jaytrinitron
- Joined
- Jan 27, 2018
- Messages
- 40
- Likes
- 4
Are you a bat or a dolphin? If so, kudos on your typing skills !
If you're referring to the "hump" in the IMD graphs, then no, I would not expect that to be audible.
What do plan on pairing the D50/Dx7s with for amplification?
That roll off is supposed to be there - it's the anti-imaging filter. That is the DAC filtering out frequencies above 1/2 the sampling rate (I think a 24 bit, 44.1 kHz test signal is used here).
Thank you. Ok, so the roll off should be there, makes sense to filter out those frequencies. Yes, I thought the "hump" was detectable distortion. New to this audio thing and not sure what all of it means but I read elsewhere that the ol dac was superior to the d50 (based on Amir's measurements) because the d50 had higher distortion, and that was the only metric that a listener could actually hear. For amplification, I haven't decided yet. Definitely something transparent, sort of thinking about the massdrop thx aaa amp, depending on how it measures.
Oh also, will Amir ever do linearity measurements for the umc204hd? And does anyone know how variable the performance between units is?
