Review and Measurements of Holo Audio May --- Probably the best discrete R2R DAC
WolfX-700
China
After I released the measurements of the Holo Audio Spring DAC, something interesting happened.
The reason was because I was wrong about the version --- I measured Spring Lv2 instead of what I thought and declared Spring 2 Lv2.When the developer found me and told me this mistake. I was surprised that Spring could have excellent measurements.And tell him: I am curious how good the measurement results of Spring 2 will be?
The developer told me very lightly: Spring2's measurement is indeed better, but you should measure my new product: May
So on this kind of cold rainy day. I received this product.
This is a commemorative prototype, and the color scheme of the shell is said to be slightly different from the official release. But the developers assured me that the quality is the same as the retail version. I also asked the developer for the price. This is an expensive product with a price of about 4000USD +
It's a split model, which means that the power box (lower) and DAC (upper) are separated. I'm talking to the developer about opening these cases to get some internal photos.
Ah how shameless—These mundane developers explain the ways in which discrete R2R measurements are bad.
They say that discrete R2R cannot be measured with measurements, yes,
But it was actually themselves, in their reckless way.
Compound their pains beyond their proper share.
Ok now this is the measurement result
Dashboard:
D-R:
Filters:
J-Test:
One more thing:
The developer told me that May's PLL is very powerful
So I did the following measurements:
I added 1KHZ sine wave jitter from 10ps to 1.5us And measure 1KHZ THD+N.Jitter without PLL will directly affect the harmonics of 2KHZ
I was surprised to see the results that were almost immune to Jitter!
How about J-Test?
I added 1us 1KHZ sine wave jitter(the green one) .
It's AWESOME!
After the PLL eliminated jitter, not only did we not see a significant increase in side lobes, even the main lobe width did not increase!
Here's what I told the developers after measuring:
“It is my pleasure to be able to measure such products, not only because of the measurement results, but also because of the effort behind these results. I always think that it is good to make a chip DAC into a chip data sheet level, but it is worthy of making products beyond the data sheet.
May is a product I consider respectable.”
pos
Nice measurements once again @WolfX-700, thank you!
I am curious about this DAC: why is there two different units? Is the lower one the power supply?
I am also curious about the PLL as it looks like recent DAC design tend to favor using an ASRC, or a FIFO for the most exotic designs.
solderdude
The Neitherlands
Nice, Can you show filters ?
Both in R2R and DS there are abominations and excellent implementations.
For $4k it should be possible to design a good measuring R2R but there are other even more expensive ones that 'f it up enormously.
Reactions: gjm
WolfX-700
WolfX-700
China
Yes
pkane
North-East
Dashboard:
J-Test:
One more thing:
How about J-Test?
It's AWESOME!
Very pretty measurements! :) Probably the best-measuring R2R DAC I've seen. Is this available for sale yet?
WolfX-700
WolfX-700
China
WolfX-700
WolfX-700
China
The developer said it will be on sale soon, I think it will be later this year (coming soon, isn't it?)
MediumRare
Chicago
If I understand, PLL is a setting that rejects jitter? What is it exactly and how does it work?
Matias
São Paulo, Brazil
Excellent! Now only if you could reach out and get a Denafrips Terminator to measure it would be awesome.
JohnYang1997
China
THD VS AMPLITUDE? R2R architecture has its limitations even when corrected by fpga(i suppose that how he does it). The DNL of r2r should be pretty bad and it's shown here in the imd vs amplitude. I'm wondering does thd show the same behavior.
WolfX-700
WolfX-700
China
I think the measurement of linearity is clear enough
JohnYang1997
China
Also it's better to show multitone with down sloping spectrum(pink for example) and NID(No Interharmonic Distortion). Also at different amplitude and/or with different numbers of sines.
MediumRare
Chicago
Suggestion: photos should show the full device (end to end) and also rear panels. Thanks!
