Review and Measurements of Topping NX4 DSD Dac and Portable Headphone Amplifier
RayDunzl
Central Scrutinizer
Riverview FL
I have bought the parts but have not yet built the cabling to measure balanced. With Michael coming this week, measuring the Benchmark DAC3 will be a priority. After that I will try to free up some time to build that.
You're not going to measure the DAC3 balanced outputs?
He was asking about balanced headphone output which has a 2.5 mm four segment connection. Not the normal balanced line output of the DAC (which these don't have).
RayDunzl
Central Scrutinizer
Riverview FL
My mistake...
Carry on.
Jimster480
Tampa Bay
Amazon lists the delivery time as July 10 to July 31 or 3 to 6 weeks. I suspect the vendor gathers orders and can't move ahead until he has a certain amount. With a lot of this Chi-fi stuff, if it breaks, it will not be worth the effort to get it fixed. That's not a disaster on a low priced item.
Well supposedly you can mail it back to them and they will fix it. I haven't had any of my Topping stuff break (thank God) so I don't have the insight into that process. But I can tell you the support is very responsive and they are overall very nice and even the support can get technical.
Guermantes
Brisbane, Australia
Nice to see the NX4 measures well as an amplifier as I've had my eye on the Topping NX5 to pair with my audio player. Hopefully it is even better.
mindbomb
On the first few tests where there isn't a load mentioned, does that mean the test was done on the line out or the headphone out? If line out, does this mean the gain switch and volume control affect the line out voltage? Also, the frequency response showing the drooping is on the line out with no load?
The combo THD graph was with loads ranging from 300 ohms down to 33.
Labeling them is tedious so I didn't. :)
dc655321
I believe the review states that the headphone out was used for all measurements as being representative of the biggest use-case.
I have not used the line out, but it's my understanding that if the usb port and the line-out are occupied but the headphone out is not occupied, then the gain and volume have no effect. Could be wrong though...
dc655321
Measured output power as indicated on the graph is about half of what Topping specs I think.
@amirm, I think your measurements are almost spot on what Topping have included in their specs (57 mW @ 300 Ohms, 150 mW @ 32 Ohms).
I believe they have an "off-by-2" error in their listings (counting the sum of both channels).
Was also curious: are you set up to perform cross-talk measurements?
I feel that this is an important performance parameter, and is often overlooked.
mindbomb
@amirm
so was the frequency response measurement done with 32 ohm load? If the low frequency roll off is from output capacitors, I'm wondering if that will get better with use of higher impedance headphones.
zenmastering
Yep, that's how the line-out works. There's one plugged in to my mastering console and the internal level control is disabled in line-out mode. I have the NX4DSD and the D50. In comparison, the slightly softer top-end of the NX4 seems to be explained by Amir's test results.
Great. Nice to see them advertise correct spec.
Yes. When I get a chance I will run it. I am still doing these tests manually rather than automating them. With the later, I should be able to run all the tests easily.
@amirm
If you had asked me yesterday, I would have remembers the answer. But today I have already forgotten. :) If I get a chance I will re-run with different loads.
