Wunderphones
- Joined
- Feb 1, 2021
- Messages
- 93
- Likes
- 115
Greetings, all. I’m a short-term lurker, first-time poster. ASR’s testing and discussion have been pivotal in the selection of a couple items in the new listening room I am assembling, and I’m hoping that the trend can continue.
Some background before we get to the “what DAC should I buy?” portion of the program:
Back when I was young, I was a rave DJ, and I still have the equipment. My stereo setup will differ significantly from a lot of people’s, because from the beginning I wanted just one workstation that could handle both active manipulation as a DJ booth and passive enjoyment as an audiophile listener. Below you can see what I have done. I built the cart back in 2010, but back then, I put the speakers on tall stands, making no attempt to position the speakers at an appropriate level for seated listening. Now, I have bolted the speakers on to articulated arm TV mounts, allowing the speakers to be positioned up for monitoring or down for leisure listening—an innovation of which I am unseemly proud.
Originally, the cart ran through a rack-mounted pro-audio Class D amp with a fan. Now, there’s a VTV Eigentakt there in that middle cubby. This Eigentakt business is the wave of the future, y’all. It’s a shame I couldn’t rack-mount that, too.
So, the original plan was to use the DJ mixer to send XLR outs to the amp, and feed the DJ setup into the mixer’s phono inputs, with the TV and my Roon client attached to the line-level inputs. Basically, the mixer was to be my preamp until I figured out what audiophile gear I might want in that role.
Unfortunately, feeding the line-level input of the DJ mixer with the Roon output was sonically awful. I was just coming out of the Raspberry Pi USB, through a Monolith thumb DAC, up through an RCA splitter to the mixer. And the hiss was terrible. Right now, I put a Schiit Jotunheim Multibit (my desktop headphone rig) in there instead, and that’s working out fine for now.
Alright, one last historical item and we’ll be caught up: the mixer went back to Amazon when I found out Pioneer wanted me to pay them $120 per annum to use the Rekordbox software. I will replace it with something else.
Directly upstream from the Eigentakt, I will need to be able to switch between the mixer and the Raspberry Pi, and to adjust the system volume. In short, a preamp.
Any mixer I would consider as a replacement will have balanced outputs that can be run into, say, a Schiit Freya+. And then I could run the Raspberry pi into a balanced DAC that would feed the other set of XLR inputs, and use the Freya+ remote to switch between the inputs and change volume.
But, if I get a more upscale DJ mixer, I can instead run a S/PDIF cable from it. And then, with just digital sources, I would no longer need a separate DAC and preamp. I would need a DAC that had easy input switching between S/PDIF and USB and a volume knob. (I know the knob isn’t technically required, but I’m not a fan of volume controls that only have buttons.)
Whew! With all that out of the way: what DAC should I buy? Balanced outs, easy input switching, and volume control are the key requirements, but Roon Ready, rack mountability, and MQA support are all big pluses.
