Hello again.
I forgot to say that beside this, the amplifier gives great sound. I tested all inputs except phono. It has enough power to drive (a lot more than that) my wharfedale speakers. I really like the product but the problem described in my previous post is driving me crazy.
Best Regards.
Sounds like tinnitus, except you can turn it off!!
That's a bummer...thanks for the info.
Not sure I understand what You are telling. Let's see if the manufacturer will replace the board.
Nothing that would help solve the problem.
Simply saying that those of us who have 'Tinnitus' hear a constant noise that never goes away. In my case, I have about a 10khz ringing or whine...which sounds similar to what you are hearing. In your case, you can turn it off at least. I wouldn't want an amp that had a 'tinnitus' issue...my own can be annoying enough.
Dear friends,
Has anyone head this dac/amp?
Class D amp with some power on paper and double ak 4490 dac chips. Also has a headphone amp.
Cost about em 600 euros.
It is really small.
I wounder if it handles big speakers...
Indeed. Sorry for the mistake.It is a single DAC chip
Hi, mine arrived yesterday, I got it for 496 euros and had it shipped with China Post to avoid taxes. Il't took 3 weeks but at the end it was worth it as I don't have import taxes.
It replaces my nad 326 + topping d30 combo.
I juste tried for your hiss. I do have it but I must stick my ear on the tweeter to hear it. At 5 cm I can't hear anything. I have 93 db Davis acoustic vinci hd speakers.
You should check if your live is on the right side of your socket. Electricians usually don't pay attention to this detail. I found 4 sockets with the wrong side.
For the sound Itvis quite good. There is more details than the d30 for sure. I still need to get use to the new sound.
It seems quite neutral, vocals are good, a little lated back but vocal jazz (tested with Malia, album : black orchid) it is great.
I then put in buddy guy, same thing, detailed sound but it misses space. On my valve amp with the d30 I could hear buddy guy's breath befor and after each sentence, on the a8 it starts and stops instantly, it must be a class d thing.
Overall, it is a good complete system. I thing it should be used with less sensitive speakers, I personnaly have to set the output of the DAC to 50% in order to have a wide volume range, otherwise at 9 it gets too loud and 8 is too low. A test from audioscience review would-be in deed welcome.
Hello friend! Thanks for sharing this!
So I am not the only one. It's not only mine amp with this problem. I can confirm all this what You said about the sound but I also have to admit that their design is BAD. There should be nothing on the speakers when the input signal is silence even if I put my ear on the speaker. The cheapest FX-Audio D802 (100 EUR amp) gives nothing when there is nothing on the input. I am using this amplifier (SMSL A8) with Wharfedale Vardus VR400 (basic entry level floor standing speakers) and I can hear the sound in normal listening position while silence. Even my handmade amp gives absolute silence when I close my ears to the speakers.
What I noticed also is that the amplifier does not have regular speaker protection with relays. Instead of that they use mosfets (which may also cause the above mentioned problem) or so and therefore You can hear lite clicks when powering ON/OFF.
Message to SMSL... THERE SHOULD BE and absolute SILENCE on the speakers when silence is on the input. Stop producing A8 and make A10 with corrected design with relays in speaker protection circuit.
for the volume issue, it came from foobar, it seems it forces the output level. I passed on MusicBee and I can now set the DAC to 100% and have a good sound control. I don't bother with ASIO anymore.
I suggest using JRiver. Without ASIO You will not be able to use full potential of the DAC. If You need help with settings, just tell me.
The difference You are hearing may be the result of class D before the DAC and also may be the result of resampling if any in Your setup. I had this problem but now it has been resolved. AK DAC is manufactured by Asahi Kasei Microdevices and it is (if You ask me) a very good choice.
Best Regards.
well I skipped on Jriver as it is not a free app... After reading your post I fiddled around with MusicBee and activated ASIO (it was by default on WASAPI).
I would be interested on how you solved the sound issue I have. I Don't think there is any resampling, I use the same config as on my old rig.
best regards
