SMSL SU-6 Review (Desktop DAC)
This is a review and detailed measurements of the SMSL SU-6 stereo Bluetooth and USB DAC. It was sent to me by the company to be sold by Shenzhenaudio. It will cost US$169.99.
I really like the slick look of SU-6 with its white LED:
Yes, you can adjust the brightness level (I think there are four). The single touch button powers the unit and lets you cycle through inputs and settings. A remote control is provided to make that task easier. Back panel shows one of my favorite features: in-built power supply so no big dongle for that:
I think this is the smallest DAC with a built-in power supply.
SMSL SU-6 Measurements
As usual we start with our dashboard:
I expected superb performance and we have it, especially in one channel. Averaging the two still leaves a very respectable score as far as SINAD is concerned (sum of distortion and noise):
Zooming in:
Dynamic range (how noisy the DAC is) is right up there as well:
Multitone shows superbly low distortion levels:
Linearity is as good as it gets:
Intermodulation distortion and noise is very low as well:
USB Jitter and noise shows some negligible (and utterly inaudible) unwanted tones:
Switching to Coax input I initially saw a lot of jitter. But then remembered the options for Digital PLL (DPPL) so played with the 8 different ones in there to find the optimal one:
Typical trade off here is slow lock time vs performance. By slow lock time I mean if you switch sample rates, there may be longer delay before the DAC starts to play. Hence the adjustability.
Lots of filters are provided for you to play with:
Filter selection naturally impacts measured performance in our wideband distortion+noise test:
Yes, we all get bored with one more desktop DAC with great performance. Here though, there is innovation in packaging and styling which works very well. The SU-6 definitely made me smile when I first powered it on in this regard.
I am happy to recommend the SMSL SU-6.
Lambda
USB C can delver enough Power to charge a modern PC this needing an extra power supply makes no sense to me.
Performance is good I like the Design and that it has a Coax input.
But without balanced out this one is not for me.
Vini darko
Dorset England
Thanks for the review amir. That's a tempting dac. Does it have volume control? I like the selectable spidif locking , very good feature.
You would lose compatibility with millions of PCs if you try to power it using USB-C higher power profiles.
Lambda
So you can sell an extra USB hub and Power supply.
I know this is not part of typical ASR review but how mush power do modern DACs like this actually need?
What you you think, a few more months and this comes out in a balanced version at $199?
Unless they go with TRS jacks, it won't fit in this small box.
We know indirectly from SMSL producing a DAC without external supply. It worked great on Coax but not USB due to running out of power. It was said that the DAC itself could be powered by USB 2.0 but not once you added a display to it.
Budgeter
As this has digital in, a power cable is a good choice to go with other devices (TV, smart devices, etc). However, for desktop use, there should be an additional option for USB power IMO.
MRC01
Pacific Northwest
Wow, this looks like my next desktop DAC. Excellent sound, internal power supply, a display showing the current rate, and a correct filter at 44 kHz that is flat at 20 kHz and fully attenuated at Nyquist.
@amirm, any reason for the 3 dB difference in the channel SINAD?
I don't know. I often see that kind of differential. Sometimes one channel is more optimized as far as layout and connection to power than the other.
raif71
This DAC must be hot off the oven coz the SMSL website doesn't list this as their product yet. I was searching for what type of dac chip this unit is using.
restorer-john
Realistically, this D/A is just as good as the ones further up the chart. They get the extra dB from doubling the voltage (4V+) using balanced. This gets where it does with 2V out.
PhnomPenhPaul
Thanks @amirm for the review and congratulations on something I don't think I've ever seen before - your review of the SMSL SU6 is the only, and I mean the only, result that Google returned when I did a Google search [SMSL SU6]! As with @raif71 I wanted to know what chipset SMSL used [is it an ESS mobile chip or the Rohm used in their D300?] , but I guess until SMSL or Shenzhenaudio get it up on their web sites [or @amirm gets permission to open it up] I'll have to put up with my curiosity unsatiated. Like @amirm I'm really taken by the aesthetics of this little thing. I know I had a real whinge about the aesthetics of the display on the SU-9, but SMSL's latest offerings are much more to my liking with this and the D300 being very nice indeed. Really, for the price this is excellent and ought to be near the top of anyone's list looking for a sub $200 unbalanced dac. [Come on SMSL, stick some trs jacks on this thing and give the Topping E50 a run for its money:)]
