Pity, another dac to remove from my wishlist.
The THD curves are definitely at max volume. I just double checked.I'm guessing the headphone amplifier is itself perhaps better than the measurements show but the DAC errors are limiting the THD+N. I see it reaches a low of 0.0017% THD+N (about -97dB THD+N). I'm guessing this is with the volume control not at max?
Oh really at full volume.The THD curves are definitely at max volume. I just double checked.
And yes, something is strange at the line out since it gets distorted depending on the volume control position.
Not in that graph. There, I show the performance at lower level signals ramping up to max. Distortions in amps are level sensitive and not the position of the volume control (although there can be a small effect there).Am I right in thinking that this means the headphone output THD+N measurements can probably be a bit better when turning the volume control down a bit as it's an analog volume control (to my knowledge, could be mistaken in this)?
Yes, but what it shows is a cumulative effect of both the DAC and amp distortion+noise. Since with the volume at max there is more amp gain the amp distortion is reached before the DAC has full output resolution so the point of lowest distortion of the amp (~1.5 vrms) does not coincide with the point of lowest distortion of the DAC (-0dBFS I assume).Not in that graph. There, I show the performance at lower level signals ramping up to max. Distortions in amps are level sensitive and not the position of the volume control (although there can be a small effect there).
Btw does anybody know which software to use for testing THD+N?
Using Windows 10.For JustIntonation, Are you using Mac or Windows or Linux?
But yeah, REW would work on either.
Thanks for catching that. I fixed it.In the thread title shouldn't it be 9038 and not 3098?
I've received the DA9.1 and measured it a bit.
It has the same problem of added harmonic distortion from the RCA line outputs when the headphone volume knob is turned to max. But.. this only happens when it's at max volume or very near max volume. At about 4/3 volume the added harmonic distortion is completely gone. So while this is a strange thing, it's not really a problem to me.
It may have something to do with the headphone output and RCA line outputs always being active. Usually when you plug in headphones the line output mutes, this does not happen with the DA9.1
I also measured the THD+N best as I could. Used an E-MU 0404USB for this. Could only get a decent measurement when I used the optical output of the E-MU into the DA9.1 and the analog output of the DA9.1 into the line inputs of the E-MU. When I used the USB input of the DA9.1 and then line out into E-MU line in the measurement was lifted in the middle, probably a timing error? Had to use the E-MU for both input and output in the software. Used VIRTINS Multi-instrument for the measurements.
I measured about -105dB for the 3rd harmonic distortion. The other harmonics were lower. Noise was well below this.
Also measured a Sabaj D4 which I loaned from my little brother for a day. It has about all harmonics at about -100dB and a slightly higher noisefloor than the DA9.1
I didn't figure out how to measure channel imbalances and linearity yet. However I did a subjective test with headphones and mono music using digital volume control down to -90dB and headphone volume on the DA9.1 at max and I could not hear any drifting to the left or right, the music stayed dead center.
I did however hear severe drifting left and right at the very minimum settings of the analog headphone volume control of the DA9.1 however this was only at the very minimum for any normal low volume use the stereo image was stable.
I also found that the Amanero Directsound drivers are not great on my computer (windows 10). At time there were pops and ticks, about once a minute perhaps more often even. Also could see this in the measurement window when I tried out USB through directsound.
However the Amanero ASIO driver is rock solid for me. I see in the review that this driver wasn't used but ASIO4ALL was used instead?
The official drivers can be downloaded here: https://amanero.com/drivers.htm
And now for the subjective part..
I was fully expecting to send back the DA9.1, untill I started listening and also comparing to the Sabaj D4 (AKM chips) and HifiMe 9018D (ESS 9018 mobile chip).
I can put it very simple. To me the DA9.1 is the best DAC I think I have ever heard
It is better sounding than the Sabaj D4 and HifiMe 9018D. The Sabaj D4 has less detail especially in the trebble / with fast transients and it sounds less natural. The Sabaj appears to have more bass, at least mid bass. But it doesn't have a fuller sound overall, the DA9.1 does to me. The DA9.1 also appears to have more sub bass, and more contrast throughout the frequency range. The Sabaj D4 doesn't sound harsh at first to me but it is somewhat harsh compared to the DA9.1 don't know how to describe it. Sabaj sounds dynamic but with perhaps some exaggeration through distortion on the dynamics or something. Really don't know the words to describe the difference in sound..
And the 9018D can sound a bit thin and harsh as well in comparison the the DA9.1. Again I find it hard to describe the differences in sound.
The biggest difference to me is the transients with a lot of high trebble. I'm noticing certain percussive sounds in records I'm very familiar with that I didn't notice before. The contrast is just bigger there.
So I'm actually not sending it back and am happy with it despite the bad measurements here..
Btw, about -105dB for the 3rd harmonic isn't that bad is it? I'm reading it's about -115dB for the OPPO UPD-205? That's only a 10dB difference?
What I'm also thinking is that perhaps the harmonic distortion and channel imbalances are at low enough levels that they do not degrade the sound quality in any significant way.
Intermodulation distortion and crosstalk are perhaps worse types of distortion and the DA9.1 meaured pretty well in those areas?
And I can't help but talk about what is not being measured. The what I've come to suspect from experience is a fairly audible difference between DAC chips. Perhaps there is a part of the sound of a DAC chip that is not measured in linearity, harmonic distortion, intermodulation distortion and crosstalk etc. I suspect DAC chips do something to transients perhaps.
The DACs I've owned in the past: Lavry DA10, and old Mytek (can't remember the type), Violectric V800, Lehmann (forgot type and not even sure about the brand, expensive and didn't like it), Yulong D200 and many other cheaper DACs. Most of these are old and surely measure bad even though they were expensive in their day. And at least the Violectric should measure well. But the one that stuck in my mind was the Yulong D200. It must have measured quite poor I think it had a weird output stage and you could hear the music was "excited" as in having distortion in a pleasant tube like manner (but strangely enough also rolled off trebble). But still there was something in its sound that was great, it had a lot of detail and contrast in a very musical way. Not "overly dynamic" yet "empty" in a way like most DACs. It has an ESS 9016 chip (full version not mobile). And I hear a cleaner version of the D200 back in the DA9.1
Perhaps it is worthwhile to think of an extra measurement for transients or something in that area? And if not transients then what else could be it? A lot of people seem to think they hear differences between DAC chips. Of course implementation matters a lot and of course the measurements as they're being done here matter a lot. But I can't help but feel something is still being missed. Especially now again when listening to the DA9.1
Oh and btw, one last thing about the DA9.1. When I first plugged it in it had a bit of noise from the headphone out at max volume and no music. Was inaudible on my DT1990 with the volume turned a bit back so no real practical problem yet I still didn't like it. And strangely enough it was completely gone after an hour or so and hasn't returned since (about a day now). Now it's pitch black with the volume turned to max. Still a little bit worrysome.. Hope it doesn't return.
And one last thing. Can really recomend the DT 1990 Pro headphones from Beyerdynamic. They need some EQ though, at minimum to lower the resonant peak at about 8kHz by a min of 6dB. Still experimenting with EQ curves in general to fit my preference. But so far I like the EQ-ed DT1990 more than the HD800 overall (without any EQ the HD800 wins though for me).
?PSOOOC.
Ah, I thought you were going to keep it. Regardless, thanks for confirming some of my findings.So I'm sending the DA9.1 back. Seems like there is no budget ES9038Pro DAC that performs precise enough. Will probably go for a Topping D50 + good headphone amp.
