Peachtree Nova 300 Review (Dac & Amplifier)
This is a review and detailed measurements of the Peachtree Nova 300 integrated amplifier with DAC and phono stage. It is on kind loan from a member and costs US $2,199.
The Nova 300 fits in the same chassis Peachtree has successfully used for last 15 years:
It is quite beefy and heavy. Volume indication overloads the LED indicators on the input selectors showing a coarse 8 levels. For this price, I would expect an LED indicator of the actual level.
Back panel shows good quality connectors and rich feature set for a desktop amplifier:
Peachtree made its name on DACs and had quite a following 10 to 15 years ago. I was curious to see if they had upgraded the DAC subsystem since that time so let's start by measuring that subsystem.
Peachtree Nova 300 DAC Measurements
I fed the unit over USB input, sampled the output from preamp out and adjusted the volume to output 2 volts:
Well, this is quite disappointing. Noise and distortion as represented by SINAD is in decidedly "poor" category in today's market:
The unit can output higher levels so let's see where peak performance is:
No luck there as the peak is actually at 1 volt out.
Dynamic range is better indicating distortion is the problem:
At this point I didn't see a need to run more DAC tests and switched to testing the amplifier.
Peachtree Nova 300 Amplifier Measurements
For this test I used the Aux analog input:
Ah, this is very respectable and above average performance:
SNR is not as good as I like at 5 watt but gets better at full power:
Crosstalk is excellent:
Frequency response shows a peaky filter though:
Multi-tone results indicate "good enough" performance:
What was most impressive is the amount of power available from the ICE amplifier module they are using:
Since I am driving two channels, this is over 900 watts of power! Indeed the peaks hit 1000+ watts:
Even at 8 ohm there is copious amount of power available:
Interesting to see little dependency on frequency until we hit a few watts:
It is clear from the measurements that the DAC subsystem is a relic that is simply behind times. The product though benefits from using a competent B&O ICE module which has stayed competitive producing far more power than you would expect in a "lifestyle" product of this kind. As such, I expect subjective performance of Nova 300 to be excellent regardless of what speaker you attach to it. I usually don't worry about price/performance in my reviews -- that is yours to worry about. :) But here, the price seems quite high relative to the other internet focused amplifiers which have come out in the last couple of years. Some of those are powerful and all of them cost a lot less than the Nova 300.
Overall, I can't recommend the Peachtree Nova 300 as a new purchase.
_thelaughingman
I'll admit i've been enamored and wanted to purchase a Peachtree Nova after seeing at a friend's house a while ago but could never justify the price. Well there's always better performance to be had at cheaper price based on the numbers of this review.
Vini darko
Dorset England
Nice range of conections on the back. 2 usb inputs :eek:
Beast of an amplifier and while the dac isn't sota (by a large bit) is that a euphoric distortion profile?
Do you know if the headphone socket has its own amp , or running off the speaker outs?
Kachda
NY
I once bought a Peachtree Audio decco125 SKY amplifier from the Peachtree ebay store. Unfortunately it caused a constant high pitched whine from the tweeters, and had to be returned. Wasn't very impressed with it because of that. It has very high SAF (spouse apporval factor) though.
A few years prior to that, being a complete newbie to good audio systems, I walked into a stereo store and the sales guy was pitching me on of their original amplifies that uses a tube in their pre-amp section. He explained this was to remove the 'harshness' from mp3 files, but at $1500 it was way too much for me back then.
Rottmannash
Nashville
I assume this uses SMPS-how does this amp deliver such high peak power than some of the other Class D amps measured here? Isn't that usually power supply limited?
m8o
Having the loop out/in feature is _really_ nice and rarely seen in a device like this; really wish my McIntosh MHA-100 had this. For applying analog tone control or eq. Too bad about that DAC perf tho.
Freeway
Just about a decade ago I bought a Peachtree Decco2. The tube thing didn't sway me (quite the contrary) but the early adoption of USB connection, the price I got and it looked kind of cool did. With it and a pair of Epos Epic 1 and NHT B-10d I floated away many a night. Have used it just as a pre amp also.
Anyhow, a few years later while on the phone with one of their people about something, I asked whether it would be worth it to upgrade to the newer model. He said nay. Actually, he said he hadn't. Got to respect that.
GWolfman
Surprised by the ammount of power in this small package. Price makes me cry nonetheless.
Sal1950
The Chicago Crusher
Central Fl
Too bad, I always liked the cute little guys with the beautiful wood cases.
VintageFlanker
Paris
Ha! This is not so bad after all. But the good amp performance is only related to the Ice 700AS2 inside. Their own part (DAC) is a mess.
Any chance you test the headphones output, @amirm ? Because Peachtree is marketing it as "Top Quality, Class A Headphones Amplifier", if I recall correctly.
Anyway, only based on my own experience, I can't recommend this Nova 300... like: at all. I bought mine 3 years back. I chose to ignore many comments talking about reliability issues at the time. Well, I did wrong. My unit has several problems, like many others: the worst being my SPDIF inputs died only few days after I received it. Support was terrible, but I got my 300 fixed at the end. I sold it because of the meh sound anyway... But the buyer called me back few time after that, to complain about the DAC's issues... :facepalm:
Fixed twice. I don't have a clue if it's still working today. Don't know, don't care.
Peachtree wasted me a lot of time and money. Avoid.
They sell a stand-alone power amp, if you wanted serious power in a really nice looking case
https://www.peachtreeaudio.com/collections/amplifiers/products/amp500
Or get the exact same performance at half the price.;)
D
Deleted member 13028
Guest
Thank you Amir. I have wanted one of those for quite some time. This is exactly why I am very happy we have ASR - now I can compare the price to objective performance, I surely hope no one will ever measure my SMSL A8 (which I ended up buying instead of the Peachtree for AV duties).
D
Guest
About its amp performance? This is basically a 125ASX2 module:
A bit weird it has much better performance inside the Yam WXA-50 (with different Gain, tho)
Yes, as well as the DAC section - not to forget that implementations might vary. I have seen detailed measurements of the A6, they looked good for the price.
Helicopter
Michigan
Nice to see good power here, but whoof! That DAC.o_O
I could DIY something with off-the-shelf Ice and minidsp boards and get better performance for a fraction of this price.
