Monoprice Monolith THX 887 Balance Headphone Amp: New Champ?
This is a review and detailed measurements of the brand new Monolith Balanced Headphone Amplifier using THX AAA 887 technology. It was kindly sent to me a couple of days ago prior to its official unveiling on September 10th. It costs US $399.99 and is slated for general release on October 27th.
The Monolith is a direct attack on Massdrop THX AAA 789, aiming to better its performance while keeping feature set essentially the same. You can tell that from the overall design:
As Avid readers of the forum know, there are now three headphone amplifiers that stand alone as the best of the best: the JDS Labs Atom, the Massdrop THX AAA 789 and Benchmark HPA4. The Atom is great but is not balanced (input or output). The massdrop is but availability has been quite poor. The HPA4 is superb but very expensive. So having more options here is good and that is what we have.
The controls are familiar to anyone who has seen the Massdrop THX AAA 789. Three gain settings, jacks for XLR, 1/4 and 3.5 mm headphone jacks. And an input selector. The power button feels better than the one on Massdrop.
The back panel is as you expect:
Monoprice Monolith THX AAA 887 Headphone Amplifier Back Panel Audio Review.jpg
As is the 24 volt "laptop" style external power supply.
The Massdrop THX AAA 789 set a very high bar. Is it possible that Monoprice can exceed that? The number "887" may give you a clue as to them getting there. Don't go looking for that on THX website. It was an informal designation that was created just for this unit. To wit, official units will not have those numbers on it.
The unit I received for testing is the limited production run. I am told it is representative of the retail products as manufacturing ramps up.
Let's get into the measurements as that is what you are all here for.
Headphone Amplifier Measurements
I must say I was not prepared for what unfolded in front of my eyes:
Monoprice Monolith THX AAA 887 Headphone Amplifier  Unbalanced Audio Measurements.png
This is stunning level of performance. Distortion levels are at or below -140 dB! SINAD is therefore determined by noise levels of the Monolith but also my analyzer. As it is, it matches the Benchmark HPA4 in that department:
That is 2 dB better than Massdrop THX 789. From here on, I was crossing fingers that it would maintain this lead throughout the rest of the measurements.
Signal to noise ratio at 4 volts input and output was exemplary at 123 dB:
Monoprice Monolith THX AAA 887 Headphone Amplifier Unbalanced Unity Gain SNR Audio Measurements.png
Dialing the output way down using the volume control to assess noise level for very sensitive IEMs we get better than 92 dB:
Again, we have a 2 dB advantage over Massdrop.
Let's look at intermodulation distortion relative to level across all three gain settings:
Monoprice Monolith THX AAA 887 Headphone Amplifier Unbalanced IMD vs Level Audio Measurements.png
A bit of a jungle in there despite me zooming in. Summarizing, the Monolith THX 887 maintains a few dB lead in noise and distortion department (solid lines).
We can see that more clearly with THD+N versus power using 300 ohm:
Monoprice Monolith THX AAA 887 Headphone Amplifier  Unbalanced Power vs Distortion 300 ohm Aud...png
Neck and neck on power but slightly lower noise. Similar story exists at 33 ohm load:
Monoprice Monolith THX AAA 887 Headphone Amplifier Unbalanced Power vs Distortion 33 ohm Audio...png
Switching to a balanced 50 ohm load we get:
Monoprice Monolith THX AAA 887 Headphone Amplifier balanced Power into 50 ohm Audio Measurements.png
Here the performance gap is a bit larger. And with nearly 4 watts of power on tap, you should be able to drive just about any headphone.
Frequency response is as flat as you can get:
Monoprice Monolith THX AAA 887 Headphone Amplifier Unbalanced Frequency Response Audio Measure...png
Channel balance shows some variations:
Monoprice Monolith THX AAA 887 Headphone Amplifier balanced Channel Imbalance Audio Measurements.png
Given the very low gain setting, I don't think in practice it will be an issue. The Benchmark HPA4 is the king of hill here if you want perfect channel match.
