I've collected a few from elsewhere on ASR...Where do I get that from?
Thanks
Thanks
Thanks, I'll try that.I've collected a few from elsewhere on ASR...
OCA,This was my first solution idea. Unfortunately, the AVR will completely mute after the transfer of any ady file with "enTargetCurveType: 0"
PS And other values like 3,4,5,6.... all default to 1!
Audyssey Flat is hardcoded to bypass app customTargetCurvePoints so all filters will be deactivated. There's an anti high frequency roll off added to each filter in A1 that attempts to reverse the odd effects of reference curve.OCA,
have you tried, if it is possible to trick Audyssey into applying a target curve in Audyssey "flat"-mode, by replacing the pseudo perfect speaker measurement (Dirac-impulse) with the impulse response of an (inverted) EQ target respose curve?
If REW allows to export parametric EQ filters as impulse responses of the needed lenght and sampling frequency MultEQ is expecting as speaker measurements, it could be possible to make Audyssey apply all kind of target curves in the flat-mode:
1. Create the wanted EQ correction curve in REW with REWs parametric EQs.
2. Invert all EQ gains/cuts
3. Export all the EQing as one single filter as an impulse response (in the needed MultEQ length and sampling frequency).
4. Load it into ADY as pseudo speaker measurement.
That impulse response is the wished inverted EQ target curve and is injected into MultEQ instead of the perfect Dirac impulse.
Then Audyssey, instead of a perfect speaker response, sees that inverted filter as the measured speaker response, and should try to flatten it by applying an inverted filter to the inverted filter impulse response... - therefore resulting in the wanted target response curve created in REW.
That way Audyssey Flat-mode would correct torwards flat without HFR and, Audyssey Reference-mode would apply the HFR and probably even allow an additional MultEQ target response curve to be applied...
I know. Therefore my idea to use speaker measurement as an inverse target curve to make Audyssey create the wanted target curve, when it corrects torwards "flat".Audyssey Flat is hardcoded to bypass app customTargetCurvePoints so all filters will be deactivated. There's an anti high frequency roll off added to each filter in A1 that attempts to reverse the odd effects of reference curve.
Yes, that works. Just add whatever target curve you want in REW instead of adding the supplied toole curve.hello, instead of the Dr toole curve, if I want to put the Harman curve, is this possible?
just replace the EQ file in REW and run the 1.3 A1 script for example?
I'm using Harman. But it is pretty much going to be down to personal preference.THANKS
what is the ideal “target” curve for home cinema
Toole? harman? rtings? ....
It doesn't take long to run the script, so you can try a few.
No, used it as it came.did you increase the level of the subwoofer with harman?
This comment from OCA needs more attention that it is getting!Yes and repeat at 8 times for better SNR.
I’ve had strange results with not moving the microphone. 10-20cm apart works better in my experience. I do use 8 positions.This comment from OCA needs more attention that it is getting!
I would be interested to know what your results were with 1 position, 8 times. Personally, i found my bass was about 2hz lower when i did multiple positions10-2cm apart. I wish OCA would expound on this.I’ve had strange results with not moving the microphone. 10-20cm apart works better in my experience. I do use 8 positions.
