• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
Review and Measurements of RME ADI-2 Pro (comparison to ADI-2 DAC)
#1
This is comparison review and measurements of RME ADI-2 Pro against the RME ADI-2 DAC. The former has both analog to digital conversion in addition to digital to analog. I purchased that combo unit because I hope to make use of its ADC for measurements in the future. According to RME, ADI-2 DAC has some additional refinements in design which they say are not measurable. Well, I hope to measure them. :)
I purchased the RME ADI-2 Pro by contacting RME in Germany/US and received kind accommodation pricing. With the retail price of USD $1,999, even with my discount, it is still pretty serious amount of dollars. The RME ADI-2 DAC which I reviewed earlier, comes at a much more reasonable price of $999.
Physically the units are almost identical as far as size and general design:
The rear of the unit is much improved though. Due to lack of space, connections such as S/PDIF on RME ADI-2 Pro are relegated to a dongle which sports rather pedestrian cable and connectors:
Yes, we are not big on differences between cables in this forum but still, at $2,000 one expects a bit more polish here.
On the RME ADI-2 DAC, space is freed up due to not needing inputs and everything has nice jacks on the back of the unit.
For same reasons, inclusion of options for the input makes navigating the interface even more complicated than it is on RME ADI-2 DAC. Yes, you can get used to it and "auto" mode helps but still, this takes some getting used to. Repurposing the I/O button to simply cycle through inputs would go a long way toward making the unit more friendly to use.
For this review, I am focused only on the DAC portion of RME ADI-2 Pro. The RME ADI-2 DAC is being returned tomorrow to its anxious (but patient!) owner so this is my last chance to see how they compare against each other.
Let's get into the measurements and see how these two products compare. If you are not familiar with my tests, I suggest reading my tutorial on audio measurements here: https://www.audiosciencereview.com/forum/index.php?threads/understanding-audio-measurements.2351/.
Measurements
Unless noted, all measurements are via S/PDIF input. To add more information to the review of RME ADI-2 DAC, I performed all of these tests using balanced output. So the results are not directly comparable to the review of that unit.
Let's compare jitter and noise using J-test signal at 24 bits, 48 kHz sampling:
The results are identical (including a pair of jitter sidebands) except for broadening of the shoulders of our main 12 kHz tone. This indicates there is random, low frequency jitter in RME ADI-2 Pro which does not exist in RME ADI-2 DAC. Due to strong perceptual masking, definitely not an audible problem but a sign of a clock source that is polluted with noise. Seeing how I plan to use the ADI-2 Pro as my reference/benchmark DAC, this is problematic.
If you look at the picture of the RME ADI-2 DAC, you see there is an "FS" after its name. I understand that may mean a "femtosecond" clock which is now also available in ADI-2 Pro. While accuracy of clocks is of no consequence in sound reproduction, if this new clock has lower random clock, it may be the reason the DAC version does better. And would fix this issue just the same in Pro version. I have to inquire from RME to see what is going on as I don't see any references to FS or femto clock on their website as of this writing.
Thinking the above may be an issue with S/PDIF input, I also tested USB. The results were the same.
Unfortunately this theme continued during the test of the tests. Let's look for example what happens when we feed a 1 kHz -3 dBFS to both DACs and then filter it out and see what is left over (all noise/distortion):
RME ADI-2 DAC vs ADI-2 Pro 1 kHz noise and distortion Measurement Comparison.png
Wow that is quite a difference. Strong odd harmonics are all but eliminated in ADI-2 DAC.
Let's look at static linearity of the DAC by how well its analog output tracks the digital values fed to it:
We again see a degradation in ADI-2 Pro. Thankfully the response stays sane all the way to -120 dB so strictly speaking still quite good. But it simply lacks the precision of ADI-2 DAC which is at the limits of my measurement gear.
Intermodulation distortion was not as revealing of differences:
RME ADI-2 DAC vs ADI-2 Pro Intermodulation Distortion Measurement Comparison.png
But THD+N versus frequency was:
There is 4 dB less distortion in the critical mid-frequencies.
