Understanding Balanced Audio (video)
I have been meaning to write an article for a while on what balanced audio means. Alas, have not had time so I thought I do a video on it instead. Hopefully for people who are new at this, it clarifies different things we call "balanced" and benefits it can provide:
Hope you find it useful.
phoenixsong
I like how the main points have been made simple and clear. Also, hopefully the explanation on balanced>unbalanced adapters at the end will save some people from destroying their equipment :)
Now I can't wait for a tutorial on input/output impedance!
Germany
Thanks for the great video!
I add this because i often hear people complain about the lack of XLR outs for example on home theatre processors:
You can convert RCA Outputs to balanced using just a single resistor. The most important part of the CMNR is the two signal conductors (3 wire cable) having the the same impedance. Measure your devices output impedance and connect the "-" with a resistor (value=output impedance) to rca ground. You do not get higher output but the noise rejection is greatly improved. For voltage gain and differential output you can use a dirt cheap DRV134 board.
As you mentioned in the video, differential is something different and often mixed up with balanced.
PeteL
Thank you. Very to the point and easy to understand.
Ismapics
Hello Amir: Thanks for another great video that installs knowledge (software) in our brains. Also illustrates that there are plenty of YT Reviewers that don't know the technical aspects and their reviews of these show. Can you consider a video debunking Directional RCA, please. In you do in that same one address using silver, vs copper. Cheers
sq225917
Differential, a signal that swings positive and negative in a mirror image on two separate signal phase.
Balanced, impedance matched inputs/circuit legs, usually to accommodate a differential signal input, generator/ source.
SE, a signal that is referenced to a nominal ground, zero volt reference.
Balanced Headphones, capable of being driven by a differential signal source.
Headphone companies really shot the pooch with this description. You'd think they would fix this nomenclature error. Of course places like headfi just perpetuate the mistake.
Atanasi
Sometimes a balanced headphone output is used to drive balanced line inputs. This is most straightforward with a 4.4mm connector, which includes the ground wire. If the headphone amp is implemented in the usual way, it would be balance in the line-level sense.
PeteL
But why would you want to do that?
D
Deleted member 2944
Guest
Yes indeed.
Amir makes the same mistake in premise that so many audio types do. Balanced interfacing is primarily about the source impedance(s) being equal and has essentially nothing to do with equal impedances in the load device. It's perfectly possible to have a destination device with unequal input resistances (or even gain) on both polarities and still have a proper, balanced, interface.
An active differential-signaling scheme is not required for a balanced interface.
Dave.
PeteL
Yes indeed.
Dave.
May you point me where he says that it's about equal impedance in the load device? I "kinda" get your point, but also note that Amir chose to not focus on CMNR, pointing that the actual benefit is minimal with short cable lengths, so yes the explanation is incomplete, but I've failed to catch actual "mistakes", but maybe I didn't catch that.
D
Deleted member 2944
Guest
He doesn't mention it. That's my point.
The key aspect in balanced interfacing is the equal impedance in both legs of the source device.
Amir seems much more interested in the input configuration of the load device.
The key (balanced) distinction here between input and output interfaces he doesn't mention at all. Which seems curious to me since the video is titled "understanding balanced audio."
Dave.
PeteL
Dave.
Yeah, but then it's just semantics, if we go there even the term balanced input printed on devices is debatable, you can only have a balanced "connection" not a balanced input.
D
Deleted member 2944
Guest
Semantics? No, these are actual interfacing issues that could exhibit in real-world systems.
Amir seems primarily interested in the alleviating of ground loops aspect of this, but there are other aspects as well.
This video seems aimed at less experienced audio types, and in that sense it's probably fine and dandy. But there is much more to this topic than he hit on. Anyways, it's not a big deal. It's just something I would have expected Amir to elaborate on.
"Balanced audio" is a premise that a couple of audio hardware manufacturers have placed their whole business model on.
Dave.
Ismapics
Question, which I believe it was addressed slightly. Are TRS connection / plugs (like form a mixer or pre-amp) balanced?
