Review and Measurements of Benchmark AHB2 Amp
This is a review and detailed measurements of the Benchmark AHB2 Amplifier using THX technology to reduce distortion. I was going to request one for testing due to membership demand but to my pleasant surprise, the company volunteered to contact me and send not one, but two units! I requested the second one because of something I was seeing in the measurements that turned out to be my issue, not the amp's. The AHB2 retails for US $2,999 from the company direct.
The AHB2 is a very compact form factor, enabled by use of switching power supply to increase efficiency/density:
There is just a power switch in the front. It might be but I constantly reached for the screw next to it to power it on! Having the power switch be slightly different color or shape may help with this.
There are a set of LEDs that show the status of the amplifier. They are driven by an FPGA (field programmable digital logic) that monitors all aspects of the amplifier and shuts down the unit if stressed. It did so very quickly and efficiently in my testing. Usually this is done with purely analog or maybe a small microprocessor. As such, the coverage of scenarios that could damage the amplifier is much less complete than using the approach Benchmark is using in AHB2.
Here is the back panel:
This is a very minimalistic approach given the small amount of real estate available. Only input is XLR balanced which is just fine in my book. A gain switch allows the input level to be controlled so that you can just use an RCA to XLR adapter and still get full power (2 volt max in high gain). At the other extreme, the low gain setting is designed for professional pre-amps with lots of output, getting its max power at 9.8 volts. Using this scheme, the signal to noise ratio can be improved as you will see in measurements later.
For speaker terminals there are two sets: classic heavy duty banana jacks and SpeakOn. The SpeakOn are locking and provide the best performance. I lost about 3 dB of performance using the banana jacks due to less secure connect there. So the measurements you see are with SpeakOn jacks.
Another minor nit on that note: I had a rather cheap SpeakOn cable and its plug was just large enough to hit the silver screws that the sockets are mounted with. Typical round shaped SpeakOn ones are not an issue. Flush mount screws would solve this problem.
There is a switch for selecting stereo or mono bridged output. The latter quadruples the amount of power available and unlike typical bridging, according to Benchmark comes at no penalty in distortion! I plan to test this later as it has a minimum impedance of 6 ohm so I could not use the 4 ohm setup I used for this testing.
There is a very beefy AC mains cable with really nice locking tabs. Insert it and it stays put unless you push the two red tabs on each side. Nothing is more aggravating than the AC cable coming half-way lose from the IEC socket.
Being a proper company of course the AHB2 comes with full set of regulatory/safety/emissions certifications which is super important with power amplifiers given the high voltages and currents running around in them.
In use the AHB2 stays very cool for a power amplifier when it is idling, outputting little power which was a nice surprise.
As to THX technology, it merges a low-power but very low distortion amplifier with a high power but higher distortion amplifier. The distortion of the latter is not seen because it is producing so much power (so the ratio of distortion is lower). The general scheme is not new, dating back to 1980s but new implementation is. We have seen this in stellar performance of Massdrop THX AAA 789 amplifier which broke new ground in level of distortion and noise. Will the Benchmark AHB2 manage the same? Let's see.
Power Amplifier Audio Measurements
As usual, I start with my 5 watt output test using 4 ohm load using SpeakOn terminals as noted:
I hope your jaw is on the floor just like mine was when I saw this picture emerge! :) 113 dB THD+N in a power amplifier? Are you kidding me?
Look at the harmonic distortion. The worst case spike is below -130 dB! This is insanely good. Of course this type of SINAD (signal and noise ratio) crowns the Benchmark AHB2 as the best I have ever tested:
The performance was so good I literally had to rebuild my dummy load to get there. Even the quality of the metal used in the connectors matters to get to this level of distortion. I replace all my dummy loads with higher precision ones that have much less VCR (voltage coefficient of resistance). Resistor values can become voltage dependent creating distortions of their own. Up to about 105 dB of THD+N, it doesn't matter but beyond that, the VCR was the dominant distortion, not the Benchmark AHB2 amplifier!
It was requested that I show the breakdown and distortion so here we are:
Our best case hearing threshold is -116 dB SPL so no question that this level of distortion is totally inaudible. Separating the noise from THD, we see that it is noise that we are measuring as THD+N, rather than distortion:
And this is with exceptional noise performance of Benchmark AHB2 as we see in the graph of THD+N versus power:
Benchmark AHB2 Amplifier Power at 4 Ohm compared to Hypex NC400 Audio Measurements.png
Even in high gain, the AHB2 easily outperforms the DIY Hypex NC400 I had tested before which used to be the best amp I had tested.
