Jitter: Seconds to dB?
DonH56
Monument, CO
For SNR the equation is: SNR (dB) ~= -20 * log10(2 * pi * fin * tj) where pi = 3.14159..., fin = input frequency (Hz), and tj = jitter in time (s pp)
This is for uncorrelated random Gaussian jitter, assumes a pure single-tone sinusoidal input, and no other error sources. Note that the sampling rate drops out of the SNR equation.
Real jitter is much more complicated, natch, but this simple formula correlates very well to the data presented in the plots in the Jitter 102 thread. It is a little off but close enough for general use (ADI uses it in some of their white papers).
Quantization noise and other things may limit the performance of a DAC (or ADC, or DSO).
HTH - Don
j_j
Audio Luminary
My kitchen or my listening room.
You ask a question that only has half of the information. The other half is "what is the input signal". The higher the derivative of the input signal, the more error results from a given jitter.
You also need to know the frequency content of the jitter.
