Hifiman Sundara Review (headphone)
This is a review and detailed measurements of the Hifiman Sundara planar magnetic open back headphone. It was kindly sent to me by one of their retailers, Apos Audio and costs US $349.
The Sundara looks elegant and no less so than higher up in the line from Hifiman:
The cups don't swivel. That, and being new made for slightly uncomfortable feeling around my ears. The weight is inline with other headphones in this class at 390 grams. The cup is round and has inside diameter of 59 mm and depth of 18 mm.
The included cord is short and comes with right angle connector. It has a nice (silicon?) insulator. It did not seem microphonic to me.
Note: The measurements you are about to see are preformed using standardized GRAS 45CA headphone measurement fixture. Headphone measurements require more interpretation than speaker tests and have more of a requirement for subjective testing as a result. In addition, comparison of measurements between different people performing it using different configurations requires fair bit of skill. So don't look for matching results. Focus on high level picture. Listening tests are performed using RME ADI-2 DAC and its headphone output.
Mounting the headphone on the test fixture was super easy requiring no manipulation to get left and right to match at dual frequencies.
Hifiman Sundara Measurements
As usual, we start with our stereo frequency response measurements:
I like the near compliance with preference curve form upper bass to lower treble. The former though as you can see, droops as many headphones do. The peaks above 5 kHz also exceed our target which you can better see in a relative graph:
There is a bit of shortfall around 2 kHz as well which I tend to like! No, it is not good that way but it means that once I compensate for it, it should open the sound more.
Distortion shows little unexpected other than something going on between 6 and 7 kHz:
This is much better than Hifiman Ananda:
Group delay shows the typical messiness we see in mid-frequencies which seems to have a role in (good) spatial effects:
Impedance is flat at 40 ohm meaning you need current more than voltage to drive the Sundara:
Efficiency is slightly below average:
Hifiman Sundara Listening Tests
I had been listening to my AKG K371 for a few hours before swapping it with Sundara. The difference was startling in how open and expansive the sound became with Sundara. Alas, I quickly realized there is no sub-bass being produced. And sound signature was a bit bright and over exaggerated at the top. So out came the EQ tool:
Oh wow! The transformation was dramatic. Sub-bass came into play like nobody's business. Even at lower volumes I could feel the nice vibrations in my head! :) The notch filter took care of the highs being exaggerated and a bit harsh. And the fine but broad filter around 2.1 kHz helped the spatial qualities improve even more. Overall tonality now was warm with tons of detail especially in string instruments. Very lovely.
As a verification, I asked my son to come over and without looking at the measurements and EQ, listen to the headphone plain and then with EQ I had built above. After about half hour of listening he said there was no sub-bass and the there was something missing in the sound. With EQ he found the sound to be much improved causing him to say he likes it. So good correlation with my findings.
We have had a checkered history with Hifiman so far with HE-6 performing very well and the Ananda, not so much. It is nice to discover that Sundara, despite its much lower price than either two, brings a competent implementation to the table. Objectively we miss the bass by a mile but otherwise, compliance to our target is very good. Distortion while not best in class, is kept much more under control than Ananda. Likely the smaller driver is able to be much more optimized here.
Without EQ, I would not be a buyer as I love my deep bass response and highs that are a bit more sedated. With EQ, the Sundara transforms beautifully providing excellent spatial effect with respect to instrument and channel separation while providing the deep bass response that I crave.
I am happy to give a strong recommendation to Hifiman Sundara with equalization.
  • Hifiman Sundara frequency response.zip
sweetchaos
The Curator
BC, Canada
To import this PEQ profile into 'Equalizer APO', use:
Preamp: -8.6 dB
Filter 1: ON LS Fc 50 Hz Gain 8.0 dB Q 1.0
Filter 2: ON PK Fc 2112 Hz Gain 2.5 dB Q 1.5
Filter 3: ON PK Fc 6300 Hz Gain -4.0 dB Q 4.0
Otherwise, see my PEQ guide.
For those who don't have PEQ-capable app, and want to use GEQs instead.
