If they're like the other Monolith amps, they will probably be available with several channel configurations.So apparently 8 channels of NC502MP or NC252MP customized by Hypex by attaching a heatsink to their backs. And the same front panel as their current amps. Alright, nice move.
Current amp style.
I asked and models with fewer than 8 channels will be coming, but won't be coming for a while.If they're like the other Monolith amps, they will probably be available with several channel configurations.
I think it really depends on if you prefer class D or class A/B.Just preorderd that new onkyo receiver and was going to get the 5-7channel monolith... should i wait for this newer one?
I honestly don't know the difference... I've been using a 20 year old B&K AVR507 receiver since new on my 4ohm Polk LSI speakers... Just bought a new house with dedicated HT room so figured it was time to upgrade to this century... I appreciate your helpI think it really depends on if you prefer class D or class A/B.
You can't go wrong either way. Class D is more energy efficient.I honestly don't know the difference... I've been using a 20 year old B&K AVR507 receiver since new on my 4ohm Polk LSI speakers... Just bought a new house with dedicated HT room so figured it was time to upgrade to this century... I appreciate your help
Current amp style.
The Monolith Class D 8 channel amp will weigh 45 lbs instead of the 5-8 lbs for many stereo Class D amps.
The heat sinks add a ton of weight and are not needed except during long term playback at high volumes. It will be interesting to see pricing and measurements. My guess is the 8 channel will be priced over $2,800. And if Monolith follows previous pricing the stereo version will be the worst value per watt.
The heatsinks are likely to help keep those capacitors that people here carp about more cool, which would be better for longer term longevity. You kinda get what you pay for.The heat sinks add a ton of weight and are not needed except during long term playback at high volumes.
