Polk T50 Review (Floor Standing Speaker)
This is a review and detailed measurements of the Polk T50 tower speakers. I bought this recently for $149 from Amazon.
As you can imagine, a floor standing speaker at this price has to be quite light and this one definitely is. I can easily lift it as it weighs less than many bookshelf speakers. What a marvel of cost optimization:
Yes, my system area is dusty. Do you want more reviews or clean listening room???
This is a 2-way speaker with two passive radiators to improve bass response.
I performed over 1000 measurement which resulted in error rate of about 1%.
Reference axis was the tweeter center. Grill was not used.
Polk T50 Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
I expected the response to be horrific but it is not that bad. Yes we have a peak around 1 kHz and then shelving up of the highs which is a requirement for "showroom selling" against its competitors which boost the heck out of that region.
Hard to see the sources of the uneven response from near-field measurement:
Polk T50 driver Frequency Response Measurements FLOOR STANDING TOWER SPEAKERS.png
I guessed that the peaking at 1 kHz may be due to passive radiators resonating. The math is too complex to visually confirm though.
Early window frequency response shows vertical directivity messing with overall sum:
Polk T50 Early Reflection Frequency Response Measurements FLOOR STANDING TOWER SPEAKERS.png
As noted -- and it is how I have my room -- use a thick carpet. That should be a nice absorber from 1 kHz up which we need to fix that trough and extra high frequency energy. High ceilings help to reduce the impact of bounce in that direction. Or you can stick an ugly absorber up there.
Predicted in-room response is not super smooth:
Polk T50 Predicted In-room Frequency Response Measurements FLOOR STANDING TOWER SPEAKERS.png
The effect of elevated treble is obvious. But that peak at 1 kHz followed by slight dip, not so much.
Edit: forgot to include distortion graphs:
Polk T50 THD Distortion vs Frequency Response Measurements FLOOR STANDING TOWER SPEAKERS.png
Polk T50 THD Distortion Percentage  vs Frequency Response Measurements FLOOR STANDING TOWER SP...png
Horizontal beam width is again, not too bad if we don't try to be too critical:
Polk T50 Horizontal Beam width Measurements FLOOR STANDING TOWER SPEAKERS.png
Polk T50 Horizontal directivity Measurements FLOOR STANDING TOWER SPEAKERS.png
Vertical directivity gets worse if you sit below tweeter so tilt the speaker forward if that is the case:
Polk T50 Vertical directivity Measurements FLOOR STANDING TOWER SPEAKERS.png
Impedance is the typical 4 ohm or so:
Polk T50 impedance and phase vs Frequency Response Measurements FLOOR STANDING TOWER SPEAKERS.png
Tons of resonances are visible likely due to think cabinet and who knows what else.
Polk T50 Listening Tests and Equalization
I must say, first impression was not bad at all. Unlike just about any bookshelf speaker, the T50 is able to handle tons of power and gets quite loud and dynamic with little evidence of stress. Throwing difficult sub-bass material at it didn't impact it since it simply doesn't try to play them (its bass response has a sharp cut off). Yes, there is a bit of brightness but judging that is often problematic as you don't know the content's spectrum and lack a frame of reference.
Best way to determine audibility of frequency response is to try to straighten it and see if you like it better. That is precisely what I do with EQ:
Ignore the first dip as that is for my room. Without it, there is enough bass activation to make the sound a bit boomy. The rest of the filters thankfully are mostly reduction which help with distortion as well. With all of them in place, the difference was not night and day but enough to make the T50 very enjoyable to listen to. Call me surprised!
Going into this review I expected the T50 to be junk. It did not turn out that way. It is a miracle of engineering and manufacturing to get a floor standing speaker in my hands for just $149 and have it not be broken. Objectively there are some issues but somehow subjectively, it seems less flawed. With a bit of EQ, it improves even more to a proper "hi-fi" class. Despite cheap bookshelves, the T50 is able to produce lots of volume and dynamics which I really value and enjoy.
I am going to recommend the Polk T50 especially with equalization.
  • Polk T50 Frequency Response.zip
What I find hilarious is the tweeter height difference between these and your Salon 2!
Yeh, the salon 2 tweeter is a bit too high though. You have to sit far from them.
Helicopter
Michigan
Thanks Amir. Great to see this performance. I am really curious how the Polk in wall speakers perform now because several cabinet speakers are good and that outdoor speaker I sent in was junk.
Helicopter
Michigan
Perhaps the front ports were to blame, or being intentionally designed to be wall mounted up high for surround use (response is much more neutral about 20° below tweeter.
Yeah, when I got to 2-way with two passive radiators, I was thinking 'ooh, I think the marketing people let the engineers figure that part out... wonder how it worked out...'
xarkkon
How many reviews are you producing a day? Man! You're on a roll! (Yes, dirty rooms are perfectly fine...)
Remlab
Oceanside California
That's a really linear, low distortion tweeter, especially at the 2khz x-over point. In a loudspeaker like this, it's pretty amazing.
Kachda
NY
2-way? So it has 3 mid bass drivers?
dfuller
Huh, that's... Not too bad. And here we see the advantages of PRs:
Yeah, it's a little messy in the mids - but there's no pipe resonance!
Remlab
Amir, I noticed you haven't tested the Reference 53 Mono amps I see in the picture. Is there a reason?
Yes. At some 135 pounds each, they have literally welded themselves to the floor! I can't even slide them an inch on the wood floor! They are that heavy. In addition, one has become flakey and I am afraid of blowing up the other by stressing it. I need it as a reference to troubleshoot the other.
I do have another Mark Levinson stereo amp that I hope to measure at some point.
Remlab
I cant imagine that there's any bracing at that weight. Stick braces at the most. The side panels must sing like a canary:)
