Hello. I use the same power supply, that have two +5volt exit, for supply raspberry and khadas.
I use this cable, that divide signal from power, then the power of to khadas from power supply and not from raspberry.
https://www.audiophonics.fr/fr/cabl...our-alimentation-et-donnees-20cm-p-14052.html
The problem is that the sound have high distortion.
To resolving, I must disconnect khadas manually from power and reconnect it, then sounds is good.
Why ?
Thanks
Why ?
Thanks
