Anyone ever measure a Sanway professional audio amplifier? Crazy specs...
cavedriver
Maryland, USA
Someone asked about these Chinese-made pro audio amps in another forum and it got me looking at their specs. Pretty crazy numbers. For example, if they really measured at >110 SNR wouldn't that be in the top 3 amps ever measured by ASR? I didn't see them hardly mentioned here when I searched.
They are stunningly cheap for the power - $880 if Aliexpress can be trusted (plus $250 for shipping). They are also relatively small - 1U rack size for 17,100 watts into 4 ohms. They are marketed as "subwoofer amplifiers" but their specs look like they would work fine full range. Granted almost no home use would ever need that much power. They are apparently reasonably well regarded as PA amps. Note that with a max draw of 85 amps (!), I would need to wire a new circuit to my movie room if I wanted to run a pair of subs of one of these. :D
Edit- as a further thought, with several cooling fans across the back, even putting the unit in my "media closet" in the rack it would probably still raise the noise floor in the movie room, so that's kind of a fail. Maybe I could 3D print a duct and use larger and quieter Noctua fans.
ITEMDA43K2
8Ω Stereo Power(RMS)4300W ×2
4Ω Stereo Power(RMS)7900W ×2
2Ω Stereo Power(RMS)8600W ×2
8Ω Bridged Power(RMS)15700W
4Ω Bridged Power(RMS)17100W
Frequency response20 Hz-20 kHz(1W@8Ω,±0.5 dB)
Total Harmonic Distortion (THD)<0.5%from 1 W to full power (Typical value<0.05%)
Signal-to-Noise Ratio 8Ω, 1kHz,1v Sensitivity>110 dBA (20 Hz-20 kHz,A weighted)
Gain.Sensitivity32dB,35dB,38dB,41dB
Cross-talk( 20Hz- 1kHz, below Rated Power )>66 dB @1 kHz
Slew Rate50 V/μs @8Ω
Maximum Output Voltage/Current185V/85A(370V in the BRIDGE MODE)
solderdude
The Neitherlands
Notice the A in A-weighted !
Amir reports dB (at 4.47V = 5W in 4ohm) where this amp is reported in dBA but at 1V so the numbers are not comparable.
I would not want to connect this amp to any of my speakers... just imagine the volume got turned up by accident !:)
DVDdoug
There's more than one way to measure SNR. I believe Amir measures relative to 5W and the higher power the higher the "S".
And of course, you can't always trust wattage specs either.
C
cavedriver
Maryland, USA
ooch, I missed the "A", although still, would like to see measurements, although I don't think Amir has test loads or maybe even meters that could measure these amps.
Regarding amp ratings I agree, but 185 V and 85 amps is a LOT of watts (15275 to be precise). I would say that not since 1990's car audio have I seen power numbers be lied about on that scale. They certainly pass the "is the case stuffed with enough parts for the power" test, lol.
Devnull
Might be fun to do some stick welding with it, aside from that would you really trust it to not burst into flames in your home?
C
cavedriver
Maryland, USA
Note that Erin just smoked a Fosi amp, like it literally went up in smoke, so are we really being critical about our risk taking re Chinese-made electronics? With the amount of power this thing has it would be idling compared to powering a sub with a Dayton, ICE, Crown, or Yamaha amp that probably has more distortion. Not saying this is THE solution, but I would really like someone else to buy some and test them so I can benefit from their experience :)
restorer-john
The S/N is quoted with respect to full rated power.
Even if the power output numbers are pure fantasy and only a quarter of what they say, it is still a very noisy amplifier.
C
cavedriver
Maryland, USA
honest question - how can you tell that from the specs, or is there another way to know?
restorer-john
S/N in a power amplifier is always quoted WRT full power as it gives the best numbers for marketing. The more powerful the amplifier, the bigger the number, all other things being equal.
The "1V sensitivity" is the input voltage to develop full rated power. As it is such a "high" power, it needs a lot of gain- so it gets 32,35,38,41dB gain switching. A normal amplifier is around 29dB gain with a 1-1.5V sens.
I would want S/N WRT 1W@8R for all amplfiers.
somebodyelse
SNR is signal to noise ratio, not including distortion. SINAD includes distortion. Based on the THD figure the SINAD would be dominated by distortion, not noise, with their 'typical' figure being better than 66dB - respectable but far from great.
restorer-john
Specifications are one thing, test results are another.
Don't make asumptions.
