예, 실제로 #3도 추천하지 않습니다.
어떤 사람들은 최소 위상 필터를 선호합니다. 그렇다면 최소 위상 필터 중 가장 좋은 필터 #4를 사용하십시오.
요약해서 말하자면:
필터 2 또는 6이 전반적으로 가장 좋습니다(둘 중 하나 선택).
인과/비대칭 과도 임펄스 응답이 있는 최소 위상을 선호하는 경우 필터 4.
Do you use tidal?
This is my playlist ^^
I want to be with you.
요약해서 말하자면:
Tidal이 아니라 Qobuz가 있습니다.
저는 주로 어쿠스틱 음악을 듣습니다. 클래식, 르네상스 등. 가끔은 블루스, 재즈, 블루그래스. 아주 가끔, 록 등.
내 재생 목록은 현재
23개의 클래식 앨범, 대부분 소규모 앙상블 실내악
2 Leo Kottke 앨범
1 다이애나 크롤 앨범
2 Ayreheart/Brian Kay/Ron McFarlane 앨범
1 톰 해럴 앨범
1 에릭 클랩튼 앨범
Agree on the volume knob, a little rubber like on my Nikon lenses would go a long way. Maybe there is some stick-on solution we could find and cut to size.
- you have to point the remote straight at the display for it to work. It would be better if the remote was less fussy and worked whichever direction you pointed it. Perhaps the transmitter is too low power or the receiver has too little sensitivity?
- volume knob should be more "grippy". Right now it's smooth so your fingers can slide a bit when you try to turn it. Also, maybe the knob is slightly too big? If you the device placed straight on the table it can be difficult to get a proper grip around it. Of course it's less of an issue if you have something placed underneath it so it's elevated, or you have it placed at the edge of the table so the table surface is not in the way. For me it's not a huge issue because I just use the remote.
48 kHz for Windows, REW, Voicemeeter.Btw what sample rate is everyone running at? Any problem in choosing 48000 Hz in Windows instead of 41000 Hz? What about 96000 Hz?
I watched nearly all of the YouTube reviewers and none of them said that.By reading reviews on the internet you can find out a lot of contradictory things about ex5 that I don't really want to believe (like non resolving, veiled sound??). Is there anyone with experience who could describe the sound characteristics?
THANK YOU for testing this. I could never figure out why the manual and Amir's measurements didn't reconcile. In short, ignore the manual and refer to this post.I measured my EX5 with REW sweeps to 22.05 at 44.1 kHz with each of the 7 filters. The names and graphs in the EX5 documentation are indeed incorrect as they do not match their measured responses. Measured responses:
Filter 19k 20k 22.05k phase 1 -3.3 -10 -40 +15, -150 2 0 / flat -1.5 -24 0 / flat 3 -3 -5 -14 +24, -84 4 0 / flat -0.2 -7 +210, 0 5 -2 -3.6 -9 0 / flat 6 0 / flat -0.3 -10 0 / flat 7 0 / flat -0.3 -10 0 / flat
Filter #2 is most correct. The manual calls it "slow minimum" but it is neither slow, nor minimum phase. Filters 6 and 7 were identical in my testing. They are a bit flatter and smoother than #2 in the passband, but they do not fully attenuate by Nyquist. The impulse responses were consistent with the phase; that is, the ones with flat phase had symmetric impulses, the others had asymmetric impulses.
For those who like pictures, here's what I measured:
Thank you very much MRC01 for bringing much needed clarity to this issue. The graphs and descriptions in the Owners’ Manual are confusing at best. Notwithstanding my affection for Topping products, I find it surprising and disappointIng that they have not seen fit to correct the obvious anomaly here. That said, like many ( most?) of us, I struggle to hear any difference between the various filter settings.…I measured my EX5 with REW sweeps to 22.05 at 44.1 kHz with each of the 7 filters. The names and graphs in the EX5 documentation are indeed incorrect as they do not match their measured responses. Measured responses:
Since i have returned ex5 and found that mini jack to cinch splitter i'm using has messed up channels (red is left!! haha) my impressions may had been wrong.I watched nearly all of the YouTube reviewers and none of them said that.
I would also not agree with it.
Granted, I don't have tons of experience with these kinds of devices, but I did compare it to a Schiit Modius/Magnius stack with my FiiO FH3's and I was not convinced there was a difference outside my own margin of error. And yes, there is a margin of error – going both ways – which is why I discount it. I also have a rather competent music and home theater system and I don't think the EX5 produces a veiled sound.
Thanks, but even trying that I'm still consistently getting the same behaviour. I've also since tried the EX5 connected to my laptop instead, which has an older version of REW and an older Topping driver (it runs Windows 7) with the same result, so I'm leaning towards it being a fault with my unit. I forgot to say that there's also a pop from the right speaker when I play something through the left speaker (even just through the left speaker) to get the right speaker working again, not sure if that makes it any easier to diagnose what's going on.
Edit: It does the same thing with the right channel of the headphone output as well.
I set up a pair of Genelec 8030C with an EX5 yesterday and encountered a slightly weird issue - when I used REW to run a sine sweep or play pink noise through a single speaker it worked fine with the left channel, but the right kept cutting out with a pop after three or four seconds of the sweep or pink noise, and wouldn't output sound afterwards until I played something through the left channel first. Initially I thought it might be a problem with the speaker going into protection (albeit at a relatively low SPL), but it still does it at very low volumes, and when I switched the other speaker to the right channel it had the same issue. I was able to work around it by running the sweep or pink noise through both speakers and shifting the balance all the way to the left or right in the Windows device settings, so I was wondering if it might just be something to do with the way I have REW set up rather than being indicative of a problem with my EX5. Has anyone experienced something similar?
I'm correcting each of my MTMs with the built-in DSP correction (one is in front of a wall, the other is in front of a bay window), then I'm generating combined correction with MMM and REW on my PC and applying with eAPO.That seems exactly it, thanks a lot! I'm reassured if it's just some quirk of the DAC chip that's easily worked around rather than a fault with my unit that could affect performance in some subtle way or cause problems later on. I'm still going back and forth on how best to EQ the speakers, right now I'm using separate MMM measurements for each channel (since one speaker is in a corner) and correcting up to 200Hz with no dip switches active, but maybe it would be better to set the dip switches as Genelec advise and perform the software EQ afterwards.
I just confirmed this with my EX5. When it is on the coax input, if there is no input on the L channel, after several seconds it auto-mutes both output channels. The time delay depends on the sample rate. At 192k it's about 5 seconds, at 44.1k it's about 25 seconds.... It appears to be a problem with the DAC chip automuting when no signal is detected on the left channel...
I use separate Left and Right measurements. I skip ARC and just use REW+PEACE.I'm correcting each of my MTMs with the built-in DSP correction (one is in front of a wall, the other is in front of a bay window), then I'm generating combined correction with MMM and REW on my PC and applying with eAPO.
The MMM method I followed measures both L+R channels at the same time, I don't know if it's a valid approach for correcting L and R separately.
There's some discussion of the approach and settings here: https://www.audiosciencereview.com/forum/index.php?threads/rew-moving-microphone-method-help.12641/
