- Joined
- Feb 23, 2016
- Messages
- 20,833
- Likes
- 37,770
Wondering about noise audibility for people here on ASR.
I created a file, that has 2 seconds of filtered white noise from 3-5 khz followed by two seconds of silence. It repeats for 16 seconds. That keeps noise and no noise segments in echoic memory. The noise is in the ear's most sensitive region of frequencies. The filtering isn't steep. Rolled out 6db / octave below 3 khz and 12 db/octave above 5 khz.
Download this zip file:
https://dl.orangedox.com/OjZQs4QF7HYPQyP5gg
It will open into 9 files. The noise starts at - 30db in the first track so everyone can hear it, and then goes down by 10 db steps until the last file is at -120 db. The files are 44.1 khz/24 bit files. Uncompressed wav.
My suggestion is play a couple of your favorite songs to set a normal comfortable volume level. Then without altering volume level listen to these tracks. Let us know on the thread at what level the noise disappears for you.
In addition to that, I took those noise files and mixed them into a 30 second song snippet. Here you can download a John Hiatt track with different levels of noise mixed in. Again listen and let us know at what point the noise is not heard by you. Set it to a comfortable volume on the first track, and don't alter the volume.
https://dl.orangedox.com/UEMeePLXxfmSIm4bUt
Same as the above, in this case an Eric Clapton/John Mayall track snippet with noise mixed in at levels from -30 db to -120 db. Let us know at what level the noise disappears to you. Again after setting a comfortable volume don't change volume levels.
https://dl.orangedox.com/8eCgDgxmZrbsyZ8xE2
Hopefully it might lead to some good discussion and we can see how this differs for different people using different systems.
