Review and Measurements of Mytek Stereo 192 DSD DAC
This is a Review and detailed Measurements of Mytek Stereo 192 DSD "mastering grade" DAC. It is on loan from a kind member and was released back in 2012 or so. Its market focus was for mastering engineers and hence that adjective. The retail price was $1,700 at the time. Someone should advise what it goes for used market today.
The unit won't win any beauty contests:
It screams old school with that 7-segment display. Machining looks hobbyist although the unit is quite heavy.
The unit strangely supports both USB 1.0 and 2.0 using independent inputs. Plugging in the unit didn't result in it working so I had to install its driver package which gave me the ASIO interface I need for my Audio Precision Analyzer to talk to it over USB. Alas, selection of Mytek ASIO driver would lead to the AP software crashing no matter how many times I tried it, or plug and unplug the USB cable, power cycling, etc. Oddly fortuitously, the ASIO4ALL software layer over the Windows driver worked and that is what I used for my testing. If you all want proof of why I hate installing drivers, here is another example.
For all of the measurements to follow, testing was done over USB and balanced output unless noted otherwise. For comparison, I pitted it mostly against Benchmark DAC3 which retails for over $2000. And of course it is a much more modern design.
Measurements
Let's start with our usual dashboard measurement:
This is respectable performance although as noted, I had to dial down the output using its volume control at -3 dB. Otherwise its performance would degrade.
Here is unbalanced output performance with level again reduced to nominal 2.0 volt that is common for that:
Overall SINAD numbers are pretty good. Here is the comparison to other units tested:
Let's dig into our 1 kHz response and see what we find as far as distortion and noise:
We see substantially higher second and third harmonic distortions. But then it skips a few and picks back up by 7th harmonic. All of this will either be mostly masked or be below threshold of hearing so audibly is not a concern.
While looking at spectrums, let's see how it does on jitter and noise:
We see that the noise floor is a few db higher than DAC3. But we also have fair bit of spikes around our main tone and a pair of symmetric ones likely indicating jitter. So definitely not as clean as it should be.
Next let's drill into harmonic distortion+noise versus frequency:
Low frequency noise or distortion rises which can be improved by dialing down the volume to -3 dB but it is no match for Benchmark DAC3.
The oddest results came in intermodulation distortion:
This is quite disappointing. We see a rise in intermodulation distortion at around -40 dB level and stays that way more or less until the output stage starts to saturate at -10 dB and distortion then rises again.
Last but not least is everyone's favorite, linearity test:
Here, I show both balanced and unbalanced performance. While I would like to see less variations toward the end, performance nonetheless is as good as it gets at -120 dB.
There are some oddities in the performance of Mytek stereo 192-DSD in intermodulation and at full level. Other than that, the measurements are very good and little to complain about. Because of the need for drivers and potential incompatibility with playback software I can't really recommend the unit. Given how old it is, you could face a situation where a future OS requires a driver and Mytek chooses to not provide it. If you are OK with this, I am not going to complain about you buying it. :)
If you like this review, please consider donating funds for these types of hardware purchases using Patreon (https://www.patreon.com/audiosciencereview), or upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
pos
Thank you for that review Amir!
Did you run any test on the digital inputs?
As the USB driver might become obsolete it would be interesting to see how it fares, especially when it comes to jitter.
Also, IIRC the unit does have internal jumpers and menu settings to set 0dBFS output level.
Those might have an impact on full scale distortion.
I did not. Tell me one measurement you like to see over digital input and I will run it.
On levels, there are settings in the menu but I was not sure if they just provided the attenuation the volume control provided.
pos
Jitter?
I think these act on the analog output stage.
The internal jumpers definitely do.
These seem to go for the same kind of price as a new DX7S go.
Dialectic
a fortified compound
Any plans to measure headphone output impedance?
Here you go. In green is the AES balanced digital input overlayed on top of red for USB:
The one jitter component is gone but it is replaced with a few new ones around the main tone.
Here you go:
The output is very anemic by the way. Only 1 volt at 300 ohm. That is just 3 milliwatts of power. So doesn't look like much attention was put behind the headphone stage.
restorer-john
The volume control is a digital attenuator ahead of the D/A or after as an analogue control? So we have yet another D/A converter that has issues at or near 0dBFS?
PS, You are clearly a sailor/boat person. Port and Starboard colours on your AP channels. Incidentally, my Dad's old Empire turntable RCA leads have the red/green, port/starboard, L/R designation popular in the 1960s before the strange (Japanese?) White/Red reversed it.
It can be either analog or digital. I left it in digital state. But yes, the last Mytek I tested clipped at 0 dBFS. Company designer said that was because of the MQA pipeline they had added (even though I was not testing MQA content).
MPA1
Thank you very much for this review Amir!
I still really enjoy this dac and still after 6 years I couldn’t part with it.
About the future of this dac: it is still very much useable through FireWire which is imo the best sounding input. USB is a nightmare indeed:rolleyes:.
I currently use it with a butchered fanless first gen intel Mac mini as naa through FireWire.
Is it possible to test the FireWire input?
Dialectic
No because Amir kindly sent the DAC back already, and I doubt he has a computer with FireWire out anyway
I actually have a firewire card in my desktop machine. I use it to capture video from my older Sony camcorders.
Dialectic
I bought a FireWire card myself, when I was convinced that FireWire might "sound" better. Sadly, the Mytek's Windows FireWire drivers are almost as unstable as its Windows USB drivers.
MPA1
I think I sent it back already.
oh that's too bad, thanks anyway. unfortunately I found you're review two weeks too late, wouldn't have thought I would find a review 6 years after its introduction. but better late than never:)
oh wow now I would be really interested in the outcome, im very sorry for you that you had that experience:rolleyes:.
I never had any problems with firewire, but then again I use a Mac that has them straight on the mobo. edit: which has nothing to do with your problems.
Blumlein 88
In regards to Firewire, I've got a really old Dell that had Firewire, and it is stable in the sense it always works. However, it can cause high jitter, or let computer activity show up in the couple of firewire DACs I've used. It's almost as bad as a Modi on USB. This is over 3 versions of Windows so its not a Windows issue. OTOH, I've got merely old Lenovo with Firewire, and it is golden. Jitter is very low, and no interaction I've found between computer activity and the output to a DAC.
I've still got one Firewire interface with nice ADC/DAC someone could get really cheap if they have a use for it. TC IMpact Twin.
Karu
I currently run the following chain: Roon->Eero->Digione Sig->Coax->Mytek 192 DSD->Wyred4sound mAmp x2 via balanced-> KEF LS50 + Rhytmik sub from the Mytek unbalanced. I understand the headphone amp is poorly implemented on the Mytek; and from my experience the USB 1.0 input is popping and therefore for me unusable direct from Nucleus via USB - also the unit is unsupported software wise and Mytek is not able to do anything about it (I asked), finally I found coax via Digione works reasonably well for me. But I keep having them also the doubt how well the amp is done, so would changing to the RME ADI-2 bring an improvement in sound?
