Do USB Audio Cables Make A Difference?
RayDunzl
Central Scrutinizer
Riverview FL
Ok.
I'll play.
Give me a solution for less than the $18.97 or so I spent and requires no more effort than to plug in both ends and hasn't required any further fiddling around since then (four years ago).
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
I don't know your architecture.
For this application, the architectural features of interest are USB Type A at PC to USB Type B at DAC
Sal1950
The Chicago Crusher
Central Fl
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
Central Scrutinizer
Riverview FL
DonH56
Monument, CO
Exhaustive research has proven to me that USB cables do indeed make a dramatic difference in the sound. When I pull the cable, the sound goes away. It comes back when I reinsert the cable.
Thomas savage
The Watchman
uk, taunton
You should publish these groundbreaking findings...
RayDunzl
Central Scrutinizer
Riverview FL
Had the question if these cables provide full grounding isolation? Reading the link I understand they do not transfer any power except internally for self-powering at both ends, but couldn't determine if the ground remains totally isolated? (ground loops).
If ground is isolated, is it still ground?
Sal1950
The Chicago Crusher
Central Fl
Yep, might be worth a AES White paper, tan might do in this case.
Hummm, sounds like a job for The Scrutinizer!
RayDunzl
Central Scrutinizer
Riverview FL
DonH56
Monument, CO
Having served in the past on the editorial team for a peer-reviewed (IEEE JSSC) magazine and seeing the posts above... No comment.
watchnerd
Seattle Area, USA
what are you talking about ground l00ps for, it uses frickin lasers, man!!
