohm load is very healthy (with two channels driven):
Denon AVR-X2200W Home Theater AVR Dolby Surround Analog In Power into 4 Ohm Audio Measurements.png
Denon AVR-X2200W Home Theater AVR Dolby Surround Analog In Power into 8 Ohm Audio Measurements.png
There is good bit of extra juice for momentary power requirements (again, in two-channel configuration):
Denon AVR-X2200W Home Theater AVR Dolby Surround Analog In Burst and Max Power into 4 Ohm Audi...png
As time has gone by, complexity of building these devices has gone up and with it, much more opportunity to screw things up. The Denon AVR-X2200W seems to predate some of this grief and appears sound. No, it still doesn't hold a candle to any desktop or main system 2-channel audio products. But if you can pick it up for $250, it may do the job as well as some expensive and new AVRs.
No recommendation one way or the other.
Had to go to the store and buy another rack to store the large number of big boxes of audio gear that keeps arriving. Could use having cash to pay for the credit card when the bill comes so please donate using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Doodski
Apparently the protection circuitry did not engage. 4 Ohm and 8 Ohm output power was respectable for what it is and it has the reliability of a Denon which from what I've experienced is pretty good. I still am suspect that Sony and Denon are made in the same factories :p They share the same common transistors, the service manuals are near identical in layout and style but the Denon does seem to be a notch above Sony overall IMHO.
stunta
Boston, MA
True, but the back panel is surprisingly less cluttered than most AVRs. Thanks for the review. This looks like a good AVR to recommend to friends who are on a tight budget.
Sancus
Agree, it could have been even worse for the era.
And all that stuff is still on the 2019 versions. I wonder if the reason they haven't gotten rid of the RCA video/component in/outs is because they're just re-using that same PCB over and over again and see no reason to change it.
bobbooo
I see it has 'ZONE2 PRE OUT' connections on the back - can't you use those for this test?
Edit: From the manual,
Connection 2 : Connection using an external amplifier
The audio signals of this unit’s ZONE2 audio output connectors are output to the ZONE2 amplifiers and played on these amplifiers.
I have done that in the past and people complain that the zone 2 is often using an inferior DAC.
bobbooo
As you said this model "seems to predate some of this grief and appears sound," maybe the same is true of the preamp DAC used here - I and I'm sure many others would be curious to know and much appreciate the zone 2 pre-outs being tested on this unit.
Nathan_A
Compared to most of the mainstream AVRs (and even some niche ones), it seems like the Pioneer D3-based like @amirm's old SC-61 hold their own fairly well.
Thanks for the review, Amir. I'm sure this has been requested before; are you able to test power versus distortion for all channels driven?
Not with this unit. If it had analog multi-channel input I could test 4 channels.
martin900
Dear Amir, if it's possible in the future, I'd love to see power/distortion measurements vs amount of channels driven.
maty
Tarragona (Spain)
QMuse
# of driven channels affects max output power per channel, not THD. ;)
twofires
I'd say game consoles played a large part in the decision to keep analogue inputs. In 2015 lots of people would still have had their X-Box 360s and Nintendo Wiis hooked up, and would have appreciated the digitisation, upscaling, and single cable out solution the Denon offered. Today? Not so much.
Vovgan
Moscow, Russia
Comrades, we really need to have Denon x4500 or x6500 tested. They sound so much better than Denon x3500 (which in turn measured here better than this x2200), but we need to see objective data. So please, if you happen to have one or are going to buy one - consider offering it to Amirm for testing.
