Neutral DAC/AMP for Mixing and Mastering
calojer
Hi, everybody.
I'm just finishing mixing a record and since I don't have a properly treated studio I bought some Sennheiser HD650 headphones with 320 Ohm impedance.
My RME Babyface sound card (first model) does not have a headphone amplifier capable of driving the HD650 and for this reason I am considering buying a DAC/AMP.
What I need is neutral listening that adds nothing to the sound of the mix. A clear, powerful but neutral listening.
I've read so many reviews but I can't figure out what's right for me. I have a budget of $350.
Can you help me, please?
Thanks in advance,
Fabio
Racheski
Chicago
Do you need Bluetooth?
How will you connect the DAC to an audio source? USB?
Do you need an all in one DAC/Amp or are separate devices for the DAC and Amp OK?
Any other features that are a must have, or you just need a neutral set up to drive the HD650?
What country do you live in?
Matias
São Paulo, Brazil
calojer
calojer
I don't need bluetooth
I'll connect the DAC to the USB-C of my macbook pro 16" 2020.
I'd like an All in One DAC/AMP.
Just a neutral setup to drive the HD650.
I Live in Italy
Kouioui
Central FL
I mix on a budget and to my ears, there's nothing better for $270 than the Topping E30/L30 stack for use with the HD650/6XX. It's going to be difficult to match this performance in an all-in-one at your budget. If you're not already doing so, I suggest looking into adding parametric EQ, such as oratory1990's with your setup. I'm PC based so not familiar with solutions for macbooks.
Racheski
Chicago
As mentioned if you are OK with a stack, the E30/L30 stack can’t be beat. For a combo DAC/Amp, I think Topping DX3 Pro ($220) will work great.
Reactions: mkt
Matias
São Paulo, Brazil
It's Awesome but my budget is 350$ not 1500$.
Right, so they newly announced Schiit Modius + Magnius should be close to the budget, just get a balanced cable for the Senns HD650s.
Racheski
Chicago
Shipping overseas from Schiit is around $50.
niceasmay
Sorry but I don't understand your problem. I have babyface and HD 650, working together as a charm. No problem with driving high impedance headphones.
dskelto
Not sure if op is still looking for a solution to this problem; but I use an RME Fireface UCX which also uses the very versatile Total Mix FX drivers from RME. Be sure to check the gain settings on the headphone output channel and set it to high if that option is available. Makes a huge difference when driving high impedence cans.
