What does this actually do?
Purité Audio
Industry Insider
Barrowmaster
London
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
There is also a video, all results based upon subjective listening it would appear.
SIY
Alfred, NY
The Hugo M Scaler brings the unrivalled advantages of our ground-breaking FPGA-based WTA (Watts Transient Alignment) filtering technology to digitally connected audio devices, dramatically improving sound quality. Although optimised for use with selected Chord Electronics DACs (for the maximum 768kHz upscaling/decoding benefit), the Hugo M Scaler can be used with other DACs with suitable inputs, subject to their decoding capability.
It apparently aligns your watt transients. And thank god there's someone out there who recognizes this problem and is doing something about it!
maverickronin
Midwest, USA
It looks like it's simply a stand alone upsampling box. I'm not really sure what purpose it would server unless your DAC has wonky performance at particular sample rates.
OTOH, upsampling everything as much as possible seems to have become a popular 'tweak' so there's certainly a market for it. On the gripping hand, it costs £3495 which will buy you a pretty badass PC which can upsample to anything trivially or probably some sort of pro audio DSP box with a lot more useful features besides simple upsampling.
Werner
Europe
Well ... clearly ...
some recent Chord DACs have dual-BNC digital inputs, which are useless unless one finds
a source with double-BNC digital outputs.
This is this source.
Watts chases ever longer oversampling filters. Now his best effort has grown too large to be
housed together with the DAC. Hence the M Scaler.
solderdude
The Neitherlands
Perhaps someone capable of recording a 20kHz burst like the one in the video in 24/96 and 44.1/16 and record the analog out of a DAC reproducing it could easily show how 'big' this 'problem' is ?
Looks like a fun exercise for those with the proper tools to pull this off ?
derp1n
Does he really believe 44.1kHz is somehow limited (quantized) in timing resolution to 22uS? That seems to suggest a pretty fundamental misunderstanding of basic digital audio theory.
March Audio
Albany Western Australia
so a bass transient isnt successfully captured within a 22kHz recording bandwidth? Really? :)
So how does it recover the transient which was incorrectly recorded in the first place due to the limited sample rate with inadequate timing accuracy ? :)
solderdude
The Neitherlands
perhaps they stole the MQA secrets ? :rolleyes:
bennetng
https://www.stereophile.com/content/chord-electronics-dave-da-processor-measurements
You can use SoX to do the same before sending to any DAC, a cheap i3 is good enough. Notice that the spikes in my 19kHz signal already present before upsampling, they are not caused by SoX itself.
March Audio
A slight aside, thinking out loud so dont throw rocks. Isnt a single sample impulse by definition an illegal signal? Should we not only ever test with a signal less than 1/2 sample rate?
maxxevv
I would suggest before pre-judging to ask for an audition of the Chord DAVE with the BluMkII m-scaler.
Had the opportunity to try that with the Focal Utopia at the local distributor, it was quite the experience using a redbook CD of the Blu. Heard the Utopia on another setup at the same session, the listening experience was markedly different.
Of course, there are too many variables in that to ascertain where the 'euphonic difference' came from but its a pretty impressive sounding piece of kit.
SIY
Alfred, NY
Good luck finding a "local distributor" who will set up a valid, level-matched blind comparison.
I can't imagine why this would be the case. ;)
maxxevv
Not suggesting that. Just suggesting that its worth a listen with and without the m-scaler to hear if the differences are justified.
bennetng
The purpose of showing impulse response is to visualize filter characteristics therefore whether it is legal or not is irrelevant. However people need to pay a price for a super steep filter since it will generate higher intersample peaks.
Also, illegal signals in music can be an art form.
Purité Audio
Purité Audio
Industry Insider
Barrowmaster
London
Are there any benefits whatsoever in the million taps?
I notice that his ‘testing’ appears to be completely subjective.
March Audio
I appreciate that, what I am leading to is what is the real world behavior with band limited signals as we would have from any normal ADC?
