terfenol-D
- Joined
- Nov 11, 2020
- Messages
- 45
- Likes
- 27
All,
I am looking at purchasing an Anthem STR preamp to replace my NAD C658 preamp to hopefully improve room correction. I have similar sub output concerns with my NAD that is well documented in the C658 thread on here.
The Anthem has balanced outputs for both main channels and subs in both XLR and RCA connections. My current sub only has RCA inputs. I have threads here that going from balanced to RCA connection via patch cable can be problematic. I also have read that balanced has higher voltage output (gain?) than RCA which leads to difference in levels. Does anyone know if the ARC room correction/bass management corrects for the different output types? IE - do I need the preamp via all RCA or all balanced outputs to take advantage of room connection? I know you can use both at the same time just don't know how the use of both is impacted by room connection. I have a theory this question (balanced vs sub RCA output) is what causes the issue in the NAD. I don't really know how to test that theory though.
I could potentially switch subs but am size constrained in how large the sub can be. I currently have an SVS micro 3000. I can do another one but can't really go larger.
Thanks.
Thanks.
