Vandersteen VLR Speaker Review
Rate this speaker:
    Votes: 225 89.6%
    Votes: 18 7.2%
  • 3. Fine (happy panther
    Votes: 2 0.8%
    Votes: 6 2.4%
This is a review, listening tests and measurements of the Vandersteen VLR coaxial bookshelf speaker. It is on kind loan from a member and costs US $1,815 a pair.
The VLR is quite dense and heavy. Construction seems nice other than bulging out driver. The cherry finish is to my liking as a woodworker:
Seemingly the design has not changed in decades given the screw terminals. The VLR like other Vandersteen speakers uses first order crossover to keep it "phase coherent." I got a kick out of this statement in the manual:
And this:
Likewise listening tests comply with the latest research into proper evaluation of speakers calling for mono, instead of stereo listening:
Reference axis was that of the tweeter.
Vandersteen VLR Measurements
As usual, we start with our frequency response graphs:
Vandersteen VLR Bookshelf Speaker Measurements frequency response Coaxial.png
Oh boy! What the heck is going on here? We have rising chewed up high frequency response. Response is much smoother down low but sensitivity drops like a rock to just 80 dB. We have variation of 10 dB between that and the peaks in treble! Did they ever bother to measure this speaker? We also have large directivity error between 2 and 5 kHz.
Paradoxically, off-axis response looks good:
Vandersteen VLR Bookshelf Speaker Measurements Early Window frequency response Coaxial.png
This results in predicted-in room response which again, is surprisingly better than on-axis:
Vandersteen VLR Bookshelf Speaker Measurements predicted in-room frequency response Coaxial.png
Slope though is almost horizontal which means the speaker will sound bright. And with sensitivity of just 80 dB, will require tons of power.
There is essentially no directivity control:
Vandersteen VLR Bookshelf Speaker Measurements horizontal veamwidht Coaxial.png
Vandersteen VLR Bookshelf Speaker Measurements horizontal directivity Coaxial.png
So room sensitivity will be high. Due to coaxial design, vertical directivity is similar to horizontal:
Vandersteen VLR Bookshelf Speaker Measurements vertical directivity Coaxial.png
Impedance dips very low at high frequencies:
Vandersteen VLR Bookshelf Speaker Measurements Impedance and Phase Coaxial.png
Distortion is OK at 86 dBSPL but not at 96:
Vandersteen VLR Bookshelf Speaker Measurements  relative THD Distortion Coaxial.png
Waterfall shows resonances corresponding with those peaks in response:
Vandersteen VLR Bookshelf Speaker Measurements CSD Waterfall y response Coaxial.png
And here is the step response:
Vandersteen VLR Listening Tests
I started listening without seeing the measurements. The first track was a duet of a male and female. I could barely hear the male while the female came right through! This theme continued with tracks segments with lower frequencies almost producing no volume Yet high pitch sounds would come through, albeit, a bit much. It is like someone constantly changing the volume control on you depending on the spectrum. And not a little, but a lot.
It is clear to me that the VLR is designed based on ideology and not any objective or proper listening tests. In both domains, performance ranges from OK to dismal and does so within the same piece of music! The brand must have strong carrying power to get people to buy flawed speakers like this. I rank the Vandersteen the second most broken speaker I have ever listened to or measured.
Needless to say, I can't recommend the Vandersteen VLR. Company needs to wake up and completely retool its thoughts about speaker design. Customers deserve better.
  • Vandersteen VLR Frequency Response.zip
Blumlein 88
Yes, some of these old school speaker companies could upgrade their designs by using REW and a Umik-1. The upgrade could be considerable. Not to mention if they then did outdoor ground plane measuring to get closer to accurate results.
Have you yet measured any speakers with 1st order crossovers that do well at all? I cannot think of any.
eddantes
This is an odd speaker. Than on-axis is not that great but the PIR is ok... No bass though... so... What is the point of this speaker? Unless it was designed for surround duty, where on-axis listening is unlikely, and bass is the domain of the sub.
alex-z
"Phase coherent" aka fully bullshit.
I honestly did a double take, these VLR measure worse than the Vandersteen Model 2c produced back in 1980. I imagine half the members on this forum could design a better speaker just tuned by ear...
handler
Per the company, this speaker is designed to be used inside cabinets. IMO, people who love this brand follow it like a religion; disciples of the claimed benefits of time and phase coherence.
Maiky76
French, living in China
And this:
The port doesn't have clearance to go straight in so it almost immediate twists to the right and down into the enclosure. Overall the build is very solid making you easily confuse it with a top monitor brand.
Hi,
Here is my take on the EQ.
Please report your findings, positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 1.2
With Sub: 4.3
Spinorama with no EQ:
  • Poor
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
Score EQ LW: 3.6
with sub: 4.7
Score EQ Score: 4.0
with sub: 6.9
Code:
Vandersteen VLR APO EQ LW 96000Hz
July042022-104759
Preamp: -1.5 dB
Filter 1: ON HPQ Fc 72.01,    0.00,    1.04
Filter 2: ON PK Fc 724.61,    -2.33,    1.91
Filter 3: ON PK Fc 1137.24,    1.92,    3.90
Filter 4: ON PK Fc 3811.42,    -2.58,    1.19
Filter 5: ON PK Fc 4300.09,    -3.35,    6.96
Filter 6: ON PK Fc 11691.68,    -1.83,    1.11
Vandersteen VLR APO EQ Score 96000Hz
July042022-104656
Preamp: -2 dB
Filter 1: ON HPQ Fc 76.17,    0.00,    1.13
Filter 2: ON PK Fc 729.61,    -2.26,    1.91
Filter 3: ON PK Fc 1128.44,    2.14,    5.63
Filter 4: ON PK Fc 3810.42,    -1.93,    0.90
Filter 5: ON PK Fc 4296.09,    -3.55,    6.96
Filter 6: ON PK Fc 10773.96,    -2.74,    0.78
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Nice improvements
The rest of the plots is attached.
  • Vandersteen VLR APO EQ LW 96000Hz.txt
  • Vandersteen VLR APO EQ Score 96000Hz.txt
Blumlein 88
Hi,
Score no EQ: 1.2
With Sub: 4.3
  • Poor
Directivity:
EQ design:
Score EQ LW: 3.6
with sub: 4.7
Score EQ Score: 4.0
with sub: 6.9
Code:
July042022-104759
Preamp: -1.5 dB
July042022-104656
Preamp: -2 dB
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Nice improvements
Commendable work here, but with extensive EQ manipulation it still only scores at the lower end of things. I realize score isn't everything, one this far wrong is pretty sure to be wrong. Says more about the usefulness of EQ done well with measurements to work with.
dougi
ACT, Australia
Hey, but it's phase coherent, just look at that step response! I should try and measure my Elipson Planet Ls again, with more rigour, and see how they compare.
Blumlein 88
They make the same speaker with a carbon tweeter from their System 9 speaker ($150k plus) for $3291. Probably just needed a better tweeter. ;)
