Well I bought a Monoprice tube amp/dac
Rod
After a while if anyone is shows interest and if Amir wants to measure it I will send it to him. But give me a few weeks/month to enjoy it(or not).
Rod
Rod
One thing I like about it is i already have vintage 6080 and 2c51 tubes around the house for it. No tubes to buy. Now hopefully I wont have problems with hum.
RayDunzl
Central Scrutinizer
Riverview FL
Which one?
Rod
Rod
It was released just a few days ago. New product for Monoprice.
Rod
Rod
I dont know. Not enough background in tube amps for me to answer. The reason I said I was worried about hum is I have had trouble with tube hum at this house in the past and the same amp in another location there was no hum. If it does, I know its not a problem of the amp just to let everyone know. Solid state amps have not been a problem.
Wombat
Australia
Do the tubes run on low plate voltages?
cjfrbw
Does it come with voice recognition?
Rod
Rod
The power supply is internal, not an external brick. So I am assuming the plates have the correct voltage. I think your referring to the tubes that are more decoration than functional?
Rod
Rod
It sounds fine. No hum. I had some scratchiness in the sound but traced that down to charging my Apple ipad from a USB hub using the camera adapter. I then grabbed a USB wall wart charger and a different lightning cord and charged the ipad from that. The noise went away.
So far I like the bite in some music had decreased for sure and the warmer sound. I ended up putting a Gec 6as7g and two Chelmer 2c51's in it. Its a keeper. Looks like a mini computer. Heavy, 20.5 pounds.
Krunok
Zg, Cro
It does? With these specs?!?
Signal-to-Noise Ratio≤ 98dB (A weighted)
Total Harmonic Distortion< 1% @64 ohms
Only joking, I have tube amp myself so I know how little these specs mean. :)
P.S. Your RME ADI-2 DAC must be thinking it has done something really awfull in the previous life as it has been punished to drive this tube device with such ridiculously bad specs. Yet, I believe the SQ is just fine. :D
mi-fu
New York
it looks like a very interesting product with adjustable impedance, and can run as pre-amp too!
hope amir will be interested in measuring it in the future :D
Rod
Rod
Built like a tank to. Looks like something you would take to a Lan party. Its got the same kinda build like the Factual Define R5 PC case below it. Very similar. The metal, paint,shape of it. Looks like the top and sides are one piece secured by screws and it can be removed for access to the guts..
Rod
Rod
The tubes are melt your skin to the tube hot, or at least severe burns. Gotta let them cool before I take them out, I hope thats a clue.