We have 185 watts of power at incredibly low distortion of 0.00016%, besting the company specifications.
Note that the FPGA protection mode kicks in and essentially shots the amplifier down past the limit. You get absolutely distortion-less and noiseless performance until there is no more.
EDIT: here is performance in bridged mode using same 4 ohm load:
You get 500 watts of stunningly clean power. Protection circuit shut the unit down after that so it is quite safe to try. With a THD essentially matching the non-bridged mode, there is no reason to be afraid of trying this.
Intermodulation distortion versus power level shows the same story of clean power:
If you want to know what you get for extra money over bargain amplifiers, you can see the difference in the above graph. We are not talking about 5 to 10 dB but whopping 40 dB better!
I have had requests for intermodulation distortion using dual 19 and 20 kHz tones. Here is that:
Benchmark AHB2 Amplifier 19 and 20 kHz intermodulation Distortion Audio Measurements.png
THD+N versus output level looks far cleaner than anything I have tested before:
Benchmark AHB2 Amplifier Audio Distortion versus Power versus Frequency Measurements.png
Even at the limit of our hearing (20 kHz), we have vanishingly low amount of distortion. The graph is exaggerated so shows a rise there but in absolute levels, despite 90 kHz bandwidth of the test, we have incredibly low THD+N of just .004%.
The sharp spike at 45 Hz in green shows the amplifier going into protection mode. So don't pump that sine wave continuously into it at 133 watts. :)
Frequency response is exceptional too as expected:
Since this is not a switching amplifier, there is no filter there allowing the bandwidth to go to 200 kHz and beyond. Lowest band of AM radio is 450 kHz so likely you could use the AHB2 for an AM radio transmitter! :)
Usually when we test switching amplifiers we see all kind of "interesting" things in their outputs above hearing range. The AHB2 is a classic configuration albeit, with a switching power supply so all is well and clean here:
Benchmark AHB2 Amplifier 1 kHz Broadband FFT Spectrum Audio Measurements.png
My reference graph for the Hypex NC400 used an AES filter (by accident) so I ran the AHB2 both ways, with or without that filter. Using the filter (in green) so the two are equal, we see much cleaner spectrum below 200 kHz and of course, no massive switching spikes. Worst case spike is below -115 dB. In other words, the Benchmark AHB2 is clean even in the areas you are not looking! It is like a restaurant scrubbing their parking lot with soap and pad as well as their dishes. :)
My loose wires on dummy loads is not the best setup for measuring crosstalk but here it is anyway:
Where our hearing is most sensitive (2 to 5 kHz), separation is around 100 dB which is way, way more than we need. Despite the small enclosure, the AHB2 manages exceptional numbers here.
EDIT: forgot to run the classic SNR test in the original review:
Wow, assuming you play at peak of 120 dBSPL, your noise floor will be at -10 dBSPL! That is absolute silence.
It goes without saying that the Benchmark AHB2 breaks new ground with respect to performance of power amplifiers. Using it, you can be assured that any distortion that you hear is from other sources (speaker, source, content, etc.). This is what I look for in high-end audio: absolutely the best performance so no second guessing is involved. You buy once, and you are happy forever!
All of this comes from a company that is a model of transparency with proper and accurate measurements of their products on their site. And importantly, volunteering to have that data shown to be correct by independent sources such as us. Support form the company for me at least has also been exceptional.
Yes, $3,000 is fair bit of money but is pocket change in high-end audio. Sales tax is higher than $3,000 for most of those products! I hear a lot of talk from audiophiles to have the equipment get out of the way of enjoying the music. Well the Benchmark AHB2 at levels that assuredly passes full transparency. So if that is your moto, you better stop buying boutique products with no specs and independent measurements and get an AHB2. Everything you hear then will be what is in your source, not the dirty dishes that your amp my serve your food on.
Needless to say, the Benchmark AHB2 gets my strongest recommendation for power amplifier. The pink panther agrees, having hit the ball out of the park after I took that shot!
Edit: Another sample of AHB2 tested more recently: https://www.audiosciencereview.com/...hmark-ahb2-review-updated-measurements.50844/
The comedian Chris Rock said it best: there is a difference between being rich and wealthy. If a wealthy person had as much money as I have, he would hang himself! So please donate enough money so that I can become wealthy using either:
DonH56
Monument, CO
Nice, Amir. This is one of a few and now at the top of my list should I ever upgrade amps.
