thank you for investigation.
my question about sample rate of J-test.
why 48 kHz not 44.1 kHz? it would be interesting to evaluate the character of jitter in the same mode as music content.
Probably one of complete and up-todate papers about the J-test Jitter is by Julian Dunn and was published by Audio Precision: A copy of it is here:
https://pdfs.semanticscholar.org/5763/8ec2b495f3c3e7f41deba07a966c9fc92db6.pdf .
Quoting from it:
Sampling Jitter / Data Jitter Susceptibility.
J-test is an AES3 test signal that was developed to maximize the coherence of data patterns while at the same time providing a basic high-level stimulus tone. This test stimulates worst-case levels of data-jitter.
The signal has two components, the first being an un-dithered square wave with a period of 4 samples. A cycle of this is shown here in hexadecimal notation: C00000 (-0.5) C00000 (-0.5) 400000 (+0.5) 400000 (+0.5) On conversion to analog at a sample rate of 48 kHz this signal would produce a sine wave with an amplitude of –3.01 dB FS at 12 kHz. (It looks like a square wave with a peak amplitude of –6.01 dB FS but in a properly band-limited system this sequence of values represents a sine wave of amplitude –3.01 dB FS.) This is added to the second component, an undithered 24-bit square wave of amplitude 1 LSB, made by switching between the following: 000000 (0) FFFFFF (-1 LSB) This square wave is repeated at a low frequency. The frequency is not critical but, for a sample frequency of 48 kHz, a rate of 250 Hz is normally used, as that makes the signal synchronous with the AES3 channel status block of 192 samples.
Beyond a certain point in time we hear no more from Dunn about the J-Test as unfortunately he had an early passing January 23rd, 2003.
Thus the J-Test is defined by its author as a specific sequence of particular samples, repeated as required with considerable latitude granted for the chosen pattern of repetition.
The sample rate of the data can vary but the proper sequence of samples is a proper J-Test as long as the defined sequence of samples is repeated.
