andymok
bandwidthIs that what might be called “slew rate” in an engineering text book? If not, what?
From 2006 - degradation detected.bandwidth
That makes even less sense than your previous ramblings.CD vs.SACD:
"In one PCM sample time where the CD version of a recording slews 30,000 steps, the DSD version of the same recording will slew 64 steps."
Music signal is random, not sine wave.what more do you actually want?
DSD 2.9 GHz = lossless PCM 44/16:That makes even less sense than your previous ramblings.
If your DAC (arbitrary waveform generator) cannot precisely reproduce single impulse, it cannot reproduce the stream of samples (digital music) correctly.
DSD 2.9 GHz 1bit = lossless PCM 44/16 and vice versa.
See page 9: https://www.xilinx.com/support/documentation/ip_documentation/xps_deltasigma_dac.pdf
Does an untruth, when repeated with sufficient frequency, suddenly become the truth or does it, like evolution, take a period of time?Music signal is random, not sine wave.
What does 1 DSD bit produce?
If their designs cannot reproduce music track or white noise in the DAC-ADC loop with accuracy after subtracting in/out 120 dB (true 20 bits in analog domain), their theories must be corrected.if you find yourself at odds with both Pluto and Mansr on a technical aspect of D to A conversion
Very small and short pulse, not necessarily the one that was programmed (saved) in the phonogram for an arbitrary waveform.What does 1 DSD bit produce?
Random = white noise.
Many modern D-S ADC chips violate Shannon Nyquist due marketing "optimisation" (freq. range 2-22000 Hz +/-0.001 dB @ 44100 Hz).So if you violate Shannon Nyquist
The last theoretically flawless audio ADC device for PCM was released in 1999:
Frequency response:
Fs 32kHz, 18 Hz-13,5 kHz:±0.1dB
Fs 44,1kHz, 18 Hz-18,8 kHz:±0.1dB - ugly for dummies!
Fs 48kHz, 18 Hz-20,0 kHz:±0.1dB
Fs 64kHz, 18 Hz-25,0 kHz:±0.1dB
Fs 88,2kHz, 18 Hz-35,0 kHz:±0.1dB
Fs 96kHz, 18 Hz-38,0 kHz:±0.1dB
http://www.digitalaudio.dk/media/1User_manual_2402.pdf
And no one has checked it on gearslutz yet.
