Marantz AVR 7701 DAC measurements
Blumlein 88
These are measurements of the Marantz AVR 7701 pre/pro I purchased second hand from Sal. It was superbly packaged and in great condition. Thanks Sal.
The original MSRP was $1699 for this unit in 2013. It has Audyssey which I may eventually report on. And of course a plentitude of other features.
One could perhaps spend weeks testing all aspects of a modern multi-channel preamp. I did a few spot checks of things and mostly this is a test of the basic analog and DAC capabilities of the device.
First we’ll start with the customary J-test done with a 32K FFT. (maybe Amir will use more bins with his new AP unit).
The central 12 khz tone is nice and tight with little spread in the base. So little random jitter around the central tone. But there are several spurious signals here. These are caused by periodic jitter. Unusually there appears little relationship between the spacing. However the spacing is consistent around any high level tone as will be seen in sweeps. The worst is at a level of - 106 dbFS with the others -115 dbFS or lower. So I doubt they’ll be heard.
There are a string of power supply harmonics from 60 hz to nearly 1 khz. The highest is -103 db at 120 hz with all the others several decibels lower. So probably not an audible problem.
The noise floor looks to be somewhere near -100 db and tested out at 103 db for SNR and 107 db dynamic range. So somewhere at or above 17 bits worth.
Finally there is a wrinkle in the noise floor I’ve shown as an imaging artifact. The output filter reacts to the signal and reflects higher frequencies back into the audio band. This one is related to another curiosity. It appears the signal is filtered with a roll off at 22,050 hz as if this were a 44.1 khz sample rate instead of 48 khz. And the position of the imaging artifacts also fit that idea. Is one digital filter implemented for cost savings? Was it a mistake? I need to test at some other sample rates and see what happens.
Channel separation (not shown) was more than 95 db at and below 1 khz, but gradually rises until it is only 65 db at 20 khz. It is about 75 db at 5 khz.
Here is the 1 khz tone for reference. Several harmonics the highest being the 2nd at -94 db or .002 %.
The 18+19 khz IMD results are also good with the 1khz difference being - 106 db and everything else is lower. There are plenty of spurious tones for that grassy look in the noise floor, but all very low in level.
Other things worth discussing:
These measures were taken with Direct mode. All processing and surround formats are bypassed. Only direct digital input and this should tell you the capabilities of the DAC and basic analog circuitry. However, Marantz included the PURE DIRECT MODE. Pure Direct turns off front panel displays and all video circuitry so only audio parts are active and powered. Touted as giving maximum sound quality with quieter noise floors and lower jitter. I tried it, and all the measurements are exactly the same. So much for Pure Direct and pollution by those video circuits.
With 0 dbFS input and volume set to 0 db the output is a touch over 3 volts where these measurements were taken. You can turn the volume up to +18 db. With max level digital input the distortion begins to rise, but not very much. It is still .005% at 4.5 volts. Distortion has risen to 1 or 2% by +12 db and 6 volts out. It puts out 16 volts at max volume, and above +12 db the increase in voltage is less than it should be. Also it appears to be an analog amplification. If you feed it some lower level digital signals and turn the volume up distortions stays very low until you pass 4.5 volts output even if volume controls are +18 db. So useful for unusually low sound levels. Will not be harmful if all you are doing is turning it up to hear at normal levels.
Here are a couple of spectrograms. In this case the background goes to gray at -100 dbFS. Anything above -100 dbFS will leave a trace. Left is single tone sweep and right is twin tone IMD sweep. You see 2nd harmonic at -94 dbFS and not much else.
Next are the same sweeps with the floor of the spectrogram lowered to -120 dbFS.
You see more of the harmonic distortion that lies below -100 dbFS and some of the imaging artifacts as well as spurious tones apparently caused by some periodic jitter corrupting the clock.
Finally a spectrogram of the low level linearity. Here the background goes to dark gray at -150 dbFS. The upper is the Marantz 7701 and for reference is the test file below it. The vertical green bars are just markers. The first marker is after the 16th bit, the second after the 20th bit and the third is after the 24th bit. The first signal is the 10th bit or -60.2 dbFS. Ignore the line at 16 khz as that is present in the ADC when connected to my Macbook Pro.
