Impulse Response
RayDunzl
Central Scrutinizer
Riverview FL
Presented for your amusement:
Single Full Scale Bit sent through speakers, playback recorded in Audacity:
Impulse response calculated from a ten second 10-24kHz sweep tone (three weeks ago) in REW:
Well, I am amused.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Looks like you have a one second delay through the system? Is that due to fir filters/convolution you are using?
The absolute time in the recording has no meaning, though the duration should be accurate.
I just moved the peak to one-second on the display above.
Here are 4 recordings showing what I get to work with.
First track is source. One second silence (record settling time) then the full-scale bit then more silence. Not perfect, but free, and useful.
The recorded data comes "before" the source data in this instance. Sometimes it comes later.
The MiniDSP has 6144 taps, and AcourateDRC centers its calculated impulse around tap 3072, so, 1/48000 * 3072 = 0.064s filter delay (I guess. Or is it 0.128s?). It may be noticeable with video, but just barely.
Here's 400 samples of the filter data:
Blumlein 88
You act as if there is some connection between math and physics and this really works.
DonH56
Monument, CO
I hate reading threads like this. Makes me realize how inadequate my impulse responses are. I have solved that problem, however; I no longer measure them. :)
The other interesting thing, given these are really outstanding responses, is that little tiny response blip at about 1 ms. It is about 5% if I read it rightly, and looks totally negligible. However, 5% is -26 dB, and yet we worry about DAC artifacts 100+ dB down. Hmph.
Oh, the delay (latency) is normally from initial input to first output at the other end, so 128 us. "Centering" the response at the center tap allows the filter to manipulate the output using pre- and post-emphasis for correction (acting on samples before and after the main cursor/signal).
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
I'm somewhat surprised it works as well as it seems to.
Somewhere else, I posted a similar comparison between a calculated Step Response and a recorded 10Hz signal. All but identical...
My later work history included plenty of taking the output of the Telco Software/Firmware/Hardware Design and Development Engineers, thinking to myself "Oh yeah? Well, we'll see about that!", pushing the button, and figuring out what really happened, and whether or not it met the design spec or if we could otherwise slide it past the customer during their acceptance testing.
That mind-set has carried over into my Golden Years.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
tomelex
So called Midwest, USA
thanks man, interesting stuff.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
restorer-john
Basically, your single impulse was generated digitally and sent through what type of D/A?
If it has an FIR oversampling filter (likely), it has become something very interesting by the time it has been through the amplifier, loudspeaker, microphone and A/D...
Here is a single impulse, 1 sample 44/16 at 0dBFS on the world's first CD player, the Sony CDP-101: (500us/div)
This is what a non-oversampled, analogue 9th order Tchebyscheff (brickwall) filter looks like on one of my actual CDP-101s (tested the other day actually). Looks rather familiar?
Just for fun, here's the 100Hz square wave response:
Here's a typical impulse from a OS player with excellent D/As and a superb measured performance (Marantz PMD-325 professional)- note scales are not the same so it looks better than it is. (1ms/div)
Zoomed just a little:
So, sending an impulse that looks like the one above through amp/speakers/microphone/A-D results in the top trace.
I put it to you all, what have we gained in 35 years? :)
Wombat
Australia
Focus too much on minutiae and its relevance to the bigger picture can be overlooked.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
One full-scale bit created in Audacity sent through a Benchmark DAC2.
The DAC has a symmetrical impulse response (what is that, linear filter?)
I don't measure much electrical here.
Most of what I present as "measurements" is what a mic at the listening position picks up. I want the "in air" to correspond to the "recorded signal". What happens in the middle - Room Correction IIR and FIR filters modifying the digits thereby modifying the electrical signal sent to the speakers is of less interest to me.
Reasons:
Can't hear electrons
Don't have a digital scope or high-high-quality ADC
Do have a 25 foot cable to preamp output to PC but it is noisy
DSP Room Correction (niniDSP OpenDRC-DI and AcourateDRC) whacks out the electrical frequency response and phase from pristine textbook flat, so electrical signals become "don't care".
Preamp Output Frequency Response examples (electrical) with and without DRC in the path (with a 25 foot cable to PC) for MartinLogan:
Signal Phase:
For JBL LSR 308:
Phase:
The ability (at home) to modify music on-the-fly noiselessly to reduce audible problems presented by the speakers and the room at low to no incremental cost with all the digital toys created for us to play with.
I couldn't do that at home in 1983.
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
Here's some electrical square wave - around 200hz in the sweep:
25 foot noisy cable to PC, some amplification applied to enlarge the received signal (makes it look more noisy)
RayDunzl
RayDunzl
Central Scrutinizer
Riverview FL
