Minidsp Flex Review (Audio DSP)
Rate this product:
    Votes: 4 0.7%
    Votes: 16 2.8%
    Votes: 117 20.5%
    Votes: 435 76.0%
This is a review and detailed measurement of the Minidsp Flex audio signal processor. It was sent to me by the company and costs US $475 for unbalanced and $550 for balanced that I tested.
Flex borrows the interface from SHD and puts it in a compact package. Seeing how I really liked that interface with nice volume control, this is a very good move.
Back panel shows why this product is so useful:
Minidsp Flex Review Back Panel Power Supply DSP Audio Processor Balanced.jpg
Not only do you have a suite of digital input but also analog. More importantly, you can rote any input to any output and apply crossover, parametric EQ filters and compression. The software interface is mostly intuitive except for channel routing which required a bit of looking around.
The supplied remote control allows you to eliminate any need for a preamplifier and drive a power amp directly.
Minidsp Flex DAC Measurements
I alternated between Coax S/PDIF input and USB although performance is the same in both. Here is our dashboard:
OK, I was not ready for this. A multifunction device with DSP that has a SINAD (relative sum of distortion and noise) to rival and outperform many dedicated DACs?
Among its own category which is a mix of DSP and AV receivers and processors it sets a new high bar:
First of its kind to land in the blue "excellent" category!
Above was with the volume at -0.5 dB. There is a bit more performance if you set it to 0:
Dynamic range is very respectable for this class:
There is something holding IMD distortion back though:
This causes the same limiting in multitone:
JItter test shows some interference but they are at such ridiculously low level that bother the eye far more than any ear could ever detect them:
DAC filter is the typical default "lazy" ones in DAC chips:
This hurts THD+N versus frequency a bit but the outcome is still good:
Minidsp Flex Measurements THD+N vs frequency DSP Audio Processor Balanced.png
Linearity is excellent:
Minidsp Flex Analog Input Measurements
Some people have an analog only path (e.g. for turntables) and would still want to implement active speakers and/or equalization for room modes. Let's see how we do here:
I am amazed once again! End to end performance this good? Remember this is the performance of ADC and DAC combined. And we still manage to have distortion at < -110 dB (18+ bits).
Dynamic range suffers a bit naturally but still, quite good:
I was relieved to see wide and flat response:
Minidsp Flex Measurements Analog In Frequency Response DSP Audio Processor Balanced.png
So unlike many AV products that resample everything to 48 kHz, here we have end to end sample rate of 96 kHz (my guess). Bandwidth is in excess of 35 kHz.
Crosstalk was superb:
Minidsp Flex Measurements Analog In Crosstalk DSP Audio Processor Balanced.png
This is better than countless stand-alone preamps!
THD+N vs frequency again shows no frequency dependence:
Minidsp Flex Measurements Analog In THD+N vs frequency DSP Audio Processor Balanced.png
IMD performance is again limited by DAC performance:
EDIT: Post review question was raised about performance of channels 3 and 4. Here is that dashboard:
As you see, performance is just as excellent as channels 1 and 2.
Another question was performance drop when using RCA input to TRS balanced adapter:
Minidsp Flex Measurements Analog In RCA to TRS DSP Audio Processor Balanced.png
This is definitely the case. That said, highest distortion component is at -96 dB which is the same as 16 bit audio dynamic range. This is well above what analog sources such as LP can achieve. So I would not worry about it if this is the configuration.
What a nice combination of functionality, usability and performance! As with many DAC companies, it is clearly Minidsp has put strong focus on chasing away sources of noise and distortion. Yes, there is some work left to do with intermodulation distortion but other than that, measurement after measurement put a smile on my face. All AV processor and receiver companies lose any excuses they have for not providing this level of performance seeing how the Flex also implements various signal processing modules.
It is my pleasure to highly recommend Minidsp Flex audio signal processor, DAC and ADC. You made my day!