Using my convention of calling it when the level is 1 db off from the correct level this unit manages the 20th bit where it is .2 db off. It is 3 db too high for the 21st bit. Using Amir’s .1 db error limits the 16th bit is where this happens. But the following 4 bits are all close with less than .5 db error until the 21st bit.
So just as a DAC, this isn't up to some of the better DACs around though it is hardly terrible. This also gives us a point of comparison for any future multi-channel gear that gets measured. It should be very good quality for video, and likely wouldn't harm any music listened to over that system.
t129
Was this with HDMI input or SPDIF? If HDMI, it seems this would be verging on great performance (referencing Amir's A Deep Dive into HDMI Audio Performance) at least on the jitter.
USB solves the issues for my need and applications, but it just seems absurd that hdmi is, I assume purely on the anecdotal information, often so badly implemented.
XpanD
Netherlands
Oh wow, thanks for the detailed measurements.
I've got a few Marantz processors on the shortlist for when my M-DAC eventually dies (it's starting to get flaky, "no comms" errors or blank screens), but there's so little good info out for a lot of these multi-channel devices. This seems quite promising!
Timbo2
USA
Thanks. I remember when we discussing AVRs. How do you like the UI?
Confusing or ok once you get used to it?
Sal1950
The Chicago Crusher
Central Fl
Thanks for the detailed report D, great job. You could almost call the darn thing transparent in the Direct mode. ;)
Glad its working out for you.
Don't know how Blumlien88 feels about it and I'm not sure what part of the UI you refer to.
The general setup/control menu can be a bit confusing but that's true about all these heavily complicated multich units. Compounded by the user manuals being written by folks for whom English isn't their first language. But it really is going to be very dependent on the owners prior experience. I didn't have any real issues but finding some info in the manual can be time consuming and at time frustrating.
The Audyssey UI is very hand holding and most anyone should be able to walk right thru it.
Blumlein 88
Blumlein 88
I largely agree with Sal's assessment. The manual is the weak link here. It is very poorly organized, necessarily large, and takes lots of effort to glean information from.
Audyssey does hold your hand and is easy. The rest of the unit, while complicated isn't too bad and I'm adapting pretty quickly. Like all such units each has its own terms. You have to figure out what the special terms are actually saying.
As a counterpoint, a Denon AVR from a few years ago was given to me because a friend couldn't get it to work reliably and hated it. He purchased it from the original owners who sold it cheap because they couldn't really get it to work. I hate it and don't care to use it. I'm not the most wonderful user of complicated gear, but I've managed to use some fairly complex stuff over the years. I often get asked to help with complex gear by people I know. I don't know what the people behind that Denon were thinking or how. Even more confusing is Denon is really the company who makes Marantz. And Denon's from a few years earlier were very good. The 7701 is pretty decent in terms of UI in my opinion.
Blumlein 88
Blumlein 88
I used a Musical Fidelity V-link USB to SPDIF converter to feed the Marantz via coaxial digital input. I do have a laptop with HDMI output. I won't promise, but I'll see about running some basic measures over HDMI and see if it differs much. I'll post some comparative results.
Sal1950
The Chicago Crusher
Central Fl
I for one welcome AVR discussion.
Why not, the science side weighs equally well with multich gear as anything. We have quite a few multich enthusiasts here including Kal Rubinson of Stereophile.
Blumlein 88
Blumlein 88
Okay, I checked the HDMI input. Yesterday I fed digital coax into the 7701 for testing. Today I fed HDMI out of my Lenovo laptop.
Here is the 12 khz Jtest signal over HDMI.
Still a very tight 12 khz tone with nearly no spreading at the base of the tone. So not all HDMI is a jitter factory exactly. The various other tones at very low level are different. The highest couple are -106 db again, but in different spots. Also unlike the coax the tones are spread symmetrically with respect to 12 khz. Most are -115 dbFS or less in level. There are a few more of them than coax. While not a pristine jitter result it isn't terrible.
