Review and Measurements of XDuoo TA-01 and Schiit Fulla V2 DAC and Headphone Amp
Frank Dernie
Oxfordshire
Many beloved recording people listen to are produced using tubes. Many of the classic microphones also use tubes. Tubes are not just distortion producers. The distortion is below the threshold of hearing. The spectrum of distortion and overload characteristics are different.
Tube microphones are chosen when the particular distortion of tubes is wanted by the recording engineer to get the effect he wants. Tube distortion is sometimes below audibility. Choosing to use tubes at home, in many implementations, is to add some effects to the sound you like, very, very different from the recording engineer's reason to use them.
Theo
I don't get it. Everything which brings a "colour" including overload/saturation, or whatever you may call it, is actually changing the input signal, which is the definition of distortion : "falsified reproduction of an audio or video signal caused by change in the wave form of the original signal"
And if it is below the threshold of hearing, how can you hear it?
rebbiputzmaker
You are basically repeating false narratives attributed to vacuum tubes. Just like any other active device tubes exist in a circuit, not alone, hence one circuit can be made to do something or sound different from another. This is not just the active device, it is how it is used that can cause differences people speak of. For people to fully understand audio electronic IMO they need to understand vacuum tubes. I feel sad for engineers that don't.
Wombat
Australia
Tube rolling is a form of random 'tone alteration' expectation with no consideration to particular circuit design parameters. Tube bias conditions are ignored/or not understood. Affects in one circuit are unlikely to transfer, similarly, to another item of equipment yet audio forums attribute generalised 'sonic signatures' to various tubes.
rebbiputzmaker
Good point, but don't you think the overload characteristics and transient capabilities, not just "effect" can be a factor also? I do not consider a U87 colored.
As far a power amps one example; tubes may drive reactive loads better. This can be advantageous for some speakers. Generalities are not ideal, but IMO there can be advantages and disadvantage with all forms of technology. They should not just be dismissed as antiquated and useless.
rebbiputzmaker
Circuits that do not have adjustable "bias" are self-biasing.
People can, and do the same with SS devices, it is just not as prevalent. Most op-amps are rectangular so they cannot roll.
Wombat
Australia
Wombat
Australia
A circuit can be self biasing but the biasing set-up can be different for other ccts and other tubes. Changing Re(or other component values) on cathode bias ccts changes the operating point which can be more suitable for a different tube . The self-biasing maintains a bias condition only for the chosen circuit values. These conditions do not necessarily match all random tube swaps.
Theo
My comment is not specific to tubes. It is just stating the definition of distortion which is : altering the input signal... So yes, if a tube changes the waveform, this a distortion of the input signal. That is just THE definition. There is no judgement of value here as distortion is not necessarily a bad thing (as in guitar amps)..
έχω δίκιο
That's the difference between music production and music reproduction. In music production, one is attempting to create a pleasing sound and that is often achieved through euphonic distortion, non-linearities, etc.
If that were the case, then you would not hear differences by changing from Mullard to Sylvania to Svetlana tubes of the same type. You can't have it both ways; that you can hear differences between tubes but tube distortion is below the threshold of audibility.
έχω δίκιο
Tubes can't drive speakers at all, which is why you need output transformers on tube amps. It's those output transformers that lead to tube amps having a low damping factor and interacting with reactive loads far more than do good solid state amplifiers.
rebbiputzmaker
There are OTL amps. Harold Beveridge actually built a speaker with a dedicated OTL amp.
rebbiputzmaker
Tube guitar amps also rely on tube microphonics to create a kind of feedback loop which also helps with "tone".
έχω δίκιο
I am aware of OTL tube amps, but it's like saying that bicycle tires are suitable for cars -- you just need lots of them in parallel. The Atma-Sphere S30 Mark 3.2 OTL tube amp produces 30 watts per channel into 8Ω load and needs five output tubes per channel to do it, drawing 400 watts of power from the AC lines. They are serious about requiring an 8Ω speaker, with their manual warning not to use any speaker that drops below 8Ω at any point (almost all 8Ω speakers dip well below that). From their manual:
Atma-Sphere said:
The amp will give its best performance on 16 ohm speakers. If using an 8 ohm speaker, it is very important the speaker exhibit at least an 8 ohm impedance at all frequencies. In any event, the speaker load should be one known to be easy to drive. Speaker cables can have a rather dramatic effect and you are invited to experiment.
So, technically, tubes can drive speakers in the same way that, technically, mopeds can tow boat trailers -- as long as you have enough mopeds connected to a shared trailer hitch and the road is absolutely flat and you don't mind their inability to deal well with that large, reactive load.
FireLion
I kinda am starting to love tubes. I had this $7 Sylvania which is gritty and bassy in a good way and popped this NOS RCA and tonal differences are apparent instantly. A little clearer but still nice and warm actually really like it and it was $15. It's almost like having a different amp with each tube.
It's nice to tube roll and my two xduoo's aren't bad and I am very happy with them.
Frank Dernie
Oxfordshire
The problem with valve power amps isn't just the valves it is the output transformer. There are probably no transformers which perform well over the entire audible frequency bandwidth since what is required for good performance at low frequencies may compromise the performance at high frequencies and give early roll off. Having written that, even solid state stuff with inter stage transformers can sound "nice" so maybe the distortion/ addition/ removal of some of the signal by a transformer is something people like????
It isn't high fidelity though.
έχω δίκιο
There are no non-inductive output transformers, either, which means that even if the transformer were to have linear frequency response into a purely resistive load, it's not going to be linear into a reactive load like a speaker's crossover.
...so maybe the distortion/ addition/ removal of some of the signal by a transformer is something people like????
Many times people use various components as tone controls to offset everything from room acoustics to speaker non-linearities. One thing I noticed early on in the CD era was people complaining that CDs sounded "thin" and lacked "warmth"; on their systems, their LPs sounded better. They had tuned their systems around a turntable that picked up bass microphonically through the air and through the floor. If they had a truly linear frequency response, the turntable would have had a boomy bass due to that bass feedback loop within the listening room.
Frank Dernie
Oxfordshire
Very true, and also many popular cartridges had/have a rolled off top octave or more, so speakers to compensate for that sound thin with a flat source.
έχω δίκιο
Henry Kloss, of Advent and KLH fame, remarked that he made a tweeter with much better performance than what his speakers shipped with, but it exacerbated hiss, ticks, and pops to much as to be unlistenable. Interestingly, in the KLH 17 tweeters had a perforated metal grill adhered to them. Removing that yields a much more extended, satisfying HF response (with modern amplification and sources).