Preamp: -7.7db
32 7.2
64 1.0
125 -0.4
250 -0.2
500 -0.1
1000 -0.4
2000 2.5
4000 -0.5
8000 -2.0
16000 -0.1
Preamp: -7.0db
20 4.7
25 5.1
32 4.7
40 3.9
50 2.7
63 1.6
80 0.6
100 0.2
125 -0.0
160 -0.1
200 -0.1
250 -0.1
315 -0.1
400 -0.2
500 -0.1
630 -0.1
800 -0.1
1000 0.0
1250 0.2
1600 0.8
2000 2.0
2500 1.5
3150 0.4
4000 0.1
5000 -0.3
6300 -4.3
8000 -0.5
10000 -0.3
12500 -0.3
16000 -0.4
20000 -0.2
If you want to import into "Wavelet" (Android App):
GraphicEQ: 20 -0.2; 21 -0.2; 22 -0.2; 23 -0.2; 24 -0.2; 26 -0.2; 27 -0.2; 29 -0.2; 30 -0.2; 32 -0.2; 34 -0.2; 36 -0.4; 38 -0.7; 40 -1.0; 43 -1.4; 45 -1.7; 48 -2.1; 50 -2.4; 53 -2.8; 56 -3.2; 59 -3.5; 63 -3.9; 66 -4.2; 70 -4.5; 74 -4.7; 78 -5.0; 83 -5.2; 87 -5.3; 92 -5.5; 97 -5.6; 103 -5.8; 109 -5.9; 115 -6.0; 121 -6.0; 128 -6.1; 136 -6.1; 143 -6.2; 151 -6.2; 160 -6.2; 169 -6.3; 178 -6.3; 188 -6.3; 199 -6.3; 210 -6.3; 222 -6.3; 235 -6.4; 248 -6.4; 262 -6.4; 277 -6.4; 292 -6.4; 309 -6.4; 326 -6.4; 345 -6.4; 364 -6.4; 385 -6.4; 406 -6.4; 429 -6.4; 453 -6.4; 479 -6.4; 506 -6.4; 534 -6.3; 565 -6.3; 596 -6.3; 630 -6.3; 665 -6.3; 703 -6.3; 743 -6.3; 784 -6.2; 829 -6.2; 875 -6.2; 924 -6.1; 977 -6.1; 1032 -6.0; 1090 -6.0; 1151 -5.9; 1216 -5.8; 1284 -5.7; 1357 -5.6; 1433 -5.4; 1514 -5.2; 1599 -5.0; 1689 -4.7; 1784 -4.5; 1885 -4.2; 1991 -4.0; 2103 -4.0; 2221 -4.0; 2347 -4.2; 2479 -4.5; 2618 -4.7; 2766 -5.0; 2921 -5.3; 3086 -5.5; 3260 -5.7; 3443 -5.8; 3637 -6.0; 3842 -6.1; 4058 -6.2; 4287 -6.4; 4528 -6.6; 4783 -6.8; 5052 -7.1; 5337 -7.6; 5637 -8.4; 5955 -9.5; 6290 -10.2; 6644 -9.7; 7018 -8.6; 7414 -7.8; 7831 -7.3; 8272 -7.0; 8738 -6.8; 9230 -6.7; 9749 -6.6; 10298 -6.6; 10878 -6.6; 11490 -6.5; 12137 -6.5; 12821 -6.5; 13543 -6.5; 14305 -6.5; 15110 -6.4; 15961 -6.4; 16860 -6.4; 17809 -6.4; 18812 -6.4; 19871 -6.3
Otherwise, see my GEQ guide.
dfuller
I just don't understand Hifiman's product stack. Some of their stuff seems to be great, and some of it seems to be crap, and price has literally zero bearing on which is which.
Also - considering most planars seem to have a distortion spike somewhere in the presence region (and, if you look on a CSD waterfall plot, you'll see they ring pretty bad right around that same point), I wonder if maybe that's the resonance caused by the tensioning of the driver diaphragm and insufficient damping. Let me go find some measurements, I'll report back.
ETA: measurements from SBAF of the Monoprice Monolith M1060, another planar. Long presence region resonance tracks directly with a distortion spike at the same frequency as well as a frequency response spike.
GDK
Toronto
Clearly, I was looking forward to this. And while I thought there was a risk that the review was not positive given how the Ananda performed, I was not worried because it didn’t matter to me. I think these are amazing headphones, although I do prefer the Oratory1990 PEQ to Amir’s (sorry :facepalm:).
Anmol
May be it's my head's shape or some other effect, changing to dekoni pads changed how sundara sound with noticeable increase in bass and reduction in brightness.
Given how popular this headphone is, If there was a dekoni pad around suitable for he series, it would be interesting to see comparable data with hifiman pali pad vs dekoni on sundara
Many thanks
KiyPhi
Good to see this review. I feel like it should be noted that the lower end performance on these depends on the seal and it will vary from head to head. I get a nice low rumble with these naturally. Others have measured the on head to extend down to 20Hz no issue. These have been my go to recommendation for years and are a great headphone and take to EQ like a champ. Only drawback is, as Amir noted, the lack of swivel but you can swap headbands to fix this if you really want to.
vkvedam
Coventry, UK
Excellent! I expected it to get the highest recommendation.
