- Thread Starter
- #21
You are reading it correctly but that part I can't control from run to run. So ignore the rate of change. Just look at when the gain is at a horizontal step and then look at the deviation at that gain attenuation. How long that step goes on is not material then.Just to make sure I'm reading these correctly, since you are making a manual sweep the time is going to vary. But assuming you are doing your best to keep your speed consistent cutting the time in half should roughly correspond to the volume at 50%?
Here is a quick example of that:
Note that the vertical graph doesn't start from zero. I need to fix that. So for now you need to note that it starts around +9 db or so. In other words, "-20 db" is really "-29 db."