Soniclife
How do the clip and temp lights work? I like the idea of these as it seems as long as you never make them light up, you have a perfect amp, not driven into clipping.
VintageFlanker
Paris
WOW. I'm shocked. This is endgame, my friends!
Buy this, and an ADI-2 DAC as preamp and be happy forever!
...Wait?!... 4000$ for both? Ouch.:eek:
The power is just INSANE for the size. It is more powerful than my huge and heavy (25kg) Denon PMA 2500NE (Rated at 160W/4ohms, but at 0,7% THD)
There is a table in AHB2 manual stipulating different combination of lights:
The labels are a bit misleading in that I got the TEMP light to come on with a speaker terminal short as the table indicates.
pjug
Are you able to make some measurements on the efficiency of the AHB2? I am wondering where the Class H power delivery puts this compared to conventional Class AB and compared to Class D.
invaderzim
NorCal
It is a lot of money but if it is the last amplifier you buy then it becomes much more of a bargain.
The fact that you can get an amp that would leave no room for "I wonder what it would sound like if I upgraded to..." for $3,000 is impressive.
Somerville, MA
3 grand seems pretty reasonable for this level of performance. 185 watts at this level of distortion is insane.
Compare with this Krell unit for over 8K:
https://hifiheaven.net/shop/Product...hannel-Power-Amplifier?sort=p.price&order=ASC
We have arrived at the next generation of amplifiers. One wonders if, like the CD dying, streaming dominating, and vinyl having a resurgence, amplifiers in the future will be tubes and next generation designs such as this.
Soniclife
Did the lights correspond to what you saw during testing? What I'm getting at is can an owner who never sees the lights flash be completely confident their power amp has sufficient power, or do they trigger too early or late?
Crane
Very endgame indeed, you plan on doing any listening tests later with your own speaker system the salon2?
Matias
São Paulo, Brazil
anmpr1
It is easy to fool oneself over these things, but I can attest, at least subjectively, to the gear's goodness. When my AHB2/DAC3HGC combo arrived I was unprepared for the subjective improvement it made on my system. I'd been using a couple of different tube amps (home made and commercial) along with a Japanese integrated amplifier of good quality, rated at 100/ch. The Benchmark combination was like lifting a haze over my speakers. I have fairly sensitive horn speakers (Paul Klipsch La Scala II) and now am listening to them at a much too loud level. I have to remind myself to turn them down. I attribute it to the very low distortion the amp and DAC produce. La Scalas are known to be 'bass deficient', and it is true as far as it goes, but with this amplifier the bass is tight, overall imaging is rock solid, and highs are not harsh at all (of course a bad recording will always sound bad).
Build quality and fit/finish appears to be excellent. The small form factor is shocking, considering the usual thing out there. I ordered the Benchmark speaker cables, which were reasonably priced, and quite well built. Not the typical snake oil magic wire thing. But you need them for the SpeakOn side, and the expanding banana plugs were quite ergonomic, too.
My final word is that unless you need a lot more power for your particular application, there is not much need to spend more than five large for any DAC/amp combination. If you do need more power, buy two AHB amps. That is that.
PS: as far as the on/off switch? Use the amp's 12volt trigger line into the DAC, and turn the entire system on with the remote.
DonH56
Monument, CO
The new Purifi Eigentakt 1E400A should have THD a little better than the Hypex nCore NC400, but IMD better than the AHB2. Let's see.
https://cdn.computeraudiophile.com/article-images/2019/0517/1ET400A - Product Brief (1.01).pdf
I wish Benchmark had a more powerful version of this amplifier using the same technology, like 600-700W in 4 ohms stable for example.
A bunch of people are using a pair bridged mono to drive speakers like Salon2's that are ~4 ohms nominal. I believe Kal tested into speakers that dip a bit low and had no problems. That is my end-game plan, but I have corresponded with one person using single AHB2 to drive a pair in a larger room than mine and he does not feel the need for more power. I may start with one or use a set to drive all seven speakers, depends on what stock and bonuses look like this year (pretty ugly, unfortunately).
estuardo4
Every body is talking about this excellent amp, and it is getting quite a buzz, deservedly so.
When you find this level of performance, as others wrote, you're set for life.
To all the experts and veteran audio engineers at this forum I ask (because I haven't heard of anything similar before): Do any of you have encountered an amp with this kind of benchmark results? My guess is that indeed, there may be a few others, but they'd be multiple times costlier and heavier than this AHB2 amp.
