έχω δίκιο
- Joined
- Apr 20, 2018
- Messages
- 249
- Likes
- 282
Tank you.Tere you go.....
Great newsAt the risk of putting this thread actually on topic, Topping quickly responded to my email and sent me the original firmware by email.
I can confirm that the unit can be flashed back AND it now works again with my Nividia Shield TV.
And now back to sexual shenningans...
My Topping D10 arrived today from Amazon. As I removed it from the protective sleeve, I heard a rattling in the case. Great.... So I removed the back panel and out came a blob of hot-melt glue. It had come loose from the board where they use it to tack it to the side of the case after sliding it in.
After putting it back together, it came right up. I'm listening to Janis Joplin as I type this. I love the display. The DAC output is dead-silent between tracks. It's replacing an ODAC (first generation). Were I a subjectivist, I'd say that this sounds significantly better. But I'm not, so I won't trust a non-blind listening session with all of the expectation bias that comes from having read a thorough instrumented test. But I am very happy with it.
I have the Topping D10 feeding a Parasound Zamp v.3. That drives a pair of Pioneer SP-BS21LR speakers. The Zamp has a pass-through for the analog, and I've got that going to an old Sony SA-W101 powered subwoofer. It's a bargain system, but it sounds very good, especially with the Pioneers acting as near-field monitors.It matches well with the O2. I have my O2 velcro wire wrapped to it.
https://audiosciencereview.com/forum/index.php?threads/my-review-of-topping-d10.3303/#post-81153
Nah. If you are happy with it, stay with it.I have a d10 and was wondering if there is a big difference between that and the d50? Thinking of replacing it but not sure if its worth it.
Also nice to not have to deal with a separate power supply with the D10.I have a d10 and was wondering if there is a big difference between that and the d50? Thinking of replacing it but not sure if its worth it.
Separate power supplies can eliminate problems with dirty USB power from some motherboards.Also nice to not have to deal with a separate power supply with the D10.
That's excellent. Welcome to the forum and thanks for the kind words by the way.After reading this thread about firmware release, I immediately upgraded D10’s firmware. Mine starts with 1804 sn. I can confirm the problem is now gone completely.
I have a 1802 serial and hadn't ran into issues with my D10 resetting or locking up for a while, but figured I would apply the firmware update anyway. I was running revision v6.F2 and it still shows the same after running the update utility and power cycling the unit. I suppose that the firmware was applied as I received a successful message from the update utility, however I can't reliably reproduce the issue so I'm unable to validate that it was indeed fixed.
Maybe try again. I'm not sure how good their English is and perhaps you will get another person or maybe they misunderstood.Interesting. They told me the DX7s firmware update (same USB firmware update) can't be reverted. Not very happy with their service.
