Hello All! I got my D50 from Mass Drop but, of course, had to wait for revised shipping date. Given the info in this thread, I hoped that the wait was because MD was getting a revised version that solved earlier problems. I have had zero hum or noise from the start. Finally found the option to change the screen to go off after 30 seconds, used to just stay on. Still have no idea what all those filters do. Am using the ' Brickwall' one but to me sounds just like the first filter which was default. I bet the manual is good if you read Cantonese. Because my laptop has limited USB ports I plug it into my docking station for power. Once again no noise. Note: the laptop is plugged into one surge strip and the docking station is on a different surge strip.
Now about the heat questions. I took out my handy IR temp pistol and started a log when I got home yesterday. Was at work so A/C was off. Starting was 86.4 F, first hour of use went to 91.2 F. After 4 1/2 hrs. steady temp was 98.3 F in the center of the block, near the RCA outputs it was 89.7 F,
Is this hot or just operating temp? I don't have it stacked with anything.
One more thought. I have the Db meter at 00.0 because that's what Amirm used for tests, if I use the toggle and put it into plus Db's is this amplification of the signal to my pre amp?
One last thing, it is a joy to find this forum, where we can talk about what a piece of tech can do and can't do. Not how it makes you feel about yourself.
