Top of the list for the worst movie ever.what are you talking about ground l00ps for, it uses frickin lasers, man!!
Hi @amirm. The SMSL Sanskrit 6th that I bought cut corners in not providing a cable that includes a really cheap ferrite bead (choke), while any other audio equipment I have bought has had a ferrite bead/choke (even outside of the audio world it's quite unusual for cables not to have a ferrite bead). I have since exchanged the cable of my Sanskrit with the one Fiio included in my K5 and I didn't need since I don't have a docking DAC. Any differences the ferrite bead produces may be quite minor, but you mayor be the First one to demonstrate them if you measure them
new here ! i think nice place for my hobby, as new i want to contrib with my test on USB cables,Exhaustive research has proven to me that USB cables do indeed make a dramatic difference in the sound. When I pull the cable, the sound goes away. It comes back when I reinsert the cable.
You say that but I remember an article someone wrote with exactly those impressions for a SATA (hard disk) cable or was it Ethernet? Gray sounded cold and red nice and warm. Or something like that.Catching up on many of the interesting topics covered here before I joined!
Has anyone tested effect on sound imparted by the color of the insulating jacket? Blue cables sound cool, and red cables sound warm. (Just kidding - though I'd likely find something claiming this on some audiophile forums).
Welcome to forum! You read my mind about testing chokes on cables. I plan to do that test as well as wrapping cables with aluminum foil!
Maybe your SMSL Sanskrit is the only unit that passes EMC testing without an external ferrite bead i.e. the opposite of cutting corners!
Sometimes the only way a piece of equipment can pass EMC tests is if the manufacturer agrees to supply a cable with a ferrite bead...
For example, here is an extract from an article on how to pass EMC testing:
So a compact unit ends up with a huge, ugly ferrite in the cable.
yes the cables that come with topping devices are quite nice! Too bad they are too short for me to useYou're right, that sounds like the most likely reason. I can report back that I just received a Topping D30 today and the USB cable doesn't have a ferrite bead either, but I wouldn't dare think that it was a cost cutting measure, Oh my... I'm amazed how the USB cable in that unit is of great quality, feels better than any other USB cable I've got. So, I'm guessing it passes emissions tests without the choke.
Hello
Pretty interesting thread. I joined the forum just to leave a comment here
As i understand ALL dacs used in this test are powered though USB, correct?
I would love to see this tested on DACs that is not using USB power that would mean that the signal over the USB line is pure USB data and no 5V messing around
The bits can get lost, or confuse their order on the journey.I have seen some DAC manufacturers recommend USB cables be no longer than 1 meter.