Note: the ADI-2 Pro was running at +19 dBu which produced the correct 6.9 volt output. The ADI-2 DAC however, was run at +13 dBu which produces slightly lower output at around 6.8 volt (from memory) which is incorrect. Maybe it needs a firmware update. Regardless, I tried matching the levels by dropping the volume by 0.5 dB on ADI-2 Pro but the results did not change.
From the measurements, it seems clear that the RME ADI-2 DAC is very much improved over the ADI-2 Pro. This was unexpected. For audiophiles this is good news seeing how the DAC version is much cheaper anyway. For pros though, it seems like a loss to have a less performant DAC in the ADI-2 Pro subsystem.
This leaves me personally in a quandary of not having a reference class DAC when I return the ADI-2 DAC to its owner tomorrow. :(
If you like this review, please consider donating funds for these types of hardware purchases using Patreon (https://www.patreon.com/audiosciencereview), or upgrading your membership here though Paypal (https://audiosciencereview.com/foru...eview-and-measurements.2164/page-3#post-59054).
#2
Great review and breakdown Amir!
It would seem reasonable that RME would want to put their best foot forward. While this model does very well, I think we all want to know how the FS version measures in comparison, which means that they should probably let you exchange it back for the FS model (hint, hint RME... ;)), which I would wager has updated circuitry along with the femto clock.
#3
Thanks you Amir! It is likely balanced output add more distortion and noise? Reading one of Douglas Self's book, I remember he spend extra efforts just to match the balanced audio to un-balanced (using parallel opamps to reduce noise etc)
Purité Audio
Industry Insider
Barrowmaster
Patreon Donor
London
#4
Apparently design improvements from the ADI DAc have been implemented in the ‘FS’ ADI PRO.
Jinjuku
Patreon Donor
#5
Purité Audio
Industry Insider
Barrowmaster
Patreon Donor
London
#6
Not really bullshit though is it, just claiming improved performance which Amir noted from his measurements.
Jinjuku
Patreon Donor
#7
How do I know the improvement is due to the femto clock? At $999 I can't complain. I just see it as marketing.
The performance still speaks for itself.
Purité Audio
Industry Insider
Barrowmaster
Patreon Donor
London
#8
It probably isn’t the clock might just be part of the revision, ‘if’ the New ‘Pro’ matches the excellent measurements of the ‘DAC’ that can only be a good thing can’t it?
Dro
#9
Thank you for this review. I did not expect such a "big" difference in jitter performance. Hopefully you also get your hands on the FS revision.
#11
Very happy with my ADI-2 DAC so far. For me the killer factor over the ADI-2 Pro was simply the remote control and lower price (I actually use a programmable Logitech Harmony with it). But I'm happy it measures so well too....
έχω δίκιο
Patreon Donor
#12
"Yes, we are not big on differences between cables in this forum but still, at $2,000 one expects a bit more polish here."
I agree. Those look like the stuff they used to give away with low-end cassette decks in the 1980s. For a product at this price point aimed at a pro market, I'd have expected cables and connectors which were mechanically robust and high quality. It's not primarily about sound -- it's about longevity and reliability. That said, I question whether those cables even have adequate shielding for the application.
RayDunzl
Central Scrutinizer
Riverview, Fl
#13
#14
That's exactly what they remind me. Most throw-away cables are actually better looking than these. My plan long term is to make my own dongle with proper cables and connectors. This being S/PDIF, it is doubly strange that they chose to put it on a dongle this way.
έχω δίκιο
Patreon Donor
#15
I'd go with an external, metal connector box with chassis-mount XLR and RCA connectors, interfaced with a straight-through D-cable to the main unit (for all of the reasons I'm sure you already recognize).
Dro
#18
How did the linearity of the ADI-2 DAC go from 19 (ADI DAC review) to 20 (this review) bits?
#19
This is balanced output, the other measurement was unbalanced.
Regardless, at that level there are run to run variations due to such small voltages and impact of noise.
I also am undecided about rounding vs not. :)
