NAD M10 Streaming Amplifier Review
This is a review and detailed measurements of the NAD M10 streaming amplifier and DAC. It was purchased and drop shipped to me kindly by a member. It costs US $2,749 from NAD dealers.
The M10 sports a very large touch screen LCD display that covers the entire front face:
Sorry for leaving the protecting plastic on. Like to keep things as new as possible for members.
As nice as the display is, it simply is not as responsive as your phone or tablet. What could be really cool such as the VU meter mode, becomes a jittery display that doesn't please much. A much faster processor with GPU would be needed to really make the display the star. Still, it is heads and shoulders above others that have small displays.
The back panel is notable for inclusion of HDMI ARC input:
Alas, I have no ARC capability on my workstation so could not test that feature.
In normal use the plastic case barely gets warm. Under heavy stress of power testing, it got somewhat warm making me wish the case was made out of aluminum than plastic. You are not likely to push the switching amplifiers this hard and at any rate, the M10 runs much cooler than any Audio/Video Receiver.
While I did not have time to test it, the M10 comes with Dirac Room EQ which is nice.
I noticed one operational/design issue. I unplugged the unit to take its picture but noticed that the display went crazy flashing random stuff. I thought it was a capacitor that was discharging but this continued and would not stop! I looked in the back and I realized I still had the HDMI cable plugged in. Knowing that it provides a 5 volt "hot plug" signal, I disconnected it and the display finally shut down. This is improper design. The device must NOT draw any power out of HDMI connection.
DAC Audio Measurements
I connected the Coax output of my Audio Precision APx555 analyzer to the M10 and measured what came out of the pre-out with volume adjusted for 2 volt output:
Distortion is quite low at -110 dB (near threshold of hearing) but the noise floor kept jumping up and down causing SINAD to vary with it. This shows lack of isolation between sensitive DAC subsystem and busy processor running other functions of the device. As it is, performance is respectable which is a sigh of relief:
Anything in green and blue is good.
Testing at other output levels shows that the M10 is capable of pumping out good bit of voltage:
NAD M10 BluOS STREAMING AMPLIFIER DAC THD+N vs Output Level Audio Review.png
Dynamic range clears the bar for 16 bit CD/streaming content but not much more:
IMD distortion versus level shows the same noise issue:
Filter response also shows higher than it should be noise floor:
Jitter and noise test shows a lot of unwanted tones but audibly they are below threshold of hearing:
Linearity is very good:
EDIT: forgot to include multitone in the original review:
Finally, we see the penalty of the DAC filter not being sharp enough in distortion+noise versus frequency:
Amplifier Audio Measurements
I was hoping that analog input was not digitized but alas, it is:
NAD M10 BluOS STREAMING AMPLIFIER analog in frequency response Audio Measurements.png
And at very low sample rate. Maybe there is a setting to change this but I did not bother to look.
Using the same analog input, I witnessed wild swings in noise floor of the unit:
So I abandoned the analog input and switched to Coax for the rest of the amplifier tests:
Performance is improved and stable as well. This rates the M10 above average for more than 100 amplifiers tested so far:
Signal to noise ratio is disappointing as even with full power, it barely clears the 16 bit hurdle:
Frequency response using digital input is wide enough:
NAD M10 BluOS STREAMING AMPLIFIER Digital in frequency response Audio Measurements.png
But for those people with ultra sensitive high frequency hearing, you will lose half a dB at 20 kHz.
Let's see how much clean power we get out of M10 starting with 4 ohm load:
NAD M10 BluOS STREAMING AMPLIFIER Coax In Power into 4 ohm Audio Measurements.png
I allowed the distortion to go higher (1%) and got even more power:
NAD M10 BluOS STREAMING AMPLIFIER Coax In Max Power into 4 ohm Audio Measurements.png
I tried to get the burst power rating but some kind of limiter in the M10 was fighting the analyzer and wouldn't allow me to get there. It was nice that it would not shut down.
Power naturally drops at 8 ohm:
NAD M10 BluOS STREAMING AMPLIFIER Coax In Power into 8 ohm Audio Measurements.png
Performance of the NAD M10 is generally acceptable especially for a multifunction device where we see a lot of fails. Alas issues here and there took away my enthusiasm for it. There is no excuse for poor analog input performance in a nearly $3000 device. Or rather high and variable noise floor.