Neddy
Wisconsin
Thank you, esp for the analog in/out measurements. Will be ordering as soon as I can, to replace the Venu 360.
voodooless
Netherlands
Why is this thing cathegorized as AV processor? It’s just a DAC+DSP.
Did you also test the second output? People seem to have meassured significantly worse performance.
Since it only brings 16 bit performance, I voted “fine”.
Tangband
Sweden
This is a review and detailed measurement of the Minidsp Flex audio signal processor. It was sent to me by the company and costs US $475.
Wow ! Finally a highend measuring dsp-crossover at a very good price for the DIY:er . :)
Combine this with tpa 3251/3255 modules inside the loudspeakers, you can build really good ones for not much money.
respice finem
SOTA product at a relatively low price.
One thing I don't understand: DIRAC is an option, but while the USB will be for the PC interface, where to connect the measurement mic? To the PC itself, probably?
Tangband
Sweden
No, its much more than a dac - its a dsp two-way digital crossover as well, and you can aparently use USB digital input from a computer as sound source . This unit uses a XMOS at the USB input. The future for highend performance at normal prices looks good.:)
  • Processor: 32-bit floating-point 400MHz Analog Devices SHARC DSP
  • Multi-Core USB Audio processor (XMOS)
  • Bluetooth streaming: LDAC™/aptX™ HD/aptX™/AAC/SBC
  • Optional upgrade to Dirac Live® 3.x Digital Room Correction, Full Range Room Correction (20~20kHz)
  • Audiophile performance (SINAD
  • Inputs: Stereo digital (USB Audio/SPDIF/Optical/Bluetooth), stereo analog (Unbalanced RCA)
  • Flexible Output versions: Unbalanced (RCA), Balanced (TRS), Digital (Future)
  • USB audio recording feature (4xCH processed output via USB audio to record inputs, e.g. Vinyl)
  • White/Black OLED front panel controller with IR control
Blew
Sydney, Australia
The manual and specs state 96KHz without Dirac, but 48KHz with Dirac.
BoredErica
USA
Let's see, how does this compare to Motu UL5?
Well, UL5 has more inputs/outputs + ADC. It has less distortions overall and higher output level for special amps. Flex has no ESS IMD hump and 3.5db higher sinad at 2v? It has a remote. Extra charge for balanced Flex + $25 shipping but no tax for me. Totals to $71.8 cheaper than UL5 but still on the hook for ADC. (Flex is in stock, UL5 still MIA.)
Flex has Bluetooth streaming still while UL5 does not. If you're buying DSP there's not much difference and Flex is just another dac. If not then there's another difference.
Hmm. At this point I'd be very hard pressed to hear a difference between this or UL5 even in pretty extreme circumstances but if I had to pick noise vs distortion I think I'm still going to go with less noise? That $72 cheaper price tag is really actually higher than Motu for me since I still need ADC (and extra devices in my room) but that remote is cool.
Potential customs fee at the door for minidsp?
Am I missing something?
voodooless
Netherlands
Yeah, like I said, it’s a DAC + DSP.. sure it also has analog inputs. But this thing is not an replacement for an AV processor as the grouping would indicate.
By the same reasoning the $20 adau1701 DSP board should be in the list as well.
Robbo99999
My take on this product is that it's a useful high end way of applying DSP/EQ "in hardware" rather than those that prefer or are able to implement it in software at the playback source - the usefulness of that is debateable depending on use case and personal preference, but as a poster pointed out earlier it's not really a replacement for an AV home theatre product.
martijn86
The Netherlands
This was the one I've been waiting for since the announcement! Thanks for reviewing it this fast. The result is even better than expected, this is a brilliant piece of kit!
Whoooo. Hyped, hyped, hyped.
Edit: I have one question before I pre-order. I don't use long cable runs. Is there any advantage to the higher output voltage of the balanced version? Otherwise I see no reason not to get the RCA version for home use.
Newman
No USB input? Can't be used as a USB DAC with extras?
