So after we put in the Kenwood headunit, the factory amp would always stay on (Via audio sensing) and drain the battery. The old JVC and OEM head-units never caused this problem. So I did a "Factory Amp Delete". I used the factory wiring for power with the new amp (Its temporary) and it technically a success. Only turns on when the radio does and I got plenty of control. The main issue, is when I do anything, there is a pop. Change a song, pop, change setting, pop, etc. I look on the internet and its either a RCA ground issue or an amp ground issue. I'm fairly certain its an RCA issue because the factory amp never did this and it used the same wiring for power.
Maybe I can ground the RCAs at the Amp side or maybe I can pay somebody else to fix this mess. I'm tired of playing around with fragile plastics and unbolting.
