That is true, but all those defaults settings are the same settings available on the remote.If you hold in the volume button on the unit when powering it on the unit goes into a setup menu. This menu seems to allow the user to manipulate default settings to some degree. Navigating the menu does not work with the volume wheel or any of the IR commands provided to Harmony - Topping did not provide any IR commands that offer direction such as up or down.
Edit: Except for the factory reset setting, which can only be done using the volume button on power-up, AFAICT.
