Size matters, there is no replacement for displacement, it’s about tactile energy produced. Larger drivers produce more and as a consequence your body feels/sense that.Their size
That's another way to do it . I tried that for awhile, but for some reason my brain struggled with it. I'm also enjoying pop/rock music a little more now I think. Tweeter is closer to mouth level(maybe like Danny Devito singing to me).When I'm listening to orchestral music, I tend to imagine I'm in the front of the balcony, not the floor seating, and it sorts things out for me. In fact, it's aligned behind the suspended microphones in major concert halls.
All that being said, the tweeter is at ear level as that's optimal from a vertical dispersion point of view. I suppose you could raise them and angle down, but then who knows what the floor might bring?
I think that ear level tweeter rule only applies to normal non coaxial design.That's another way to do it . I tried that for awhile, but for some reason my brain struggled with it. I'm also enjoying pop/rock music a little more now I think. Tweeter is closer to mouth level(maybe like Danny Devito singing to me).
Indeed, and that's why I initially took such care to make sure the tweeters were right at ear height. Also why I was hesitant to try(had to make some wooden lifts). I spent an hour or so yesterday going back and forth, and I honestly couldn't hear any negatives of the raised tweeter. I even did a few mono tests to listen for specifically tonal degradations. There were none, or if there were some, my untrained ears couldn't hear them .
Not sure if this will apply to everyone, but yesterday I discovered that tweeter height is a big factor in the "big speaker sound" for me. I was getting that small speaker sound with my 8351b, and it was most noticeable with orchestral music. Having the tweeters at ear level made it hard to imagine the performance as being real, as that's rarely how you hear live music. Raising the tweeters up 4" or so has gone a long way towards making them sound bigger.
Not sure if this will apply to everyone, but yesterday I discovered that tweeter height is a big factor in the "big speaker sound" for me... Having the tweeters at ear level made it hard to imagine the performance as being real, as that's rarely how you hear live music. Raising the tweeters up 4" or so has gone a long way towards making them sound bigger.
Size matters, there is no replacement for displacement, it’s about tactical energy produced.
My beta-testers came to the same conclusion.
I was afraid the unavoidably greater tweeter height of a new design I had in mind would be detrimental relative to the "tweeter at ear height" which was my normal. I asked my beta testers to raise up speakers they already had on hand by about four or five inches. They liked it so much they made the additional height permanent in their system.
So says the guy whose avatar is an Iowa-class battleship firing a broadside from its 16-inch guns.
Not that I disagree! But your appreciation for "tactical energy" comes as no surprise.
Correction. Autocorrect just keeps getting me! I typed “Tactile” energy. Autocorrect changed it to Tactical and I just noticed that. However, your point is absolutely correct.
Hello @mitchco ! I found your research on this topic very helpful. It helped me buy a pair of LS50 and I have no regrets
The question I have here: Is there a difference with the in-person experience? Wind from the ports flapping the sleeves on your shirt? More "thump" in the midrange? (assuming thump is not only from the subs)? Other perceptions in change of room pressure?
I think I understand that sound is sound, and when listening through headphones or computer speakers, the eardrum is small, so it makes sense how the LS50 could sound bigger perhaps as you say, as a result of room sound. This is referring to listening to recordings of speakers rather than being in front of them.
The thread title does say "sound" so maybe I have to leave it at that. If air movement or visible cues change the input so that your brain translates that into bigger sound, it would be more accurate to say it's a bigger experience (not measurable) instead of bigger sound (measurable)?
This is ASR after all so if there is really nothing to bigger speakers, I would like to know.
For example, I could see a movie theater using JBL M2 but not Salon2 (ignore the cost for a moment). Even with the Salon2 "preferred" and the 3-8" woofers roughly equal to a single 15" Maybe it is an issue of SPL at that point?
How accurate would it be to say, at a given SPL (80) there is no difference in the sound OR the experience? Bigger drivers simply can get louder, with lower relative distortion, than smaller drivers, and this is only useful or needed at high SPL (stage, auditorium, etc.)?
Do headphones sound "big" or "small" or "it depends"?
If you have height channels, some types of surround mixing will pull the front image upwards as well. DTS Neural X and Auro3D(to a lesser extent) both do this in my experience. Dolby Surround doesn't seem to, however.
This 100-700 Hz ish 'envelopment' region is what tends to differ the most among small and big speakers, or perhaps more specifically, narrow and wide baffle speakers.
While a speaker of any size can have 'wide' or 'narrow' directivity in the traditional sense at upper frequencies (the image/source broadening region), big speakers have a distinctly different response in the lower mids and upper bass.
They can control directivity far lower. Larger speakers tend to have narrower/flatter directivity at these lower frequencies and imo that contributes a lot to the 'bigness' of a speaker.
Maybe I missed something: What I read about most conventional, non-cardiod/non lossy side-ported w/ dipole boxes is that they can only from around 500 Hz upwards establish constant directivity. It is is in the upper part of the frequency region you described as being crucial to the ominous big speaker sound and they behave comparable to any other box below, transitioning into 4 pi radiation in the low mids/bass. The D&D 8c is not to be compared with these 'conventional' speakers with wide baffles, a CD horn and a big woofer. A D&D engineer introduced their concept when back when the 8c was not a reality, at another forum: https://www.diyaudio.com/forums/mul...vity-low-200hz-using-drivers-post4595604.html