GWolfman
Thanks! Do planar magnetic headphones have a difference (sense of) sound compared to traditional headphones? Was wondering if they are worth a try. HD6XX are my most used at the moment.
frix
Nice to see there are more reasonable priced great performing headphones. Though what is it with hifiman and cup swifel? Why hifiman? Why? Was the swifel a weak point in former designs? And instead of improving they just killed it?
luft262
Phoenix
Thank you Amir! These are my daily drivers, along with the JDS Atom DAC and AMP. I love these headphones and I'm glad the science backs it up. I'm going to try your EQ settings out. I generally use the stock EQ in Wavelet for my cans, but I'm excited to play with the EQ a little! What audiophiles aren't using EQ these days anyway???
P.S. Thanks for the Ananda review too. I'll stick with my Sundaras or hold out for the Arya review!
paolomo
Germany
Thanks for the detailed review! I like mine, a lot. Peak here, shelf there, and they shine, that was my first successful EQ attempt ever. My impression is that a pair of Sundara and a random pick from the HD 600/650/660s/6XX family can make a lot of people happy.
(ok, a random pick or two :D )
Maiky76
French, living in China
Here are some thoughts about the EQ.
Notes about the EQ design:
  • The average L/R is used to calculate the score.
  • The resolution is 12 points per octave interpolated from the raw data (provided by @amirm)
  • A Genetic Algorithm is used to optimize the EQ.
  • The EQ Score is designed to MAXIMIZE the Score WHILE fitting the Harman target curve with a fixed complexity.
    This will avoid weird results if one only optimizes for the Score.
    It will probably flatten the Error regression doing so, the tonal balance should be more neutral.
  • The EQs are starting point and may require tuning (certainly at LF).
  • The range above 10kHz is usually not EQed unless smooth enough to do so.
  • I am using PEQ (PK) as from my experience the definition is more consistent across different DSP/platform implementations than shelves.
  • With some HP/amp combo the boosts and preamp gain need to be carefully considered to avoid issues
Excellent L/R match.
I have generated two EQ, the APO config files are attached.
Score Flat@ HF: default Harman curve
Score no EQ: 85.4
Score Armirm: 87.1
Score with EQ: 88.3
Code:
Hifiman Sundara APO EQ Score Flat@HF 96000Hz
April162021-130912
Preamp: -7.6 dB
Filter 1: ON PK Fc 25.8 Hz Gain 6 dB Q 0.69
Filter 2: ON PK Fc 223 Hz Gain -2.17 dB Q 0.76
Filter 3: ON PK Fc 928 Hz Gain -1.62 dB Q 1.72
Filter 4: ON PK Fc 2082 Hz Gain 1.67 dB Q 2.52
Filter 5: ON PK Fc 5302 Hz Gain 1.94 dB Q 4.55
Filter 6: ON PK Fc 6275 Hz Gain -4 dB Q 8
Filter 7: ON PK Fc 8500 Hz Gain -1.38 dB Q 7.76
Filter 8: ON PK Fc 13645 Hz Gain -7.75 dB Q 4.7
Score -1.5dB@ HF: default Harman curve decreased by 1.5dB at HF. looks closer to the initial response
Score no EQ: 84.0
Score Armirm: 82.4
Score with EQ: 92.8
Code:
Hifiman Sundara APO EQ Score -1.5dB@HF 96000Hz
April162021-130342
Preamp: -8 dB
Filter 1: ON PK Fc 29.5 Hz Gain 8 dB Q 0.88
Filter 2: ON PK Fc 941 Hz Gain -0.95 dB Q 6.16
Filter 3: ON PK Fc 2072 Hz Gain 2.18 dB Q 4.23
Filter 4: ON PK Fc 6301 Hz Gain -5.45 dB Q 7.48
Filter 5: ON PK Fc 7423 Hz Gain 2.42 dB Q 0.93
Filter 6: ON PK Fc 8500 Hz Gain -2.68 dB Q 7.76
Filter 7: ON PK Fc 13516 Hz Gain -8.92 dB Q 4.71
  • Hifiman Sundara APO EQ Score Flat@HF 96000Hz.txt
  • Hifiman Sundara APO EQ Score -1.5dB@HF 96000Hz.txt
