PortalKeeper
- Joined
- Feb 8, 2023
- Messages
- 46
- Likes
- 2
Hello, I’d say I’m somewhat of a noob here.
I have an Audiophonics lpa-s400et power amp and kef q950 towers. I would like to build a system using at minimum two subwoofers with MSO, Dirac, REW, or some other software I currently know nothing about to correct for room modes in my 25’x11’x7.25’ (length by width by ceiling height) basement. I do make music and would like the top of the line ADC that is reviewed here (I think this is the RME ADI-2 pro, although this DAC doesn’t appear to have been reviewed individually by Amir yet, only in comparison). I would like to use a pro dac since I was dealing with speaker hiss (pro dac will let me turn gain to low on my power amp) with my last DAC (Focusrite Scarlett Solo 3rd gen) but they don’t seem to have SOTA SINAD levels which I really value so I thought maybe the Topping pre90 would be a great solution here. I would like to use balanced connections for the entire system.
I would really appreciate any help in setting this system up. Also, I would like to know if there is any way to make this system using a DAC that Amir reviewed with a SINAD>122. The reason for this is I don’t think any minidsp product can achieve this high of a SINAD and it seems they are the main solution for multiple sub optimization.
Thank you for your help.