Here is a graph with HDMI in cyan and coax in magenta superimposed on it.
Next thinking maybe it would make more difference with HDMI I tried it with Pure Direct. Remember it turns off the displays on the face of the AV 7701 and turns off video circuitry to lower noise and jitter. In this case it made a difference. A bad one. It added some hash around the central 12 khz tone that otherwise isn't there. It also widened the spacing slightly of the jitter related side bands compared to simply Direct input.
Other than that I checked THD and IMD with no changes at all. Noise floor was not appreciably different (less than a db change). Power supply artifacts looked identical in level and number of harmonics showing up. So HDMI or coax look close to identical as long as you leave Pure Direct off.
Sal1950
The Chicago Crusher
Central Fl
Thanks D for the extra work. A good look inside a mid-level pre/pro and quite revealing of a high quality result.
Trdat
Yerevan "Sydney Born"
Blumlein, I am trying to untangle your write up above, I to have a Marantz but the 7005 and according to "Soundandvision.com" both the 7005 and 7701 measure very similarly. Unfortunately the tests are not very thorough to be able to interpret for an amatuer. Anyway, with further reading from your results and more from Amir's measurements on the 7705 and 8805 I am starting to understand what is going on.
To confirm a few points, when you say "if you feed a lower level signal and turn up the volume distortion stays low until you pass 4.5 volts." How can you not pass 4.5 volts if you turn up the volume? Doesn't the volume coincide with the Volts?
According to Amir, up to -11db volume is where abouts 4 volts is. Is this the same on the 7701? How can we know when we get to 4 volts? Is it just with the volume?
Blumlein 88
Blumlein 88
Sorry, my wording was confusing.
This unit has some analog gain. If you set to 0 db on volume and feed it max digital signal you get about 3 volts out. I measured it with another DAC for which I knew its input sensitivity. I double checked with a multimeter which has 20 khz response on the AC low level input.
Now I can add analog gain above this point, which I did, the input is still a clean input from a digital source. The output rises as I turn up the volume and at higher levels the distortion in the analog circuit of the 7701 begins to distort eventually. I measured this using an ADC where I reduced the input levels so as not to overload the ADC. That capability is build into the ADC I was using. So with additional analog gain from the 7701 it stayed relatively clean even at 4.5 volts. As gain was pushed higher which meant output voltage increased the distortion began to rise enough to matter.
The 7701 can have the volume displayed in one of two ways. In one method it is 0-98 (which isn't a db scale). The other is -79.5db to +18 db. I was using the latter as it is a db scale. So my assumption is Amir had volume reference set the other way on the other Marantz unit, and without looking into the manual I don't know if it was 0-98 or some other scale on the other Marantz. It is also possible Amir was using the db scale and the other unit has a different amount of analog gain than the 7701.
Trdat
I am hazarding a guess when you say max digital signal means volume from computer?
This was the missing link, I had no idea whatsover that the voume scale could be changed on the Marantz. Okay now its relatively simple to understand. But I have one question, my current amp is .775 input sensitivity which if I understand correctly is common for PA amps. Now, if around 0db or on the absolute scale 75 is around 2 volts(lets say approximately) then if I reach that point I have passed the maximum input needed to reach maximum volume right? But its easy to pass that point and the volume keeps increasing when i pass that point I know that the amp must be clipping but how much more can the amp increase in volume if the input sensitivity is .775? Just trying to understand what is happening....?
Blumlein 88
Blumlein 88
Well, using a music signal the max points may be beyond .775 and may momentarily clip your amp. Yet the overall average level will be below clipping. Some people are more sensitive to clipping than others. Your amp may also have some momentary headroom above .775 where it can manage to reproduce a short transient without clipping, but it couldn't do that with a steady test tone at that level. That dynamic headroom varies between various designs. However if you turn volume up enough beyond the reference point of .775 volts you'll get considerable clipping which you'll hear.
Trdat
Also, do I lose SINAD when I turn surround mode on? I mean when I add the rear channel(even without connecting speakers) it feels like I'm losing some trasparecny in the front lef/right. On paper do we know if this is what happens?
