Well mine arrived today and got put into the chain:
Aries Femto>>MiniDSP DDRC-22D>>UDA38pro>>MF M6 500i integrated amp>>B&W 803 Diamond speakers.
I used the toslink input - there is no USB used in my setup. I thought I should give it a decent chance so I powered it with the Uptone LPS 1.2 on the 9V setting with the Uptone supplied SMPS and as there is no SMPS in or anywhere near my current setup, I ran an extension lead from the other side of my home from another electrical circuit to keep it that way!
So, impressions after unpacking and playing a diverse selection of music from rock to instrumental for a few hours:
Not surprising
1. The look & feel of the unit are exactly as Amir described.
2. The packaging is as spartan as you can get and no paperwork whatsoever.
Surprising
1. It worked! I was half expecting to get nothing out of it
2. This thing is LOUD using the RCA outputs and the volume knob at full. Using the same volume level on my amp that I use for other DACs with balanced outputs, it was still louder. Level matching to my Pavane by ear I reduced the Hifime volume about 1/8th of a full turn for my listening.
3. It's not the train wreck that I thought it would be, I'm not listening critically yet but it sounds decent enough out of the box without being anything special. Perhaps a little muddled in busy passages and sounding flat overall compared to what I'm used to (at up to 25x the price).
4. This doesn't sound like the ESS DACs I've had and heard before? Initially I would have placed it on the warmer side of neutral but even as it's playing in the background it seems to be opening up a little?
Anyway, it's early in the process and I'll keep it playing for a few days before coming to any real conclusions. The main aim of buying it was to compare a similar priced product to the D50 that is still making it's way to me.
