Difference between Audiophonics MPA-S250NC and HPA-S250NC
ovi
A look at the images of both products is also quite revealing:
audiophonics-mpa-s250nc-rca-power-amplifier-class-d-stereo-ncore-nc252mp-2x250w-4-ohm.jpg
vs
audiophonics-hpa-s250nc-power-amplifier-class-d-stereo-ncore-nc250mp-2x250w-4-ohm.jpg
Overseas
vs
Welll... it is not revealing for lay listeners like me. That is what I am trying to say. I know it is hard for technical people to put themselves in our shoes.
Nicolas_
Nicolas_
There is also this beast, for which, as far as I can tell, the only difference compared to the MPA is the XLR inputs?
VintageFlanker
Paris
Well...That's one dual channel module VS two mono channel, really nothing revealing to me. ;) But if you wonder, the bigger will deal better with heat dissipation.
There once were two MPAs, one with XLR, the other with RCA. The new chassis now includes both inputs, while having another (larger) form factor. That's all.
I should have read the datasheet before I purchased a lot of ICEpower 2000AS2 modules....
The sales department says this:
While the truth is more like this:
The way I understand it, it's 2000W short-term (my 1200AS2 claimed 1200W, mono, but for 90 seconds before the module shuts down). This seems to state without shutdown. Meaning 290W... forever?
Nicolas_
Nicolas_
Got it, makes sense.
None of these have a sub out as far as I can make out, though the integrated amp versions (DA- and DAW- ) do. Does that mean that if using those power amps in a 2.1 setup, the sub out must be on the preamp? But the WiiM Pro+ doesn't have one... No way to use a (powered) sub with the combination I had in mind?
StigErik
Norway
This is a bit off topic, but anyway..
The 2000AS2 datasheet states different power levels depending on their duration. With one channel driven it can deliver 2000W for just 20 ms. That's equal to a single period of 50 Hz sinewave. With both channels driven, it can deliver 2x700W for 150 ms, but only at frequencies 50 Hz or higher. When those limits are exceeded, it goes into protection mode. Not exactly useful for powering subwoofers...
In my experience, the real world limit of the 2000AS2 is around 2x300W when used to drive subwoofers where the signal might be as low as 10-15 Hz, and power bursts are a lot longer than 150 ms.
It's a bit ironic that the old 1000ASP could deliver more than 1000W continuously for several minutes before it entered protection.
D
Deleted member 68495
Guest
Absolutely not. Difference between NC252MP and NC250MP is the fact that you deal with separate modules, with supposedly better separation and longevity for modules SMPS.
Apologies if my question is a bit out of the topic, but I found your remark quite revealing and made me wonder: do you think that two mono purifi amps will have better separation and longevity than the one commented here, the 1 ET-400A? I'm asking because getting two monos at Audiophonics is almost the same price and it might be a better option...
Otherwise, what would someone go after when choosing monoblocks instead of a stereo amp? The possibility of using longer cables with balanced connections?
Rotor
The first is described as a "stereo/large single mono dual amplifier [...] based on a duo of Hypex NCore NC250MP modules"
The second, as a "stereo amplifier based on an (single, I presume) amplification module Hypex Ncore NC252MP"
Are they made for different usages?
Apart from what others have mentioned, the first one has both balanced inputs and RCA.
The direct comparison would be with this 2ch version that also has balanced and RCA. (I bought one recently and I am very happy with it)
D
Guest
Hi there, I am considering buying this exact same amp (AP300-S250NC)
If you don't mind me asking, which speakers are you using it with?
In my case, they are 8 Ohm (min 6Ω) with 86 db, do you think it will be enough amplification power, considering the listening distance is 2.5 meters and I usually listen up to max 85db?
staticV3
Could you please tell me the speaker model?
Jukka
I've used both stereo and mono amplifiers for a stereo set. A mono amplifier is one box with one channel input and output for one speaker.
With monos you:
- get better channel separation (crosstalk)(not really a big issue with Audiophonics products)
- can place amps right next to speakers (less external noise pick up)
- have a power on ritual before starting listening.
With stereo you can:
- save space
- save money
- improve usability (all-in-one etc).
Both options are valid for people with different requirements and tastes.
When putting dual mono into one box, it gets into the over-engineering and in practice excludes the goods points of real monos. If you are into over-engineering, you might want to use a dual mono amp, but be sure to validate performance, because over-engineering can easily ruin performance, because it gets closer to over-marketing than engineering.
V.b.
Well. I'm not so sure since both the dual-channel NC252MP and the single-channel NC250MP has the same power supply.
If you look closely you will notice that NC250MP has one amplifier channel from NC252MP and NC122MP power supply. Also NC500MP has one amp from NC502MP and NC252MP power supply.
Sokel
On the other hand it can do 2200 watt with one channel driven for 400ms and 1200 watt for 60 seconds under the test conditions specified on the paper.
The smaller one Amir measured (the 1200as2 in the Peachtree) delivered a little more than the specs even with the "audiophile" buffer in front of it down to 20Hz.
Duration is also a matter of cooling,most very high power amps are actively cooled apart from those with REALLY oversized heatshinks.
Agreed about the marketing though,most of the new Class D modules has the 1/8 of the peak power spec'd for continuous power at the fine letters.