So overall, I gave it a "like it" panther award but it is not something I would personally buy. I can be stubborn that way!
So stressed out with the terrible backlog of reviews, I have nothing sarcastic to say. So I will just ask that you donate what you can to change my mood using: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
Lattiboy
Wow, what mediocre performance for a $3000 integrated!
Just buy a Yamaha AVR for 1/3 the price that still has Dirac and a whole lot more. What is the possible justification for this thing outside of “it looks pretty”?
EDIT: I just realized it’s Arcam not Yamaha that does Dirac. However, you could buy a mini dsp, a Hypex amp, a lifetime Roon subscription, any streaming device (raspi, CCA, ect), a Topping D30, and still wouldn’t be spending half the money and have better performance.
It is very compact and due to use of switching amplifier, runs very cool. These two things you won't find in an AVR.
But yes, I wish they had paid more attention to the design and created something with much better performance.
stren
Thanks Amir, honestly was expecting worse from nad on the digital side given some of the other reviews. A decent looking box with a ton of functionality.
JohnYang1997
China
Is the noise floor jumping due to DC at the output?
asruser2020
I don't own this amp, but I've had my eye on it. The M10 is not an integrated amp that you would buy for just the amplification; you'd buy it for the all-in-one feature set. It has full streaming capability to every online music service using ethernet and Wi-Fi. It has Airplay2 (if you use an iPhone) and Bluetooth. It's part of the BluOS multi-room ecosystem, so you can use smartphone and desktop apps to control it. It has Dirac room correction (which wasn't tested). And because it uses an nCore amp, it can put out 200W within an 11lb chassis. By the way, it won the EISA 2019 hi-fi award for best smart amplifier (I guess "smart" means "streaming" or app-connected).
Are you referring to the touch-and-swipe responsiveness? You still had the plastic over the screen, so that would probably explain any lagging.
That is unfortunate, because Dirac Live is one of the main selling points of this unit.
TimoJ
Finland
Yamahas don't have Dirac. But yes, 2750$ is way too much for this.
Kachda
NY
was looking forward to this one. I’ve had my eye on it because it lets you run dirac and calibrate from your phone (and i assume add your custom peqs) as well. The dirac functionality may be worth it even with the higher noise floor. And NAD seems to have been pretty conservative with the power rating.
the other option I’m considering is a mindsp shd + a nc252mp based amp. Not as convenient because it needs a usb connection and laptop, but the performance will probably be way above this.
samysound
USA
I actually purchased an M10 and ended up returning it. I had all the plastic removed on mine and found the touch screen to be laggy as well. In addition the digital inputs had issues. As for streaming, I preferred roon to the NAD software (seemed to lag a bit as well). On positive note, the dirac integration was great as was the big display and nice case work and inclusion of hdmi input. In ended up purchasing a minidsp SHD unit instead....
Kachda
NY
Seems like minidsp is the way to go for dirac
samysound
USA
I actually went though the same thought process and ended up with a SHD and NC502MP based amp instead. the setup with dirac is not as slick as the M10 but the over all system stability has been better (im using roon) and the measurements are excellent in comparison to the M10
restorer-john
A plastic box, $3000 streaming amplifier with meausurable flaws in just about every parameter. The analog in-out response is dreadful.
It's hard to get excited about a product that does a whole lot of things, but nothing really well. A jack of all trades- master of none.
jasonq997
I really like what they are doing here. This is the kind of device that would be more ubiquitous (and much cheaper and better because of it) if there were more young (in this context this probably means under 50) 2 channel enthusiasts plugged in to modern technology and streaming services. It is a shame that 2 channel receivers and integrated amps are still stuck in 1995.
jasonq997
And this is what I am talking about -- the notion that in in 2020 a heavy box with a lot a capacitors should mean something when we have better technology that just needs to be refined, but hasn't been for the consumer market due to lack of understanding and demand.
samysound
USA
Its not plastic. Anodized aluminum with glass top.
AndrewDavis
A Bluesound Node +DAC w/volume control + NC252MP would work well and perform better.
In fact, Node(or rasberry pi)+Soncoz SGD1 + any Ncore based amp is an amazing value streamer/preamp/amp setup.
Dj7675
If concerned about best performance, agreed. Even a Minidsp shd/nc252 combo. I can se the appeal on a simple, 1 box solution. Minidsp shd power would be a great comparison. Hopefully someone will send one in.
