Constant Beamwidth Transducer (CBT) Speakers
Bjorn
Norway
No need to get snappy. IR peaks are dominated by HF. So again, can you please share those measurements?
And that matters when the speaker has a constant vertical directivity down to Schroeder? Please explain why.
Ever heard about a bandlimited ETC BTW?
markus
That's exactly the question – does it really have "constant vertical directivity down to Schroeder?" Please post data showing this. I can't remember seen it published. Is it somewhere in Keele's papers?
Yep, and it's of limited value for showing the claimed behavior with the Schroeder frequency – and a large transition zone around it – usually at around >200Hz in acoustically small rooms.
Newman
Yes, pretty much.
This is from Keele’s modelling:
Keele, A Performance Ranking of Seven Different Types of Loudspeaker Line Arrays, 2010
He also did actual measurements and essentially confirmed the model for vertical. I need to dig further to find them.
cheers
markus
Yes, pretty much.
cheers
Thanks, remember those theoretical calculations when I read the Keele papers back then. Would like to see Bjorn's claim of "20dB attenuation" confirmed for a real design though.
And again, an ETC won't do even when band-limited. You'll fight frequency vs time resolution and in the end graphs aren't as conclusive as desired. One would need to look at free field data instead.
A 20dB attenuation at a 40-60 degrees angle is pretty hard to do. Something like a Quad ESL-57 does it.