Output impedance is comfortably low:
My setup has close to a 1 ohm impedance of its own so the actual impedance is probably close to 0.4 ohm.
Headphone Listening Tests
I tested the Monolith THX Balanced THX Amp using my Sennheiser HD-650 using both 1/4 inch jack and "balanced" XLR. I had no need to go beyond middle gain setting. No matter how much I turned up the volume, there was zero hint of any kind of distortion. Fidelity was exceptional. With XLR connection and highest gain, you get scary loud so there is plenty of headroom here for higher impedance headphones.
I then switched to Drop Mrspeakers Ether CX headphones. Despite the very low impedance of these headphones (around 25 ohm), there was no issues whatsoever driving them. Dynamics were excellent and nothing between your music and the headphones.
I play the same tracks for headphone testing. Having heard them hundreds of times, I am sick of them so usually stop pretty quickly. Not this time. The fidelity was so good that I kept the amp running for the rest of the evening.
There is not one subjective flaw I can identify with this amplifier.
I did not think it would be possible to build a mid-priced headphone amplifier and beat the Massdrop THX AAA 789. It is clear that the Monolith team managed to go against the tide and produce even a better headphone amplifier. Both subjectively and objectively, the "Monolith by Monoprice THX AAA Balanced Headphone Amplifier featuring THX AAA 887 Technology" (yes that is the official name) beats the Massdrop offering. Mind you, there is not much room left to squeeze one up there but they did. It is like beating the world record holder in Olympics.
Needless to say, it is my absolute pleasure to recommend the Monolith THX AAA Balanced headphone amplifier. It delighted me to see a company dedicated to absolute excellence and full transparency to our sources and content. This is a type of product you buy once and you are done. It made me happy just testing it!
Thinking about needing to buy more test gear to handle the broader set of products we are testing. So please support us by donating using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Merkurio
As you said, the best part is the apparent availability compared to the Massdrop version, so more people can enjoy great level of performance without waiting so long (and possibly that forces Massdrop to regulate the stock of their model).
VintageFlanker
Paris
BTW, the product listing is already on Monoprice website: https://www.monoprice.com/product?p_id=39359
Availability: 10/27/2019. Hope this won't became a never-available product as the 789, and will ship to EU. :confused:
Edit: even worse: pushed back to 11/26/2019...
Aw man. Should I cancel my THX AAA 789 order ? Awesome results.
Probably no audible difference. Both are State of The Art at the same price. Design comes to personal preference. And the main factor will be availability.
AnalogDE
California
It's comes out ~2 weeks before the next batch of THX AAA 789's... I'll go with whatever comes first.
The designs look pretty much the same, same front/back panel layout...
Amir, any quality differences on the connectors/knobs etc between this and the 789?
Ceburaska
Gloucestershire, England
Maybe buy something that’s actually available!
Do these thx products get made in batches of one?
Reviewing them seems mildly pointless as no one can actually buy them.
I want to put them side by side and play again. But from memory, the power button is more solid. On the Massdrop one feels loose. I also thought the volume control felt better. But this one I need to double check.
Ceburaska
I am hoping that the availability will be much better here because Monoprice has far more resources than Massdrop. Massdrop operates on take money and then build. Monoprice hopefully can foot the bill for production in advance of orders.
Indeed. I am tired of recommending the Massdrop THX and then be told people can't get them. Maybe competition will also force them to increase volume.
Ceburaska
The fact they went unavailable almost immediately doesn’t make me confident.
phoenixdogfan
Nashville
" it is my absolute pleasure to recommend the Monolith THX AAA Balanced headphone amplifier. It delighted me to see a company dedicated to absolute excellence and full transparency to our sources and content. This is a type of product you buy once and you are done. "
My THX AAA 789 is set to arrive on Thursday and now I'm contemplating slitting my wrists. :(
Oh no. You have an exceptional product. Don't get buyer's remorse that way. The monolith is for people who have not yet managed to get a Massdrop one.
